Results 1 to 17 of 17
    Jan 03 2019
    Advice on 20 inch rims
    Hi everyone,
    Pretty new to getting after market rims so just wanted some advice. I have a 2019 s5 sportback, looking to get 20/10.5 with 27 or 35 offset. And for tires looking at 285/30/20. My question is will this set up work? Don’t want too much rubbing or for it to cause any issues and will this give me an aggressive wider look?
    Appreciate the help! Thanks
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Shouldn't be a problem to do a 20X10.5 ET30 on 275/30 tires. Here's an example of one on Vossen HF-2 Wheels:
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Senior Member Three Rings zoomzoom!'s Avatar
    May 28 2016
    2015 Q5 3.0T (Wife), 2000 GMC Sierra
    Richmond, VA
    Quote Originally Posted by Stanler.c View Post
    Hi everyone,
    You didn't stipulate if you were planning to ALSO lower the car, so if on stock springs, you have lots of room. We were blessed with a ton of stock wheel gap, yay! lol
    __________________
    Richmond, VA
    2018 S5 Daytona Cabrio
    2015 Q5 Ibis (Wife)
    SOLD: 2013 A6 3.0T
    Jan 03 2019
    Quote Originally Posted by zoomzoom! View Post
    Thanks for the input. Im probably going to end up lowering the car.
    What are your opinions on staggered? I originally wanted to go bigger tires in the rear, like 305s, but might just go with 285 all around
    - - - Updated - - -
    Quote Originally Posted by RLB6 View Post
    Thanks for your input! What’s your opinion on staggered wheels? Wanted to go 305’s in the rear
    May 28 2016
    Richmond, VA
    err....from memory, I think staggered on quattro is not recommended. Hopefully one of our wheels gurus/vendors will chime in.
    __________________
    Richmond, VA
    2015 Q5 Ibis (Wife)
    SOLD: 2013 A6 3.0T
    Registered Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Running staggered isn't recommended for quattro but if one does it, the overall diameter of the tires should be less than 1% different, ideally the same. So if you really want to run a 305 then it should be a 325/25R20 with a 255/30R20 up front. These would provide an OD of 26", same as OE.
    For a S5, a 275/30R20 is really the max I'd recommend with it being 1.8% bigger than the stock 255/35R19. The Vossen pictured above are really a great spec. A bit of stretch if not lowered but once lowered provide a great fit. For non lowered, doing a 20x10" ET30 with a 275/30R20 is a great fit.
    Jan 03 2019
    Quote Originally Posted by Jimminez@Nemesis View Post
    Thank you so much for your input! I’m planning on getting the niche gamma m190 and the option for 20s are 20/10.5 with et of either 27 or 38. Which offset would you recommend?
    With 10.5s do you think I need to go to 285/35 tires or will 285/30 be fine ?
    May 16 2007
    Ottawa CA / DE USA
    ET27 but they will stick past fenders when not lowered, less so when lowered. I'd recommend 275/30R20 vs 285/30R20. Definitely not 285/35R20.
    Jan 03 2019
    May I ask why you recommend the 275 over the 285?
    May 16 2007
    Ottawa CA / DE USA
    Closer to overall diameter of the original tire. You want to stay within 3% at most. 285 would be around 2.8%.
    Why are you leaning towards 285?
    Jan 03 2019
    I was leaning toward 285 because I like the wide look, 285 would look wider than 275s correct? Sorry lots of questions, pretty new to this
    May 16 2007
    Ottawa CA / DE USA
    Yes but will also proved a different steering feel vs stock. Will feel more weighted plus added weight.
    Not trying to dissuade you. Just want you to be aware of the sides. I’m going with a 285/30R20 on 20x10” but the OE are 275/30, so a minor difference.
    This is what a 275/30R20 on 20x10” ET30 looks like on a stock height S5 Sportback.
    @TEKNIKA has 285/30R20 on 20x10.5” for reference on how that tire sits but he has wider fenders so more room.
    Jan 03 2019
    I see thanks so much for your input. I appreciate it!
    I think I’ll go with the 275’s. It still looks pretty wide so I’d rather not sAcrifice ride quality or take on the extra weight if it’s noticeable.
    May 16 2007
    Ottawa CA / DE USA
    No problem. Just remember, the picture I posted is of a 275/30R20 on 20x10” not a 20x10.5”. If you go with 10.5” and 275, you’ll have more of a stretched look.
    Jul 10 2014
    United States
    I previously had 14 s7 and got the velos d5 21" 10.5 with et 33. I still have wheels and was wondering if anyone has run a 21" setup? Checking with will it fit.com i would need a 295/25r21 to be close to stock diameter. Anyone have thoughts on this?
    Dec 21 2018
    WarnerJedXL
    Panama
    A 185/80R13 is about as large of a 13 you can go. They fit too. With a 14 inch wheel tyre combo I believe 195/65r14 is about the biggest you can go on the standard offset aftermarket rims without modifying guards.
    Stage 2 Banner Advertiser Four Rings Alex@TAG's Avatar
    Nov 15 2011
    ABT RS5-R, SQ5, 488 Pista
    San Diego, CA
    So i highly suggest not staggering the wheels on the car. What we can do i go ahead and do a wheel with a staggered conical profile. Much like the images you see above of our TAG S5 Sportback.
    There are tons of different options. Especially if you're going to lower it, it can certainly be easily done without any issue :)
    Check out our gallery for some inspiration on cars we have done in the past - and feel free to give us a call, or shoot us an email to [email protected] for more insight.
    https://tagmotorsports.com/gallery/audi.html
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    AUTHORIZED DEALER: HRE Wheels || FlowForm || Vossen || ABT || TechArt || AWE Tuning || APR || KW Suspension || Milltek || BBS || Brembo || Michelin & more!
