Hi A4 B8 guys! When having the reliable 2.0 TFSI
engine in your AUDI A4 B8 (Year 04/2013 - 08/2015) with 165KW (225HP) CNCD engine simply double the performance
up to ca. 420HP by adding the PNP LM430 - the VAG Upgrade turbocharger - the first available IS20 Audi Hybrid on the world market. It is manufactured by Ladermanufaktur Germany, who uses the stable original stock housings to keep the original Audi look and all weak stock internals are removed !!! and the famous TD05+ Racing Premium basic unit is used instead. They combine it with a bigger & lighter HighFlow compressor wheel for impressively broad torque range (2500 - 7200 rpm) and a new & highly efficient exhaust wheel for very early turbo spooling.
The combined development is called OptiRate technology and has worked in the PNP LM440, PNP LM500, PNP LM6XX, etc. very successfully so far making tuners happy for its stability, extraordinary performance and reliability. When buying a hybrid - generally make sure you invest in a stable basic unit because the most other turbo builders just re-use the old weak IHI core or use Chinese copies to make fast money but the weak basic units have been responsible for thousands of blown IS38 and IS20 turbochargers worldwide (see all forums). When buying, always keep an eye on a very stable core/basic unit (TD05+, etc.) and very early turbo spooling.
Ask your personal tuners first for hardware needed like a downpipe, etc. to get 420HP. Your tuner who gives the software tune also programs your DSG/S-Tronic, which is able to keep 600NM torque perfectly nowadays with modern software.
Here a video of the LM440 IS20 (Cupra) which has exactly the SAME technology (TD05+, dynamic hiflow wheels, etc.) as the LM430 AUDI:
Here some
more specs and technical details and the photos of the AUDI IS20 PNP LM430:
