Originally Posted by
OlyS6
Are you turning off ESC? If that’s turned off, then you should be able to use launch control- I’d be impressed if the prior owner launched it 200 times (the current max). If you have a VAGCOM cable, you can check the launch counter to be sure. An APR tine can remove the max limit on launch control as well. As far as your question goes, the conventional wisdom is that brake-torquing as you describe is actually easier on the transmission than using launch control anyway.
Ive had the car for over 2 years and know it inside and out. From the very beginning, I have never had launch control. I even had the boys at RocEuro try it when it was there getting some work done and no dice. I never checked the count via VAGCOM (I dont have it), but the car came tuned and with an intake so I suspect the previous owner was a modder and drove it hard. The car is a 2013, I bought it October of 2016 with 37k and it now has 58k. I suspect the owner used the launches up in that 37k miles.
I know I can get it reflashed and up the launch counter, I just was looking for opinions to using this method and if it was relatively safe to do so.
