I'm asking because I continue to throw the following code for PCV valve (even though the dealer claimed to have replaced it, but definitely not done since the supercharger was not removed). From everything I've read, that is required to change the PCV. Setting up another appointment tomorrow, but wanted to try to have as much info as I can get before calling. Here's the code I throw... appreciate any info you can give. If someone can just try it and see, would be appreciated... just don't want to tell the dealer it's pulling strong crankcase vacuum if it supposed to be.
1 Fault Found:
20136 - PCV Valve Malfunction
P052E 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 77734 km
Date: 2018.12.31
Time: 11:40:24
Engine speed: 701.00 /min
Normed load value: 12.2 %
Vehicle speed: 0 km/h
Coolant temperature: 71 °C
Intake air temperature: 19 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.624 V
Unlearning counter according OBD: 38
Engine speed: actual: 704 /min
MAF_ENVD: 119.83529 mg/stroke
Coolant temperature (unfiltered): 71.25 °C
Engine: operating status: IS
Engine load: 12.109375 %
Vehicle speed: actual: 0 km/h
