    Sep 02 2016
    Using mmi cable vs bluetooth for connection phone to mmi??
    What's the difference in features or audio quality if any??
    Also does b8.5 mmi play videos?
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    Conncting via cable allows you to navigate through artists, folders etc. On BT Audio you can only skip to next/previous track in the current playlist.
    Sound quality is the same for me (iPhone and B&O)
    2014 Audi S5 3.0T STronic // Estorilblue
    VAG Coding and retrofit expert
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Sound quality for me is the same, too. B/T also takes longer to start up after the car is turned on, but I still prefer the convenience of not even taking my phone out of my pocket for my music to start.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    Sound quality on Bluetooth is very close to the same, much better than the Hyundai I used to have. I have only connected my old iPod via MMI cable, not my phone. Nice thing is I can leave it hidden in my glovebox and control it through the MMI.
    Like HazeMyth said, had to beat not having to take your phone out of your pocket or bag to get essentially the same quality.
    XM sound quality on the other hand...
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
    Aug 13 2008
    Reston, VA
    Mimi cable has much better bass
    Not sure if you will notice this with OEM sub
    I have an after market one and it's certainly better with Mimi
    Also
    Bluetooth uses a compressed format for streaming audio from phone to stereo
    Cable isn't compressed, so it's higher quality using cable
