Results 1 to 32 of 32
    Junior Member Two Rings
    Apr 25 2016
    Dallas TX USA
    Semi-Dynamic Turn Signal Indicator LED Taillight modules
    Got dynamic Turn Signal Indicator LED Taillight module from e-bay. Tried it on inner lights with same result as for the outer. It was not easy to get access to inner light connector. Tried both modules (in case one was defective), tried adjusting timing with the screw on both modules. same result. No dynamic effect, they just repeat. Good outcome - did not brake anything, learned how to remove inner light assembly on a trunk. Can someone provide solution that worked on US models and is below $100? After all it's just a delay module.
    Veteran Member Three Rings SeattleiteA6's Avatar
    May 08 2015
    I've contended that these were not made for our lights, coding or not - our tail light configuration is different internally from the ecode ones, as well as the plugs being different (which can easily be hacked to fit).
    Even if they did work it would look weird wouldn't it? You'd have a rectangle shaped light with a 'sweep' effect, not a single line on the top sweeping for the blinker with a separated brake. You need the ecode light configuration for the delay module to work as intended - I used it on my old RS5 with OEM ecode tails and it was pretty cool.
    Europrice sells the OEM C7 ecodes for like $1200, could probably get an eBay set for $600. Not sure about C7.5 options. I and a few other members went with an eBay/AliExpress facelift styled version for ~$700 that are ecode and dynamic (true sweeping).
    2014 Phantom S6/B&O/Innov/BlkOptx
    Pixel 2 XL using Tapatalk
    2014 S6 Phantom w Black Int & Carbon Atlas//B&O//Innovation//Black Optics//RS front clip//E-code Dynamic Tails//Carbon Diffuser w carbon tips//VCDS -15mm//Straight Pipes//JB4
    2018 Q7 Night Black w Black Int//Technik Trim (CAN origin)//Luxury Pkg//Black Optics//Adaptive Air//euro tails and other mods forthcoming...
    2013 Q7 3.0T Prestige S-Line Plus
    2013 RS5 Ibis w Black Int//e-code tails//20" HRE FF01
    2012 A6 3.0T Prestige//Sport Pkg
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    ive been looking for c7 euro tails and its so hard to find. post a link if you guys find one.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    May 08 2015
    https://europrice.us/taillight-packages-a6-s6-rs6-led
    May 10 2013
    Toronto,ON
    Quote Originally Posted by SeattleiteA6 View Post
    i was thinking more along the line of a used set off ebay. lol
    May 08 2015
    Quote Originally Posted by ichi d View Post
    Oh haha! If you go with an oem set from ebay you'll need a wiring harness from Alex@Europrice I think, he can confirm though. I think the pins in the connectors are different so they won't work out of the box. Needs coding too but that would be easy with vagcom.
    I had a '12 A6 5 years ago and did a ton of research as I've always thought the NA tails were pretty lame with the big red rectangle brake/blinker.
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    Quote Originally Posted by zhuk1 View Post
    My seller is shipping me new ones that they SWEAR will work with the USA lights..plugs, functionality and all. I am not holding my breath but will give them the benefit of doubt. Will update whenever they get here and I have had a chance to test them out. Tails will be the last thing I mod on this car for more than what I paid for these modules (if they ever work). I am not interested in the$500-$1000+ options out there as its just not that serious.
    Senior Member Two Rings 36dbldz's Avatar
    Dec 15 2018
    Escalade ESV, Audi A7
    North Florida
    let us know.i think we have same ebay seller
    May 10 2013
    Toronto,ON
    I'm certain they won't work on Na spec tails. Only because u cant even code the tails to flash like the euro ones. Its just not possible without changing some wires around.
    Dec 11 2017
    DFW
    Cool well onus is on them (seller) to provide me with a working product or a refund. I have a paper trail asking them to confirm it will work with USA models and they swore up and down this new batch will. Breath not held.
    May 08 2015
    Quote Originally Posted by digdah View Post
    They might 'work' so to speak, but not as intended. As @ichid notes above, you can't code the tails to flash like the euro ones, so these delay modules will delay the entire brake&blinker segment - will look odd IMO but I'm definitely interested to see how they look when installed. Post pics when you get them in!
    Dec 15 2018
    North Florida
    I got another set getting shipped next week from the seller
    Sent from my SM-T820 using Audizine mobile app
    Dec 15 2018
    North Florida
    They did mention it blinks inwards not outwards too
    May 08 2015
    Quote Originally Posted by 36dbldz View Post
    Huh? Blinks inwards, like opposite the direction you're turning?? Do you have a link to a video of their function on a C7, so curious now
    Dec 11 2017
    DFW
    I'm thinking he is refering to what gets adjusted timewise. I thought it was the outer unit that was being adjusted but goes to show how much I know. Lets see how this works out.
    Dec 15 2018
    North Florida
    This is the video they sent me. I'm not sure how the adjustment goes but we will find out soon. The module is for inner light
    https://youtu.be/AAiKOyjIgi8
    Sent from my Pixel 3 XL using Audizine mobile app
    May 08 2015
    yeah that looks ridiculous IMO - it's sweeping the opposite direction that you're turning! Also, for all of the US guys who want this look it won't be possible unless you get the Europrice ecode tail light kit. Seems like a total bust for US cars with stock lights unfortunately
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    Ticket or Accident waiting to happen, don't do it imo.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Woah, those semi-dynamic modules are not installed properly, yikes!
    Also North American models would not be able to use semi-dynamic modules safely since the turn and brake are combined. Rest of World pre-facelift models can use the semi-dynamic modules but they should two step outwards, not inwards:
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Dec 11 2017
    DFW
    When they said it should go o the inner light I was yeah right. That video they sent you confirms they are stupid. The outer light should be delayed for the desired effect. I have very little faith that this next module wile either connect or slow down my OUTER
    Dec 11 2017
    DFW
    https://youtu.be/F5zWD_94A-g
    This is the look I am expecting
    Dec 11 2017
    DFW
    That's what it should look like
    Dec 15 2018
    North Florida
    I'm trying to cancel the replacement.
    Dec 11 2017
    DFW
    I should do the same with mine.
    Nov 27 2008
    New Jerz
    That actually looks pretty good. if i didn't have the europrice lights and they made this module for the C7.5 i'd rock it.
    Dec 15 2018
    North Florida
    That was the look we were trying to do with the module
    Sent from my ONEPLUS A6003 using Audizine mobile app
    May 10 2013
    Toronto,ON
    its never going to happen. like i said na spec cars arent able to code the turn signal with just the top strip. i been trying to just code them like the euro lights and it wont work.
    Aug 07 2008
    Dallas, TX
    For North American models to use the A6, S6 semi-dynamic modules the car should be converted to Rest of World spec pre-facelift taillights. The cost to do that and add semi-dynamic modules starts to creep up to fitting the post-facelift lights, though with A6, S6 pre-facelift sedan you do have the small hurdle of adding little spacers or building the bumper up on the outer lights to fill the small gap the post-facelift taillights leave.
    Cheers,
    www.europrice.us
    [email protected]
    Dec 15 2018
    North Florida
    Quote Originally Posted by [email protected] View Post
    Cheers,
    That the same for A7
    Aug 07 2008
    Dallas, TX
    Correct. Though the A7, S7, RS7 have a 100% direct fit with the post-facelift taillights which makes for an even easier fitment and decision. Post-facelift dynamic taillights FTW
    Cheers!
    www.europrice.us
    [email protected]
    Dec 11 2017
    DFW
    So the new ones came in and, as everyone predicted, they don't work. Now I will say they are a MUCH improved product in terms of size but that does not stop them from being utterly useless for us. I have my light coded a little differently and what I found weird was with my non-standard coding the side marker was exhibiting the delay but not the outer lights. You can see this in the video below were the left side had he module affecting the side marker and the right side didn't so was blinking as standard (per my desired coding that is).
    On a side note the good news is my dynamic turns in the mirrors are still chugging away like champs - for now.
    Dec 15 2018
    North Florida
    Kinda works tho.
