Results 1 to 21 of 21
    Aug 24 2018
    United States
    Smile 55k service B8.5 service schedule and part list?
    Can anyone point me to a resource that lists out the specific items that need to be done for the 55k service? I just hit 55k and am a little behind on figuring out what needs to be done and gathering the parts.
    Thanks in advance!
    Aug 24 2018
    United States
    Found it! Looks like I will need to order oil, oil filter, dust and pollen filter, spark plugs, and supercharger belt.
    Is replacing the supercharger belt really necessary if there is no visible damage? Looks like this was replacement interval went from 75k miles to 55k miles from the B8 to B8.5.
    Nov 28 2018
    Las Vegas
    Quote Originally Posted by jhoffy22 View Post
    Where did you get that screenshot?
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    The belt is probably the easiest part of the service so I wouldn't skip it. For the low cost and the piece of mind its worth just doing it.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Veteran Member Four Rings 303 Spartan's Avatar
    Aug 16 2016
    F87 M2 Comp
    Colorado
    Quote Originally Posted by Solarsuplex View Post
    Is the "Ribbed V Belt" just the super charger belt over the SC and crank pulleys?
    I'm coming up on my 55k mile service as well and this chart made me realize that I've pretty much already taken care of all the necessary stuff in the last 10k miles, after going stage 2 and upgrading the HX. New SC belt, fresh coolant, new spark plugs with proper gapping and fresh oil/filter every 5k. If the belt they are referring to is the SC belt that gets replaced when you go stage 2, then it looks like I just need to replace the cabin air filter and pollen filter and call it a day.
    Correct me if I'm mistaken.
    Current:
    21' GMC 1500 Denali
    Gone:
    B9 RS5 Sportback / APR+
    F80 ///M3 | 6MT
    B8.5 S4 / EPL Dual Pulley Stage 2
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by 303 Spartan View Post
    100% correct as far as I know. Buy a new CAI and all you have to do is he cabin filter
    -James
    Aug 16 2016
    F87 M2 Comp
    Colorado
    LOL! I replaced the OEM filter with a AFE Pro dry S filter when I installed the 034 inlet hose about 15k miles ago.
    What a nice little surprise this is! Looks like I'm good to go for the foreseeable future (aside from the cabin filter). Just need to change my brake pads and brake fluid at some point when they get low enough.
    Current:
    21' GMC 1500 Denali
    Gone:
    F80 ///M3 | 6MT
    Aug 20 2011
    Seattle Wa
    That’s basically the extent of service. At 70-75k revisit your dsg fluid and filter if that’s your transmission. Potentially earlier if you are stage 2 as you mentioned. Audi suggests every 35k but the timers suggest slightly shorter intervals.
    -James
    Aug 16 2016
    F87 M2 Comp
    Colorado
    Yeah, the DSG fluid/filter (and sport diff fluid, I believe) were changed at 35k. I'll get that changed again around 65k to be on the safe side, now that I'm stage 2.
    I've gotta say, coming from the Subaru world, I really expected the maintenance on the S4 to be considerably worse. That's not the case.
    Current:
    21' GMC 1500 Denali
    Gone:
    F80 ///M3 | 6MT
    Aug 20 2011
    Seattle Wa
    Well this is the ‘preventative’ maintenance. We still have plenty of things (anything plastic/sport dif/ mechatronic/cats/internal intercoolers) that could potentially go wrong. Only age will tell.
    -James
    Nov 28 2018
    Las Vegas
    Indeed. This is the most complicated primary powertrain I’ve ever owned so it will be interesting to see the design durability of all the individual systems beyond 75k
    Aug 20 2011
    Seattle Wa
    Lucky for us the b8.5 is only a mostly fixed version of the b8 and the b8 hardly had any major issues. Without jinxing myself I could see this chassis/motor being fine to 100k. I’ve only been told the OE struts are of great quality so I don’t see them needing a refresher anytime soon.
    -James
    Veteran Member Four Rings kjeeper10's Avatar
    Dec 07 2017
    2007 Jeep Wrangler JK
    Same lol well the dealership replaced the tires, spark plugs, wipers, brakes at 56k
    2015 Daytona S5 - Madico Ceramic Tint 35/20 - 6 Speed - Mods - Sprintbooster V3 - APR Stage II - Dual Pulley - CPS Cooler - Eurocode ST Shifter - EuroImpulse weighted knob - USP SS Clutch Line - 034 SD Engine Mounts - 034 Trans Mount Insert - 034 rear SB - CR-15 - ORT Coilovers - SPC Front CA’s - IE Non Res Downpipes - AWE touring w/ 102 tips - CTS intake - ECS Streat Shield - Deval CF Splwitter/Rear Valance - Signature SV901 Forged 19x10.5 wheels - 275/35 Mich PS4S Tires.
    Aug 24 2018
    United States
    Quote Originally Posted by basssteakman View Post
    Directly from audiusa.com after signing up for My Audi and clicking on the maintenance schedule.
    Aug 24 2018
    United States
    Are these the plugs that most of y'all are running for B8.5 S4s?
    https://www.amazon.com/gp/product/B0...ustomerReviews
    6 New NGK Iridium IX Spark Plug BKR9EIX # 2669
    My research revealed that there was a changing of the part number from B8 to B8.5 so it's a bit tricky figuring out which one is the actual OEM plug number for B8.5.
    Aug 17 2017
    2001 Audi TTQC 225, 2003 VW GTI 20thAE, 2016 SQ5
    Atlanta, GA
    I would hope it would make it further than that!
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by CollecTTor View Post
    Fine meaning you won’t have to deal with any pesky little gremlins. Every car gets them as they age so it would be insane to pretend they don’t exist. But not for the next 2 years in my case.
    -James
    Aug 24 2018
    United States
    Which plugs are you running, sir? I see that you, too, have a B8.5.
    Senior Member Three Rings S5boxster's Avatar
    Sep 14 2016
    986 boxster
    East Brunswick NJ
    I get my oil and maintenance parts from Europa parts located in Piscataway NJ they ship to you or you can pick up from them. I did change my plugs and coils at home
    Here is a DIY video in YouTube
    https://youtu.be/wmZI42A-JPA
    Sep 14 2016
    986 boxster
    East Brunswick NJ
    Quote Originally Posted by S5boxster View Post
    I changed my plugs at 50k and car engine feels alot smoother and more mpg.
    Add liqui moly cera tec to next oil change engine loves it
    Aug 20 2011
    Seattle Wa
    I went through some old texts and found I purchased OEM NGK and was advised to tap them down to .026”. I changed them prematurely as I had a misfire on startup cel being thrown shortly after getting the car so it was a while ago and I started documenting everything after the fact. Sorry for the ambiguity.
    -James
