Results 1 to 14 of 14
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    Stock exhaust with test pipes before/after video
    I'm starting to feel like I should have started a build thread and probably will but just trying to share experiences as I go and this forum is a little slow compared to the S4 guys that I'm used to so I hope its ok that I keep posting updates as I build my car. I'm close on power goals, just need a revised tune and a TCU tune at some point. Next will be handling. Here is a video I put together of before and after test pipe install on an otherwise stock exhaust.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    Sounds similar to stock at idle and under partial throttle and sounds great under WOT. Not obnoxious at all. Any drone?
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Nov 12 2006
    Michigan
    Quote Originally Posted by Perry01 View Post
    No drone at all, sounds completely stock just cruising at neutral throttle.
    Established Member Two Rings messex's Avatar
    Apr 16 2017
    xr400
    los angeles
    Sounds really good!
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Nice. Does it smell? And dam, @0:45 that thing scoots!
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Nov 12 2006
    Michigan
    Quote Originally Posted by q5 dave View Post
    Yea it stinks, I’ll probably go high flow cats soon.
    Jan 08 2016
    Los Angeles, California
    Perfect!
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Active Member One Ring ssjchris's Avatar
    Oct 01 2018
    Pennsylvania
    Wow honestly that sounds perfect! How did the install go?
    Sent from my SM-G935T using Tapatalk
    Nov 12 2006
    Michigan
    Quote Originally Posted by ssjchris View Post
    It took about 3 hours for the downpipes. Not bad at all.
    Dec 13 2018
    Nashville, TN USA
    Quote Originally Posted by elijahallen View Post
    Did you remove the factory cats yourself or did you pay someone?
    If you did it yourself, Any tips/tricks or suggestions or any DIY write ups on doing so?
    Nov 12 2006
    Michigan
    Quote Originally Posted by TRiker1981 View Post
    I had my shop do it. There is a special wrench to get to the back nut that without it it would not be easy.
    Established Member Two Rings James115's Avatar
    Jun 02 2021
    Audi A6 3.0 TFSI ABT, Mercedes C63 amg
    Italy
    I am planning to do the same on my A6, I bought the red star test pipe. What will you do for the cat?
    Thanks
    Jul 31 2016
    PA
    I'd suggest looking at the JHM baffled cat pipes, or get a cat and have it welded into the downpipe in place of the resonators.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Jun 02 2021
    Italy
    Quote Originally Posted by djn876 View Post
    Yes, I was thinking to the jhm catted but I don’t have any feedback from them, I asked what type of cat they use but no reply
