Possible it wasn't bled properly/completely after the coolant refill. I would think this would result in engine coolant temps being off as well, but could be a bubble stuck somewhere. If there were no issues with heat before the work was done, most likely related to the work performed. There are additional steps even if a vacuum fill was performed. See below for excerpt from manual following a vacuum fill. Obviously keep the reservoir sufficiently full the whole time.
1. Bleed at SC screws, one at a time (passenger side first).
2. Bleed heater core hose (passenger side, just behind positive terminal in engine bay, need to remove plenum cover)
3. Manual refers to a parking heater, not sure what that is, but turn it on if it has one.
4. Lastly, perform the following:
– Tighten the cap on the coolant reservoir until it locks into place.
– Start the engine.
– Set the temperature to “HI” for all zones and set the fan speed (0).
– Press the AC button to turn off the A/C compressor (LED OFF).
– Run the engine at 2000 RPM for 3 minutes.
– Run the engine at idle until both large coolant hoses on the radiator are warm.
– Run the engine at 2000 RPM for 2 minutes.
– Turn off engine and allow it to cool off.
