Results 1 to 18 of 18
    Nov 18 2012
    United States
    Oil leaking on top on engine
    As in photo below, my ‘10 b8 a4 fwd is having oil leaked on top of engine, around mating surface of the valve cover. Engine runs a bit rough on idle and low rpm
    I did have a failed pcv valve earlier that caused low oil pressure.
    I’m thinking my valve cover seal/gasket blown. What do you think?
    TIA
    Feb 15 2016
    Cambridge,Ontario
    it Is very unusual for oil to leak "up" from the gasket into those areas . I would suggest cleaning it all with brake clean and watching carefully. redoing the seal on these cars is a bit of a job as you might know as that top "cover" is the upper cradle and holding the cams down.
    it could be leaking past one of the protrusions for the top plastic cover to lock on to . its a simple o ring in there. .. so clean it up and watch.
    a PCV valve will not cause increased or decreased oil pressure .. but it will cause increased crankcase pressure ( depending how it fails ) which could blow seals , so your concern is valid ...
    Also I really like how clean your engine is .. if you wouldn't mind could you take a pic of directly above your PCV valve ? I replaced mian and I had 9 long bolts with a shoulder and a shorter one with no shoulder. I think I may have mixed the bolt up with the one that holds down the coil pack harness... but I'm just not sure. I was hoping a pic of yours might help.
    Thanks
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    all 10 bolts for the PCV are the same part number
    Feb 15 2016
    Cambridge,Ontario
    thanks smac ... I'm thinking I mixed it up with the one holding down the coil pack harness then .. coz one was way shorter
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    Yeah, PCV bolts are M6x20, coil pack harness bolt is M6x16 combi.
    Established Member Two Rings BoostedJoe's Avatar
    Oct 11 2018
    It’s weird how there’s oil on the top of the valve cover which was a bit different in my case. My valve cover was leaking and was told by the shop that it is common, now mine wasn’t as bad as yours but Im very cautious about things like that so I had it resealed by a very good reputable shop. Here’s a pic of the new sealant they use, it doesn’t use a gasket but some type of silicone. I’d get it resealed before the oil corrodes the plastic water pump.
    [URL=http://s1262.photobucket.com/user/IIXXCVI/media/IMG_4036_zpsebseoupd.jpg.html][/URL
    2013 A4 B8.5 Quattro 2.0T
    | AEM Intake | Forge BOV | 034Motorsport HFC(Gutted) | Resonator Deletes | Eibach Sport Plus Anti-Roll Kit | 19x8.5 Enkei Tuning Raijin | RS4 Grille | Rockford Fosgate T1500-1BDCP | PSI Platform 2 12" (HP-1800w)
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Smac770 View Post
    ah that's it then... the short one is the coil pack bolt. should have figured,,,
    thanks
    1976 Yamaha XS 360
    Senior Member Three Rings Quattro420's Avatar
    Apr 08 2015
    2003 Jetta tdi 5peed 2000 b5 a4 1.8t 5aq, 2005 Passat tdi wagon2.0l, 2000 sierra 5.3l
    Ontario Canada
    Quote Originally Posted by harrybinh View Post
    TIA
    It almost looks like the cam sensor is leaking possibly bad o-ring? Undo the connector for it see if there’s oil in the terminals if so I’d replace the sensor
    Feb 14 2018
    Irving, TX
    I had this problem in the exact same place about 6 months ago. Mine was leaking from the black cover in the bottom pic. I think it covers the chain if not mistaken. At any rate, I decided to just apply high temp gasket sealer along the right edge up to about mid-way. Using your finger you can make it unnoticeable. And.. that did stop the leaking in my case. The gasket was just wearing out so I did a patch job to give it a little extra life.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    I dont understand why people start a thread and then never follow up.
    I'm as cool as a cucumber in a bowl of hot sauce.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by BoostedJoe View Post
    I'd love to know what green sealant they used, never seen one that color before.
    Veteran Member Three Rings Depthcharge's Avatar
    Nov 15 2007
    '21 PS2, '20 SQ5, '14 A4
    DFW, TX
    It's the 'Anaerobic Silicone sealant' D154103A.
    It cures in the absence of oxygen so it will form a seal inbetween the metal of the housings. Some have noted that it doesn't appear to cure where it is pressed out from oxygen. I don't think any extra curing techniques are needed on the sealant that's pressed out but I'm sure there are some creative ways to get it to harden if you're worried about it.
    It's expensive from most shops, but there are alternatives like Permatex and even on ebay.
    Nov 20 2016
    LOL $70 dollars at a discounted rate for 100 grams. Oh audi, you so silly.
    Dec 30 2014
    2013 A4 Prestige, 2013 A6 Prestige, 2001 Range Rover, 2001 BMW 330i
    United States, Show-me state
    I read great things about this Toyota sealant which is a lot cheaper than Audi's.
    I haven't tried it yet but going to use it on oil sump job for my BMW E46.
    https://www.amazon.com/Genuine-Toyot...gateway&sr=8-4
    audi bug --------------------------------------------------------------------------- audi bug
    @ 13 A6 Quattro 3.0L TFSI Prestige Phantom Black - Innovation package, 20" Sport package, LEDs
    @ 13 A4 Quattro 2.0L TFSI Prestige Midnight Blue - Driver Assist package, S-Line package
    @ 06 A6 Quattro 3.2L FSI - traded @185k in 16.
    Apr 30 2018
    Orange County, CA.
    Quote Originally Posted by wesbrown12 View Post
    This! I had oil in the same locations as well and it was coming from my upper timing chain cover (black cover in the pic). Yours appears to be dry in th pic but maybe we can’t see it in the pic.
    I replaced all theee orings/seals:
    1. Upper timing Chain cover gasket
    2. Cam sensor seal
    3. Inner cam sensor oring (this one is important)
    Replacing all three of these seals is a relatively simple job. Good luck!
    Nov 07 2020
    England
    Hi mate, can you tell me which sealer you used and if you have any pictures of where you applied it
    Nov 07 2020
    England
    Anyone managed to fix it
    Feb 15 2016
    Cambridge,Ontario
    just replace the timing cover seal
    1976 Yamaha XS 360
