Results 1 to 9 of 9
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    No turn signals, horn, wipers, windows dont work - Please help!!
    Good morning all,
    I did some research as quickly as I could since the issues just happened this morning and it could be the ignition switch or bad battery (new battery installed little over a year ago, so I sincerely doubt that it is the battery unless the alternator is going bad, will have it tested at lunch). This is on a 2003 A4 1.8t FWD.
    Unlocked the car normally this morning with the fob (fob stopped working after all of this happened - does not lock or unlock)
    Additional controls not working:
    turn signals, horn, high beams, windshield wipers, windows, the radio stays on once I turn of the car
    No water under the battery and as much as I could see no water under the ECU, however the carpet where the gas pedal is slightly wet.
    Low beams and fog lights work.
    Forgot to mention, the ABS and Traction control light turned on as well.
    Please point me in the right directions if you can. Your help is greatly appreciated.
    Z
    Zlaja
    Jan 24 2010
    Paramus,NJ USA
    Sounds like a bad J519 or a flooded J393.I would pull the carpet up on the driver front see if you have water in there.Chances are yes if you saw water.My guess is water intrusion into vehicle from ebox cover.Most liekly burned up J393.
    Ziddy Autowerks
    Jun 09 2016
    u.k
    I ended up scrapping the car when this happened but I found the part in the steering column could have been the culprit. The part that the wiper stalk etc plug into.
    This is the part here but you must match part numbers.
    https://rover.ebay.com/rover/0/0/0?m...2F323490766444
    I wish our had found that out before scrapping the car as it was a quattro now I'm stuck with a fwd
    I lost high beam, wipers, headlight flash, driver information system, indicators, radio playing up, it affected so many things.
    I hope you get it sorted
    Sent from my ANE-LX1 using Tapatalk
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    Hey guys, my comfort control module got fried due to the water leak. It is currently being fixed. Where could this water be coming from. I try to keep my two drains in the front clear of debris. The car does not have a sun roof. Is there another place where the water could be leaking into the cabin and causing this? Thanks for all of your help!
    Zlaja
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Usually it is from a clogged drain underneath the brake booster. It can also leak in from the back side of the ECM box, but that generally causes a multitude of other issues as well as a wet floor.
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    Thanks so much for your help. When you say multitude of other issues, what kind of issues are we talking about. Shop just called me after installing a new CCM and having it programmed at the Audi dealership, stating that the blinkers were still not working and that the hazard lights were on constantly, which of course drained the battery while at the Audi dealership. Very frustrated with this issue.
    Thanks again for your help.
    Zlaja
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by zlaja80 View Post
    You need to replace your CECM (Central Electric Control Module). The CECM controls the outside lights and wipers. It is located underneath the dash above the drivers legs. The CCM controls the remote door locks, door control modules and interior floor well lighting and puddle lights.
    When water leaks under the dash it can get on the CECM as it drips down to the carpet.
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    Thank you so much for your help!
    Zlaja
    Junior Member Two Rings
    Apr 18 2012
    Toms River NJ
    does anyone actually have a wiring pin out for b7 3 cecm plugs???? been trying to chase a few burnt wires from rain getting in from the ecu box
    haven't found one in the 2 weeks I've been looking and the Haynes manual just says colors it doesn't tell me what pin goes to what spot on the plug
