Results 1 to 21 of 21
    Jan 05 2019
    New York
    2002 Audi A4 B6 1.8t No Response from OBD2
    My 2002 Audi A4 B6 1.8T does not respond to any obd2 scanner and I have no clue what it could be. Their is a stage 2 ecu in it and the airbag light flashes but I had no problems with it until now. The car runs and drives perfectly fine, I started with the broken radio and fixed it, nothing happened. Then I pulled the abs harness nothing happened. Now I’m just lost.
    Senior Member Three Rings A4-Mike's Avatar
    Jun 12 2016
    Melbourne, Australia
    I have the same car same problem the only ones that read it are OBDELEVEN or Rosstech
    Sent from my H8216 using Tapatalk
    Jan 05 2019
    New York
    I can’t even get my car inspected because of this problem and I can’t try another ecu because of the immobilizer unless i get it tuned. Maybe something tripped in the ecu code. I just need ideas, anything would help. Thank you
    Jun 12 2016
    I bought the OBDeleven and haven't had a problem with it reading and adjusting settings in my ecu.
    Jan 05 2019
    New York
    I can try the rosstech scanner from one of my friends but the inspection part is where I’m stucK because the scanners they use doesn’t pick up anything.
    Jun 12 2016
    Quote Originally Posted by RC490 View Post
    Oh Wow sounds like they need new scanners, I'm Australian and the state I LI e in you just get a Roadworthy Certificate when you buy the car and that's it no yearly inspections.
    I really do feel sorry for all the bullshit you guys have to go through just to have a car on the road were as I can modd the shit out of it and not have any hassle.
    May 22 2012
    Estonia
    You should use VAG compatible scanner to read abs, airbag etc. modules. Rosstech of course is the best. Basic obd2 scanner can only read your engine module. With no connection seems that there's no response from K-line. It's located on pin 7 (green/red wire) in DLC. At first i would check fuses 12 and 31 in fuse panel. Those two give power to DLC. From fuse 12 to pin 16(DLC) and from fuse 31 to pin1(DLC). If there's no feed, you can't get connection.
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    They're not scared of you. They're scared of what you represent to 'em.
    Jan 05 2019
    New York
    I appreciate all this info, if you guys have any other ideas let me know. I’m gonna try all this tomorrow. I’ll keep you updated
    Jan 05 2019
    New York
    Tested the k line off the radio and that’s fine. Change the MAF sensor, even tho that has nothing to do with it I’ll just add it in. I ripped out the ac and compressor along with the whole harness. Still getting no response.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    find someone local with rosstech cable and see if it can do a scan and read. if it does...find another inspection shop. if it cant read your ecu make sure nothing shorted and fried it. i had my maf wiring melt and the wires touched and shorted my ECU. had to buy a replacement ecu and have the immobilizer defeated. it could be the shops scanner. most smog shops use shitty cheap obd2 scanners and they dont take care of them at all.
    Audi Club Bay Area
    Senior Member Two Rings asg1290's Avatar
    Dec 04 2010
    San Francisco, CA
    Check your fuses. I had a bad fuse cause this for me.
    2004 A4 Avant 1.8T 6MT
    2006 A4 Avant 2.0T 6MT
    May 22 2012
    Estonia
    How you tested K-line? You can rip whole car apart thinking "maybe this" with zero effect. B6 is smart enough to tell you what is wrong with her. You only have to ask correctly. Like Google. If you can't get any connection or response from any module with Rosstech, then at first i would check if pin 16 on DLC get +12v as shown on Gin+ posted picture.
    Jan 24 2010
    Paramus,NJ USA
    Do you have a aftermarket radio installed??I've seen aftermarket radio do weird things in these cars.Other than that all you need is power and ground at obdII connector and Kline.as long as you have all those your good.
    Or install a ecu that has its immobilizer defeated or clone the existing immobilizer.Also what kind of tune do you have??Some tuners disable reading of ecu over OBD but this is usually not a problem when checking faults.
    Ziddy Autowerks
    Jan 05 2019
    New York
    Currently I’m checking the ccm under the driver side seat, I’m at the what if game. I do have a reflet tuning stage 2 tune but didn’t have problems at all with a cheap code reader until recently. I have the stock radio in and I just recently fixed it with no luck afterwards. It’s just what if’s. About to kick the car to the curb.
    Jan 24 2010
    Paramus,NJ USA
    Well I will say this if a cheap obd scanner can talk to it you shouldnt have a problem.Maybe the issue is with their hardware??There is a fuse for the OBDII connector on the side of the dash.Check make sure its not blown.
    Ziddy Autowerks
    Jan 05 2019
    New York
    The obd gets power but no response
    Jan 05 2019
    New York
    It was the ccm
    Dec 08 2018
    South Yorkshire, UK
    Hi RC490,
    Did you replace the CCM with the same part number or did you upgrade it to a newer part number?
    Larhal
    Larry
    2002 A4 B6 1.8T
    Tuned Stage 1, BSR exaust, RS4 rear sway bar, A4 B7 320mm Brembo disks, calipers, SS brake Lines, B7 wiper arms and blades, Valeo HD SMFW Clutch.
    Jan 05 2019
    New York
    I used one from a 2003 A4 and everything works like it’s supposed to and the OBD2 port gives me codes now. It was the last thing I check due to the extent to get to the box.
    Dec 08 2018
    South Yorkshire, UK
    Thanks for the information. DO your key remotes still work?
    Larry
    2002 A4 B6 1.8T
