Results 1 to 15 of 15
    Dec 15 2017
    New York
    Expected labor costs for supercharger pulley installation?
    Thinking about going stage 2 single pulley and reached out to a local shop for a quote on swapping out the supercharger pulley. I was thinking it should be a fairly quick thing and expected about ~$130 or so. They quoted me for 2 hours @ $120 per hour so $240 total just for the labor. How does this stack up against what others have paid for a sc pulley swap?
    I'm in a tough spot because I really want to get more power out of my car but I'm having a hard time justifying spending roughly $600 for marginal gains from sc pulley, and Dual pulley is just way out of my price range from having to also upgrade heat exchanger.
    Current: 2019 S5 Premium Plus Coupe
    Gone: 2012 A6 Prestige - APR stage 2 DP
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Quote Originally Posted by siyman4 View Post
    It took me about an hour. It's very easy I just loosened supercharger bolts and lifted it up just far enough to get the puller on and came right off and heated new one with torch and slid on easy. I didn't even have to take the coolant lines off,just loosened the clamps.
    Established Member Two Rings BurgerGawd's Avatar
    Nov 08 2016
    Rollerblades
    Philly / South Jersey
    Quote Originally Posted by Shane Horning View Post
    Ooooh torch, nice touch
    Please elaborate. I plan on doing mine soon
    Oct 22 2014
    Atlanta, GA
    Toaster oven is even easier and even. Several how-to videos show the steps.
    Nov 16 2018
    Upstate. New York.
    Quote Originally Posted by BurgerGawd View Post
    I just set the pulley on the ground and heated the front inside of the pulley and grabbed it with a visegrips and slid it on. I had a cts pulley so them fit tighter so I heated mine to 800 which was plenty hot. Prolly 600 would work if you cool the supercharger shaft with ice beforehand
    Nov 08 2016
    Rollerblades
    Quote Originally Posted by SpectreGadget View Post
    I’ve seen them, but I’m in an apartment although 1st floor I’d rather not run a 100 ft extension cord.
    My main goal is to demonstrate the usefulness of my torch collection to the wife
    Nov 08 2016
    Rollerblades
    Thanks. I think most install guides say around 400F so 600 is plenty good
    Nov 16 2018
    Upstate. New York.
    Yes that's good for most pulleys but some have had trouble with the cts at 400
    It's very easy to prop up the supercharger, most everything can stay connected just loosen the coolant line clamps
    Oct 22 2014
    Atlanta, GA
    Let me know how that works out!
    Jan 28 2015
    14 X3, 99 F250
    Phoenix, AZ
    Better than what I was quoted. Three hours at $109 / hour.
    2013 A7 Prestige Daytona Gray | 20" Sport Package | LED Headlamps
    APR DP & CPS | p3u tcu | EBC redstuff & USR| EuroCode swaybars | RS7 airbox | BMC filter | Autohold | 034 Motorsport transmission mount insert | OE rear sunshade
    Senior Member Three Rings dc2002's Avatar
    Jan 29 2007
    Roswell GA
    I got 3 quotes locally from 360 to 500 to 600.
    Weighed against messing up my ACC and ruining an entire Saturday I opted for the 360 route at a local very reputable shop.
    - - - Updated - - -
    And stage 2 is a beast....
    2012 A6 3.0T Prestige
    EPL Stage 2
    Oct 22 2014
    Atlanta, GA
    Quote Originally Posted by dc2002 View Post
    - - - Updated - - -
    Yes, worth it. I used the unbolt the supercharger approach and it went pretty well. Have fun!
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    If the kitchen is not too far away from your work space, use the kitchen stove and and bake the pulley long enough to heat and expand it
    400F for 35-45 minutes. Wear good and thick leather gloves
    Jul 30 2013
    Colorado
    I Paid $280
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    For my car (different car but same engine) and crank pulley, I paid 3 * 125 = 375 for labor.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
