Originally Posted by
Moisealx
Hello,
Is here someone who had the following error:
Help?!
5940 - Exhaust Pressure Control Valve
P0475 00 [237] - Electrical Malfunction
5923 - Exhaust Pressure Control Valve
P047F 00 [237] - Stuck Open
The only problem I saw is that for a ride of 1400 km, consumption was 9.7l / 100 km.
Please help!!!
The flap will be seized of sticking, its located after the nox cat.
If you raise the car no ignition on you will see the flap in the middle of the exhaust, if you use a screw driver you should be able to pushe the spring loaded lever up and when you let go it should spring closed again if it doesn’t then it needs replaced. If the exhaust flap module does need replacement then I’d call the dealer and see if you have a warranty extension on it if not then two new clamps new new gaskets and a module and you will be on your way
