Really scratching my head on this one. Keep getting some random cam sensor codes. "Camshaft over advanced", "Camshaft A slow to respond" "Camshaft Position Sensor Circuit Malfunction" Most of the times it's intermittent, but sometimes it sets off a CEL. Car will then stumble off the line, especially in traffic in 2nd gear just tapping the throttle. EPC light flashed and the motor misfires between 1500 and 2000 RPM. Turn the car off, clear the code, restart, and everything is fine again. I did the timing service last year, and replaced the cam sensor a few months back. Shop tried telling me the harness was loose, it's not loose. Double and triple checked that. Did some data logging on my obdelevn the other day watching timing values at idle, off idle, and a medium pull form 2nd to 3rd (I'll post pics). Read in the forums that other guys were having this problem, but didn't see any solution to it. So here we are......
Idle
Off Idle
Pull
