Results 1 to 18 of 18
    Nov 06 2017
    Orange County, CA
    Upper radiator hose leak
    Have any of you dealt with a leak from the upper radiator hose fitting? From what I understand there are o-rings inside the fitting where it attaches to the upper radiator neck. Can the o-rings be replaced or are the hose and fitting one assembly?
    Dec 09 2018
    I just replaced my upper radiator hose. It was leaking for one of the Orings. I just replaced the whole hose. The Rein brand was only $30.
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    I did the o-rings in mine when I put it into the service position. I want to say they were about $2. Separating them required quite a bit of force though.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    Nov 06 2017
    Orange County, CA
    I値l look in to the Rein upper hose. Where did you find the O-rings? Are both ends of the hose the same thing?
    I had the car towed back to my house so I could get this taken care of so hopefully I can get to it in the beginning of next month.
    Nov 06 2017
    Orange County, CA
    Quote Originally Posted by B. Rock View Post
    I found the part number, OEM-N90765301, online for the hose o-rings. Is there just one o-ring per hose connector? One for the upper hose and one for the lower hose?
    Where did you order yours from? I知 hesitant to ask the local dealer if they have it on hand because I知 guessing Audi will want $20 per o-ring.
    Jul 27 2008
    09 3.0T A6 Avant
    I just went onto https://parts.audiusa.com/ and drilled down from there. Ordered online and picked up at the dealer. Note - not all of the dealers in town were the same price. One was a good 20%+ lower than the rest.
    1 o-ring for every quick connect, which is applicable to every coolant hose/pipe/etc.
    09 A6 Avant 3.0t
    01 WJ rock toy
    Nov 06 2017
    Orange County, CA
    Thank you, the local VW dealer has two in stock for $1.72. I was surprised to say the least. They also said G12 is no longer sold, superseded by G13.
    Jul 27 2008
    09 3.0T A6 Avant
    That is correct. It should be backwards compatible with G12 though, from what folks have told me. I am still using up an old stockpile of G12.
    09 A6 Avant 3.0t
    01 WJ rock toy
    Aug 24 2014
    Newport Beach, CA
    Here's a good read on the differences in the Audi/VW coolants, and yes G13 is backwards compatible:
    https://www.wolflubes.com/EN_EU/Blog...d-coolant.aspx
    2024 M3 Comp xDrive
    Nov 06 2017
    Orange County, CA
    I知 finally getting back to this project. The A6 has been sitting since the o-ring blew. I got the hose detached from the radiator no problem. The issue I知 having is that the new o-ring seems to be too small. The new ring is on the left and the old on the right.
    I tried putting the o-ring on the radiator neck and pushing the plastic hose adapter over it. Then I tried putting the o-ring in its slot in the hose adapter then putting the hose on. Neither way seemed to work.
    Can someone give me some guidance on this?
    I bought PN N-907-653-01 but it just seems too small. Maybe there痴 a trick I知 missing out on.
    Thank you for your help!
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    yeah that oring doesnt look right.. it should be same as your old one, they don't get bigger over time.
    the hose will just slip right on, the only reason taking it off is a pain is because it seizes on over time, also there is a little nipple off the upper radiator hose that gets really brittle over time, mine broke off by brushing up against it when i was working on mine, so i ended up just replacing the hose.
    Marko
    2007 A6 Avant 3.2L Black/Black, 265k miles
    Nov 06 2017
    Orange County, CA
    Thank you Marko. I知 going to see if the dealer has a coolant o-ring that works or just buy a new hose assembly.
    Established Member Two Rings crteacher's Avatar
    Aug 02 2009
    Chevy Bolt; Nissan Leaf
    Elk Grove
    I just did this same thing last week on my A6. I only had to replace the O-ring and it solved the problem. That small one you got is definitely not right. I bought one at the dealer for $5 and it was same size and fit.
    2006 Audi A6 Avant 3.2:: Atlas Grey|Black leather|Premium.Techno.Cold Weather Pkg|Eibach springs|S6 Avant EU rear valence|997 quad tips|S6 doorblades|In-pro LED DRLs|aluminum side mirror housings|.5 facelift|RS6 Rep. Grille|20x9 Hartmann RS4 Reps
    2008 2.0 MTQ A4 Avant S-Line: sold
    2002 1.8 MTQ A4 Avant: sold
    Nov 06 2017
    Orange County, CA
    Double post
    Nov 06 2017
    Orange County, CA
    Quote Originally Posted by crteacher View Post
    Is there any chance you have the part number you used?
    Aug 02 2009
    Elk Grove
    Quote Originally Posted by abovo View Post
    Sure thing. Part number: 4E0-121-666
    Definitely a different number than the one you posted above. Hope that helps.
    Jul 14 2018
    San Diego
    FWIW I usually put a small amount of grease on an o-ring when I replace it. Makes it easier to slide things together and helps keep it from sticking.
    Nov 06 2017
    Orange County, CA
    Very helpful! Local dealer has them in stock for $8. I値l pick one up tomorrow and throw it in. Hopefully all checks out ok.
    Here痴 an amazon link in case anyone in the future needs the same part.
    Volkswagen 4E0 121 666, Engine Coolant Pipe O-Ring https://www.amazon.com/dp/B00KWGEVYS..._3tFyCbFFVVWAH
