Results 1 to 40 of 45
    Dec 16 2018
    NH
    Staggered tires and AWD
    Hi Guys,
    Something I have never understood about staggered tires on an AWD car.
    I know the tire width doesn't really matter as long as the height is the same so front and rears rotate at the same speed. But with our staggered setup the rear tires are half inch taller that the fronts, So the fronts are rotating faster than the rears, wouldn't that put some extra stress on the center diff?
    Nov 06 2017
    Vancouver
    Well first off there is no center diff, just a haldex unit.
    Second the original RO2 tires are sized so they are very close to same height, this is why you are finding some guys complaining of very easy to trigger traction control when they change to another brand.
    Apr 20 2018
    Chicago
    Also this setup is done to allow the back end to be a bit more lively when cornering. Won't be like a rwd M2, but would be even less fun with square setup.
    Dec 16 2018
    NH
    Quote Originally Posted by Potatohead_RS3 View Post
    Ok, but there has to be something rotating at different speeds in the drive line somewhere?
    Hmm, I was planning on switching to Pilot Sports when the PZeros wear out (Which seems like will be quickly)
    Established Member Two Rings sti-tom's Avatar
    Nov 17 2017
    Edmonton
    Quote Originally Posted by omniphil View Post
    Hi Guys,
    I found the big height difference to be alarming at first as well, especially considering the fronts will wear at a faster rate then the rears making it even more then a .5" it starts out at. This would have caused some massive issues on my STI or GTR, but it is a lot more acceptable with the Haldexs these things have. To even it out as much as possible for my racing set of wheels/tires, I went with a 265FR and 235R to get the difference down to .1".
    Nov 06 2017
    Vancouver
    Haldex is basically a unit with clutches inside at the rear diff that lock and unlock (or anywhere in between) according to what the computer is telling it to do, it is constantly adjusting, some differential front to rear is not only ok, but normal. They always have to allow some wiggle room to allow for tire wear and what not as well.
    Like sti-tom said the easy fix is to put a 265 tire on the front when you replace them, but I'd also have to check how many will work on a (stock) 8.5" wheel. Personally I will probably stick with 255 and if I have problems just turn the TC into sport mode more often.
    Also FWIW I had ~7300 miles on my tires when I took them off for winter and the front are like 90% pooched. lol
    Dec 16 2018
    NH
    So then I am guessing that most of the time the rear tires are disconnected from drivetrain, so then the speed difference is not an issue most of the time.
    7300 miles on the stock tires, yikes, I'm hoping to get to November with mine then put winter tires on the stock rims.
    I wonder what size people are going with for winter tires on staggered rims.
    Mar 07 2017
    San Francisco
    I had a nail+leak in one rear tire, Audi just replaced (under tire warranty) the one tire yesterday. If the other side is worn (12k miles), should they have replaced both rears?
    18 Silver RS3. Notable past cars: v10 r8, noble m400, lotus elise
    Nov 06 2017
    Vancouver
    You never want side to side to be more than about 3/32 different at most, so I would say yes they definitely should have done both. And that rep there needs a smack because that's an easy sale for the second one
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I had a legitimate staggered AWD car from factory (Porsche 911/964 Carrera 4 Cabrio) and the car came with 205s(Front) and optional 255(Rears). One time I put 215s in the front and the car made all kinds of grinding noises and it will shake bad. It was undriveable pass 15mph and had to be towed to the factory just to find out that the AWD system was very delicate. If I were you I would use the tire rack calculator and pick something equivalent in diameter.
    Out of of 16 or 17 sports AWD cars that I had the mismatch staggered set up is the only one that gave me issues. My current RS3 does not have the staggered wheels.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    May 16 2017
    MD
    Just make sure you do research, I believe Michelin tires were one of the brands that had TC issues when staggered.
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Haldex is basically a unit with clutches inside at the rear diff that lock and unlock (or anywhere in between) according to what the computer is telling it to do, it is constantly adjusting.
    Just to touch on this subject, the rear haldex filter on the MQB cars gets clogged up with clutch material and debris extremely quickly (~15k miles). This can lead to loss of rear differential function if not addressed. Fortunately the servicing is pretty straightforward and inexpensive, just be sure to service it regularly.
    Dec 05 2010
    Los Angeles, CA
    So, what are you all replacing the staggered tires with when the OE ones are toast? What brand and sizes did you use and did you have any issues?
    2019 Nardo with all OEM options
    Senior Member Two Rings SolarRS3's Avatar
    Jul 09 2018
    2016 KTM Superduke 1290R
    Winnipeg
    I know guys have had problem with mp4s but after contacting tirerack and verifying circumference 255/30 235/35 they said it would be no issue. At the moment i have 225/40 blizzak at 26.1 circumference with no TC issues.
    Nov 06 2017
    Vancouver
    Quote Originally Posted by SolarRS3 View Post
    It’s not the diamter itself the problem, it’s the difference front and rear. 255/30R19 is definitely shorter than 235/35 in pretty much all cases, by about 1/2”. The easy way around it is to run with the TC in sport most of them time or you could possibly even go to a 265/30 in the front.
    Veteran Member Three Rings javbomb's Avatar
    May 11 2013
    Sydney
    I swapped my staggered tyres to Michelin PS4S 245/35 squared and the car has never been better.
    This definitely has less issues than the factory Pirellis for me. I used to have the TC light blinking all the damn time even from the first month of ownership. Straight line 50km/hr in 3rd and it would blink at art throttle. Much, much better now. My car hated the OE staggered tyres.
    C7.5 S6 | Black | Stage II IE ECU/TCU
    Apr 20 2018
    Chicago
    Quote Originally Posted by javbomb View Post
    Odd, when I'm in Sport mode and on staggered with stage 1+ tune I rarely get a traction light. Certainly not in 3rd gear. Not saying stock tires are great, but very strange you are get lights blinking in 3rd gear at part throttle.
    May 11 2013
    Sydney
    Quote Originally Posted by r26372 View Post
    Yeah it's a classic case of something completely other than a real traction issue. Its much more something like rolling diameter.
    Stage 1+ myself now, and same conditions the car will pull properly for the most part.
    Mar 29 2018
    NE Ohio
    Question on the 245/35's - are you using these on the stock staggered wheels? Was wondering if the 245 is a bit of a stretch for the rear 8.0 width.
    2023 RS3
    Dec 05 2010
    Los Angeles, CA
    Arened the wheels the same? I thought the difference was only in the tires. Also, does Audi alter the suspension for the staggered configuration?
    May 11 2013
    Sydney
    Quote Originally Posted by CW98 View Post
    Yes and no issue at all.
    Senior Member Two Rings TK42ONE's Avatar
    Jul 16 2017
    DFW, Texas
    I’m runnning 265/35r18 front and 245/40r18 rear with no issues. They .4” different in diameter or 1.6%
    Current: 2018 RS3 Florett Silver, Dynamic Pkg, Blk Optics, RS Design, Tech Pkg, PPF (partial),
    EMD lowering springs, 034 rear sway bar, Rse52 18" x 9" 265/30/18F 245/35/18R
    UNI Stg 2 ECU / TCU
    Fuel-IT Sensor
    APR FMIC, Turbo Inlet Pipe and CAI
    Insta: @12453_rs
    Best 1/4 10.983 127.7 MPH
    Mar 29 2018
    NE Ohio
    Quote Originally Posted by BzzzBom View Post
    If you have the Dynamic package with the 255 front tires, the front wheels are 8.5 width to accommodate and rears 8.0.
    - - - Updated - - -
    Good to know, thanks.
    2023 RS3
    Senior Member Three Rings Canvasoso's Avatar
    Aug 25 2012
    Atlanta
    Are you using the stock wheels?
    Never mind, just saw someone else asked the same. I may go with this setup. I currently have the PS4's with the stock staggered sizes and I have to drive in sport mode all the time or the TC light would come up constantly on my Uni Stage 1+. I also get some weird vibrations during certain torque accelerations and the car pulling to one side when letting off the gas after acelerating, I'm guessing quattro trying to correct some variation on rolling diameter that may be computing and feels like all of the sudden getting hit by a side wind.
    Do you have pictures that you could share of your square tire setup on the stock staggered wheels?
    Current: 2018 RS3 / Dynamic / Technology / Carbon / 7HE / Daytona Gray / Alu Optics
    Previous: 2013 B8.5 S4 - 1998 B5 A4 1.8TM - 2002 B6 A4 2.0TM - 2006 B7 A4 2.0TQM
    May 11 2013
    Sydney
    Quote Originally Posted by Canvasoso View Post
    You will still get TC intervention due to tune, but only on WOT for me. I DONT get it in a straight line at ridiculously low speed part throttle on smooth road anymore, so I would almost say TC is now working as intended since the rolling diameters are finally properly matched (my theory). So if I am going to drive hard, I will still use TC Sport. I absolutely dont get any strange quattro crap you just mentioned though.
    Here are pics
    This is 10 Front / 10 Rear Spacers
    Aug 25 2012
    Atlanta
    Here are pics
    Thanks for the pics. That looks great. It actually looks very similar to the stock Pirelli's where the fronts had a bit of a stretched loo compared to the rears. I'll go this route when the time comes to change my staggered PS4's.
    Jul 13 2018
    Winnipeg, MB, Canada
    Certainly the 245/35/19 size at all 4 corners looks more natural. It doesn't look like the front wheels are riding on a rubber band, and the wheel well is properly filled up.
    2018 Audi RS3 - Ara Blue, Black Optics
    2019 Audi SQ5 - Manhattan Grey, Black Optics
    Jan 12 2010
    2018 Nardo RS3
    Lancaster, SC
    Happens to me a lot.....staggered with Contis. Have about 1k miles on the Contis. I may mess with pressures a bit....mainly drop them from the 44/39 they are currently at.
    2018 Nardo RS3
    2018 Glacier White RS3 (Totaled RIP)
    2013 Ibis TT-RS APR Stage 2+
    2012 A4 2.0T White S-Line
    2011 E90 Alpine white M3 Sedan (SOLD)
    2008 Ibis RS4 (RIP)
    2010 Meteor Grey Q5 S-Line Wifey's car (sold)
    Nov 15 2017
    FL
    I had the traction interference issue with the OEM tires/staggered wheels in 3rd at times as well when traction couldn't have been an issue. I just always drove with ESC full off.
    Dec 05 2010
    Los Angeles, CA
    Is ANYONE happy or at least content with OEM staggered Perelli tires?
    Established Member Two Rings besttom's Avatar
    Oct 29 2017
    Palos Verdes
    Mine are shot… I'm at 13k miles and can't get a straight answer on what to replace them with… I want to go PS4S, but hear all the traction control issues
    2018 RS3
    2015 A4
    2009 A4 Avant
    2006 A4
    2002 A4
    Jun 26 2018
    CA
    Do you think a 245/40 would be too large squared?
    Senior Member Two Rings whitewaterguy87's Avatar
    Dec 12 2018
    A badass Scooter! I've had an 05, STI & 1998, 3000GT VR-4
    Northwest
    I see a lot of people going PS4S, Would a Pilot Sport Cup 2 be a better option with the better grip?
    Nov 06 2017
    Vancouver
    Quote Originally Posted by whitewaterguy87 View Post
    For street driving, no
    Dec 12 2018
    Northwest
    I thought the newer Corvette Zo6 comes OEM but I really don't know much at all with tires and set-up!
    Nov 06 2017
    Vancouver
    Lots of cars that will/should see track time have them. Compared to a normal summer tire they will offer more dry grip but less wet grip and also last half as long, and make a lot more noise. Plus if you are exceeding the limits of regular summer tires on the street you are driving like a maniac.
    Dec 12 2018
    Northwest
    I see what your saying! What about drag racing or really good 0-60, on stage 2 and up cars? Will the Michelin PS4S still be a great all purpose tire or should someone with those plans getting a set just for the drag strip? I know YouTube can be very misleading but it looks as if some people are running Hoosier Drag radials as DD?
    What kind of mileage difference are we talking about with Drag radials vs something like the PS4S
    Nov 06 2017
    Vancouver
    Drag strip use only, better off to get a second set of wheels with drag radials. It will be cheaper in the end by not wearing your sticky tires on the street, and it will also perform better.
    Junior Member One Ring
    Mar 12 2019
    PA
    Hi all:
    I went from the staggered setup to a square 245/35/19 on stock wheels (8.5” W on front, 8” W on rear). Love the restored AWD balanced feedback from the steering. One thing I noticed is when driving to a slow roll, the transmission does not shift into first gear until the lesser end of 4 mph. I will pull form this speed in second gear with a slight vibration as if a manual car was at a low speed in a high gear. Any way to fix this? Hard reset?
    Also - When I’m in manual mode and driving more spiritedly, the car shifts into gears with more of “drop in gear” feedback, rather than the old, smooth punch it had before the tires were switched. Is this a calibration issue with the transmission?
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    I’m wondering about tire sizes as well.
    I’d like to still run staggered set up, but do a little more meaty tire front and rear in the same proportions.
    I’m going to run 11mm spacers at all 4 corners I believe to go with it. I like an aggressive flush look.
    Thoughts on what would work best?
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
