Results 1 to 15 of 15
    Junior Member One Ring
    Aug 11 2010
    Connecticut
    Retrofit MMI from B8.5 to B8 S4
    I am contemplating the purchase of a 2012 B8 S4, Prestige, Black Optic, Sport Diff 48K. I would really like the AD2P MMI functionality of the B8.5+ MMI systems. Has this retrofit been done by anyone else here? I have read https://www.audizine.com/forum/showt...-RS5-to-MMI-3G and https://www.audizine.com/forum/showt...ection-removed and wanted to make sure that I wasn't missing anything.
    Thanks for the help.
    Apr 20 2011
    Hackettstown, NJ
    I have done the b8.5 mmi swap into my b8. It's super easy if the car is already equipped with nav. You only need the MMI unit and the center console controls. 100% worth it imo
    2009 Brilliant Black A4 Avant Prestige 2010 S4 Prestige 6MT Swapped - SOLD
    2012 Nogaro Blue A4 Avant Prestige
    2009 Condor Gray A6 Avant Prestige - On daily duty. 240k miles and counting.
    2018 Glacier White RS3 Unitronic Stg 2 ECU / TCU
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    Just upgrade to RSNAV instead. You’ll get carplay or android auto and bigger screens of your choice.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    You may want to look into this https://rsnav.com/products/10-25-and...-q5-sq5-3g-mmi
    I will eventually buy the top and pair it with this https://www.turbozentrum.de/FIS-Cont...ad-Description to cover all of the p3 gauges.
    Here are some threads to get you started, if this option interests you:
    https://www.audizine.com/forum/showt...(RSNAV)/page57
    https://www.audizine.com/forum/showt...9#post13224869
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by raudiace4 View Post
    +1 here.
    I just upgraded from B&O Symphony to B&O 3g+ nav and all that shit. If you like to tinker and like OEM stuff, go for it. I will say, though, that my sound is intermittent so I’m waiting on my second MMI head unit in hopes that fixes it.
    You must like three things for this mod.
    1) spending money
    2) removing interior trim pieces
    3) fishing for info on AZ because it is NOT all in one place
    If I were to do it again I’d go RSNAV but I bought the OEM stuff before I knew it existed.
    I also installed backup camera A++++++ on this mod
    Jan 20 2017
    RS7
    New Hampshire
    Just went through the RSNAV thread and read mention that it’s not being sold for B8 anymore , but it’s on the website. Trying to figure that one out.
    Junior Member Two Rings
    Jul 21 2008
    Minneapols, mn
    Previous owner did this mod to my car. Works perfectly. Only issue I have is a sketchy volume knob, which is not an issue with the conversion. Deciding if I want to replace the mini controls to fix it.
    Jesse
    Aug 11 2010
    Connecticut
    So the consensus seems to be to retrofit the RSNAV unit in place of the upgraded 3G MMI+? I assume that i will be able to use the factory backup camera and its plug and play?
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by captnops View Post
    It is up to you, if your b8 has mmi not concert, swap to 3g+ is very easy. RSNAV is either carplay or android device(2 different units). It all depends what you need/want etc, regardless you can use your factory camera...
    Edit: if all you want is bt stream, then cheapest is get ebay adapter for 20 and connect it to ami plug, which probably your car has(not a fact)!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jan 20 2017
    RS7
    New Hampshire
    Check the RSNAV thread. The gist I got was that sound in the B8’s wasn’t great.
    Aug 11 2010
    Connecticut
    I have been reading through the RSNAV threads that I found and I confess that I am not seeing the benefits. The cost is somewhat cheaper than going to 3g MMI+, but given the issues surrounding updates etc, what are the real or perceived benefits? Apple CarPlay or Android Auto? I am certain that I am missing something, but all info is greatly appreciated.
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Super easy -- took longer to run the GSM antenna cable from the back than to swap out the MMI unit and console controls. You can find the components on eBay relatively cheap. I believe the 8R1 035 746 F and onward (G, H, etc.) has the antenna that also supports AT&T 3G. I have the G model and am able to get 3G on both T-Mobile and AT&T. Good luck!
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by auditd0rk View Post
    From B8.5 MMI to B8 MMI controls, completely agree. I read B8.5 MMI to B8 without MMI - this is MUCH MORE complex.
    Apr 07 2012
    PA
    Quote Originally Posted by Ford Prefect View Post
    How about from B8.5 non MMI (Symphony) to MMI?
    I don't mind not having Nav... just wonder have the MMI center consoles, MMI radio CD player etc.
    Jul 16 2018
    Atlanta
    MOST bus infotainment systems (MMI 2G/3G/3G+) use an optical cabling infrastructure, unlike the CAN bus infotainment systems (Chorus/Concert/Symphony).
    So you'll have a different dash unit (J794 instead of Symphony), a different J533 that supports optical connection, an additional radio unit as it's outboard for MMI, different AMI connection if you have that in the glove box, and running optical cabling from the front to the rear, new center console controls frame, etc. It's also been documented in threads before. Look for MMI 3G retrofit threads.
