Originally Posted by
trophies
Can someone give me a TLDR for washing technique besides the two bucket + mitt method? Debating if I should save myself the money..
Or, what if I decide to actually wrap the car down the road, thinking a Porsche chalk grey. If I did a clear bra PPF now then that would be pointless right? Maybe even hold off on ceramic coating if the probability of wrapping my car a new color is even in sight?
I would determine if you want to change the color of your car first (wrap). Paint Correction should be the first step of whatever you do. You could opt to not do the correction first if you're going to wrap it, since when it comes to removing wrap, it will leave a lot of residue and you'll need to claybar (which WILL micromar your paint, needing a correction/polish after)...it all depends on what you want to spend.
If you decide to stick with the color of what you have, then apply Paint Protection film. You can (I would) Ceramic Coat after applying the film, but technically, you don't need to. Just keep it protected with wax or a paint sealant.
If you decide to change the color and wrap it, then I would just get a paint sealant and keep the paint protected until you decide on a color. Ceramic Coating now, then wrapping, will prevent the adhesion and longevity of the vinyl wrap. PPF now and vinyl wrap second would just be a waste.
What I would do:
Color the same:
-Paint correction
-Paint Protection Film (or vinyl wrap)
-Ceramic Coat
-top with Paint Sealant
-wax over sealant (optional)
Two bucket method:
1) I use a snowfoam cannon (connects to pressure washer) and foam the entire car as a presoak. It helps loosen dirt and grime while you prep the buckets.
This is optional, but I do it...and customers like the pictures.
2) One bucket a PH Neutral soap (or get some Optimum No Rinse*). Fill the other bucket with water. Buy a grit guard, and place it in the water bucket.
3) Use a mitt, soak it full of the soap bucket. Start at top of the car and work your way down.
4) After every panel (if not more often/when you need more soap), take the mitt and dip it into the water bucket. Scrub the bottom of the mitt on the grit guard to release the dirt from the mitt. Remove excess water from the mitt.
5) Dip back into the soap bucket and get it all sudsy again. Move to next panel.
6) Rinse car (either panel by panel depending on how long it is taking you/how dirty it is), or at the very end. The PH Neutral soap helps prevent water/soap marks.
*Look up Optimum No Rinse. It has a TON of uses based on dilution ratios and I absolutely love it. Soap, rinseless wash, waterless wash, quick detailer, clay lube, glass cleaner, interior quick detailer.
~Feel free to check out my pages. I'd appreciate the follow.
Website:
https://www.refinedautodetailing.com/
Google:
https://g.page/RefinedAutoPA?share
Instagram:
https://www.instagram.com/RefinedAutoPA/
Facebook:
https://www.facebook.com/RefinedAutoPA
