Went for a spirited drive through the canyons and somehow managed to trigger tones of fault codes. I have the cete module lowered 25 mm. It has caused some faults in the pass that are usually able to be cleared using obdeleven. Now I am unable to clear 4 major ones...brakes, steering, and a couple others that's slipping me at the moment. Nothing I do works. I have also tried disconnecting the battery for 30 minutes to no avail. I though about flashing back to stock to see if that would help but I'm not sure. Any suggestions?
