Results 1 to 20 of 20
    Dec 25 2018
    Valley Stream
    how to black out chrome on 15 SQ5
    Hi all,
    Does anyone have experience blacking out chrome? Id like to do it to my 15 SQ5 and would appreciate some tips. Is plasti-dip the way the way to go?
    Thanx
    Rey
    Jul 31 2016
    PA
    That's an option to dip it, or you could pick out a vinyl wrap color you like (gloss, matte, etc.) And either DIY or take it to a shop that specializes in that sort of work.
    Sent from my Pixel 3 using Tapatalk
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Dec 25 2018
    Valley Stream
    Quote Originally Posted by djn876 View Post
    Where can I pick up vinyl wrap?
    Established Member Two Rings Blackunicorn's Avatar
    Sep 04 2014
    49 Chevy Truck (Project Abe)
    KS
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by Rey Roc View Post
    They have all the tools you'll need to wrap the chrome pieces.
    https://www.metrorestyling.com/default.asp
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Veteran Member Three Rings hellovaras's Avatar
    Oct 28 2018
    PNW
    I did plasti dip on my camry. You will need 6 or more coats. The vinyl on the car was not super paint friendly. However, it did turn out well after the coats. Also, inexpensive compared to other options. FWIW
    Hi all,
    Thanx
    Rey
    Sent from my Pixel 2 XL using Tapatalk
    2013 Monsoon Grey B8.5 S4 6MT | ECS CF Wing | ECS CF Front Lip | Canyon Run-15 Strut Brace | ECS Front Strut Tower Bar | Injen CAI | ECS Center X-Pipe | 034 Motorsports Rear Sway Bar | ECS Tuning Lower Control Arm Brace | Ziza Interior Light Kit | Luft-Technik Intake Air Scoop | ECS CF Antenna Cover | ECS CF Rear Diffuser | IE Stage 1 |Do Tinted Windows Count?
    Dec 14 2018
    san diego, ca.
    Vinyl wrap seems more sturdy than spraying on the plastic...
    Senior Member Three Rings draekin13's Avatar
    Jul 14 2014
    08 GTI, 11 F-350 King Ranch
    Kennewick, Wa
    Quote Originally Posted by mrico99 View Post
    In my experience much easier to remove as well. https://www.amazon.com/gp/product/B01M09GT92/ this is what I used. I have done Lamin-X several times so I had some squeegees and razor blades around. Take your time and don't try to stretch it too much as in cold weather it will shrink a bit. Took me a few hours to do everything on mine and while not perfect unless you are looking for flaws you won't find them.
    2011 R8 v8 Manual Ice Silver
    2019 S4 Prestige Glacier White, Black Optics, S Sport
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I got some vinyl wrap from ECS as well as the tool kit and will attempt in install it myself to black out the chrome around the windows. If that goes well, I'll find Monsoon Grey Vinyl so I can get rid of the rest of the chrome on the Q5.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    You can black out your exhaust tips for free just by driving! Better than trying to keep them shiny, which is futile.
    I know you are probably talking about chrome trim, but I'm serious about the exhaust tips turning black no matter what you do.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Three Rings djsnowman777's Avatar
    Apr 22 2008
    Queens NYC
    If you live in ny, check out nycwheelprofessionals on ig. They can de chrome your car for under 300 I think. They are in Brooklyn. They fix and powdercoat. They painted my calipers and painted my wheels few times.
    Veteran Member Four Rings MK2SQ's Avatar
    Aug 11 2018
    Quote Originally Posted by djsnowman777 View Post
    Why you have to pay? Don’t you just park the car overnight in Brooklyn and it will be de chromed for free?
    Sorry could not resist,
    Established Member Two Rings ArizonaA6's Avatar
    Jul 31 2016
    WA
    I'm going the vinyl wrap route. I ordered my 3m Gloss Black 1080 vinyl from Amazon
    There is a bit of a learning curve with this stuff, but I'm pleased with the results so far. Still trying to figure out how to attack the roof rails though.
    2013 S6 Prestige
    2016 Q5 P+ / S-Line / Tech
    2021 SQ5 Prestige
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    Quote Originally Posted by ArizonaA6 View Post
    I'll soon be in the same boat as you. Not too shabby. There are quite few videos on YouTube for this as well, that's where my learning is from thus far. And then trial by error. Good luck.
    Senior Member Two Rings 36dbldz's Avatar
    Dec 15 2018
    Escalade ESV, Audi A7
    North Florida
    If you gonna spray try superwrap. I just got this wheel kit for my 20s but will use some for the chrome trim around the doors. Haven't used it yet but seems to be same as plastidip but higher quality.can get on amazon or from them directly MVIMG_20181231_194544.jpegMVIMG_20181231_194608.jpeg
    Sent from my Pixel 3 XL using Audizine mobile app
    Jul 14 2014
    Kennewick, Wa
    Roof rails scared me a bit too but actually ended up being pretty easy, just take your time to work it up into the corners, make sure to leave enough excess to be able to have something to hang on to when stretching.
    Dec 15 2018
    North Florida
    I just did my chrome trim and rims today. Not as good as a professional wrap job but good enough for me and the kit cost $99 on amazon. Rims and trim! BoomMVIMG_20190105_141335.jpegIMG_20190105_165316_01.jpgMVIMG_20190105_184403.jpeg00100lPORTRAIT_00100_BURST20190105165419422_COVER.jpegMVIMG_20190105_150944.jpeg
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Hope it holds up. I've never done a spray-type or plasti-dip, but from what I've seen from many different vehicles over the years is that this stuff doesn't hold up well after a year or two
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Dec 15 2018
    North Florida
    Quote Originally Posted by 2018_SQ5 View Post
    For plastidip emblems (3 red in rear) $6 can will last longer than I'll have car. The superwrap on rims and trim is TBD.
    Sent from my ONEPLUS A6003 using Audizine mobile app
    Dec 15 2018
    North Florida
