Results 1 to 40 of 48
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Turbo Concepts selling Intake Manifold
    Anybody look into trying this thing Turbo Concepts is selling?
    Veteran Member Three Rings ruiz's Avatar
    Apr 07 2009
    B5 bi-turbo avants
    MD
    Here's the same thing for cheaper:
    https://www.ebay.co.uk/itm/Intake-Ma...UAAOSwdIlbkoB5
    Sent from my LG-H901 using Tapatalk
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    I would love to know if it has any real benefit and flow differences between stock and rs4 manifolds.
    Sent from my LM-Q710(FGN) using Audizine mobile app
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by ReggieNoble View Post
    I'm going to see if they'll send me one to test.
    Apr 07 2011
    Home of the mighty beaver
    How are you taking it seriously? It looks like straight from china garbage.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Quote Originally Posted by S4James View Post
    Doesn't mean it won't work.
    Chinese garbage downpipes are on 9/10 B5 S4s these days and do just fine.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    It might not be exactly about overall flow, but how it shapes the powerband. It all depends on runner length. Most of the issues with China intakes is thin material over large surfaces allowing flex then failure. One could brace it also.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    That and many other problems. Shit welds,
    warped flanges, mounting holes that don’t
    line up and way more headaches. All the Chinese
    5 cylinder parts come with those problems
    above.
    The only thing I’d do Chinese on the b5
    is downpipes, exhaust, and possibly the
    y-pipe & bipipe. Literally nothing else. If
    you have the funds skip xspower entirely.
    Nov 14 2013
    Also based on your data the best
    intake manifold setup to date is
    an ported rs4 manifold with enlarged
    plenum. You said it even outflowed
    the loba motorsports intake mani.
    Jun 30 2018
    Portland OR
    Interesting. How about the project b5 big plenum manifold?
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by landfill View Post
    I don't believe I called the ported RS4 manifold the best. It out-flowed the Loba when the test was performed with all of the intake runners open simultaneously. That is not representative of how the part functions in operation. I would put more emphasis on the test case where each runner was flowed individually.
    That's not particularly relevant to what I'm interested in, the product that TC is selling is different and I haven't seen a whole lot of different designs available for this engine so I'm curious to see how it compares with respect to airflow.
    Nov 02 2014
    Winchester, VA
    above.
    Something as easy as the manifold to replace doesn't bother me to try out. But, then again I don't have anything on top of mine.
    I wouldn't mind testing one out with the dragy, only takes a few minutes to swap so I could do back to back runs.
    That said, I'm not going to be buying one any time soon, but it has my interest.
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    the runners look anemic imho
    Nov 14 2013
    It was late and I guess a poor choice
    of words. You were saying the ported
    rs4 outflowed everything thus far so
    I figured it was the best choice for peak
    hp numbers but I could be wrong.
    I guess in my opinion until a quality
    aftermarket option arises then the
    ported rs4 is the way to go. Again
    just my .02.
    Anyways I wouldn’t mind seeing your
    data on this piece but if it’s from China
    I’ve had bad luck with a lot of their
    Audi parts.
    Aug 06 2008
    Canadia
    Too bad it doesnt have provisions for secondary fuel injectors, especially something being marketed for bigger set ups.
    Dec 17 2016
    B5 S4 Avant
    Fl
    I think one of the biggest faults with this manifold is the fact it appears to use the S4 throttle body. It would of be nice if it was able to use a RS4 or hemi throttle body. I also have concerns about the area above the throttle body flange, it looks like it would cause turbulence.
    Mar 22 2013
    AK
    TheTuner makes a quality intake manifold out flowing the RS4 piece with optimized runner without silly bottom weld one but not at bargain prices Chicom parts offer
    Hilariously some posters bashing Chicom stuff are running Chicom sourced flat out ripped off /copied turbos from a Chicom peddler in Las Vegas
    Nov 19 2014
    Portugal
    Quote Originally Posted by Drehmoment View Post
    You didn't :) 😱
    Apr 07 2011
    oh just ignore that guy. He adds no value.
    Aug 06 2008
    Canadia
    Las Vegas
    “Im Rick Harrison and THIS is my B5S4”
    Jan 06 2007
    Mk7 Golf R
    FL
    TheTuner makes a quality intake manifold out flowing the RS4 piece...
    This one? By how much?
    Junior Member Two Rings Cash-Fueled-S4's Avatar
    Dec 11 2018
    1967 Cadillac Coupe DeVille, and a 1979 Chevrolet C30
    Napa California
    Quote Originally Posted by FlyboyS4 View Post
    Seconded, anyone know the actual benefit? Or if there is any?
    Nagaro blue B5 S4, 6 speed, Ko4 turbos, EVS 14 550 CC injectors, 034 stage three tune, 034 forged diverted valves, silicone hoses, 85MM MAF housing, MAF upgrade, twin disc ceramic clutch, secondary oxygen sensors tuned out, XSpower full stainless exhaust (no cats), rolling on Enkei PF01’s
    Nagaro blue B5 S4, 6 speed, Ko4 turbos, EVS 14 550 CC injectors, 034 stage three tune, 034 forged diverter valves, silicone hoses, 85MM MAF housing, MAF upgrade, twin disc ceramic clutch, secondary oxygen sensors tuned out, XSpower full stainless exhaust (no cats) rolling on Enkei PF01's
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Quote Originally Posted by Cash-Fueled-S4 View Post
    The benefit is mainly weight reduction.
    ..of your wallet.
    $2300 intakes? no thx please lol.
    Apr 07 2011
    law of diminishing gains... When you can mod a stock one for 1/4 of the price and get 95% of the performance.. Makes more sense to put that cash into something that will benefit you better.
    But if the goal is a maximum effort build, and no expense spared, then sure fuckit... Mind you there are a ton of much better cars out there to soak up your money and they will be a lot damn faster and reliable.
    Mar 22 2013
    AK
    Quote Originally Posted by VR6Bomber View Post
    ..of your wallet.
    $1535 if you can read.......but I am sure you would be shelling out 2g's plus for Chicom knock off turbos where the vendor pockets $1800 with zero R&D and are convinced you got a great deal.
    Mar 22 2013
    AK
    [QUOTE=Cash-Fueled-S4;13441307]Seconded, anyone know the actual benefit? Or if there is any?
    Nagaro blue B5 S4, 6 speed, Ko4 turbos, EVS 14 550 CC injectors, 034 stage three tune, 034 forged diverted valves, silicone hoses, 85MM MAF housing, MAF upgrade, twin disc ceramic clutch, secondary oxygen sensors tuned out, XSpower full stainless exhaust (no cats), rolling on Enkei PF01’s[/QUOTE
    Once upon a time Quattro GMBH commissioned Cosworth to build a engine with some potential.........to get to 385 crank they build a entire new engine top to bottom and yes, it included a enlarged e n g i n e e r e d intake manifold to provide adequate flow for the rest of the puzzle called a Otto engine.........now if you are willing to get to the top of the heap with the goal of 1000 plus chp the Thetuners piece will, in conjunction with another $35000 in parts/labor get you there not counting the other $20000 you will be spending to learn how to make it last.
    Jan 06 2007
    Mk7 Golf R
    FL
    Saying that it outflows the RS4 is too general to convey useful information, as well as unsubstantiated thus far.
    I assume VAT would not apply to a U.S. purchase so looks like the price would be about $1230. Reasonable price for what looks like a quality part.
    Getting back on topic, I heard back from TC and am discussing what I have in mind.
    Aug 04 2013
    Pennsylvania
    $1230 isn't bad at all. I'd spring for that if I didn't already have a ported/enlarged plenum RS4 manifold
    Apr 07 2011
    agree
    Nov 14 2013
    Damn I honestly thought it would be a lot more $$$.
    Aug 06 2008
    Canadia
    Where the velocity is the higest the velocity is the lowest, with that in mind adding pressure is just slowing down the air velocity into the engine.
    The only reason “bigger is better” seems to work is because the penalties paid for all the sharp edges in the intake system would be lower when things are larger.
    Basically, the less air you are trying to move the less it matters the changes in direction, shape, etc of the air.
    Veteran Member Three Rings csobel's Avatar
    Mar 25 2018
    Portland, OR
    BAM! Busted.
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by MacDaddy View Post
    I'm confused by that statement.
    The rest is also not very clear to me.
    May 13 2009
    XXXX
    I have TTE's dork.
    Aug 06 2008
    Canadia
    Where pressure is highest velocity is lowest*
    Jan 06 2007
    Mk7 Golf R
    FL
    Ok.
    What does this mean:
    "with that in mind adding pressure is just slowing down the air velocity into the engine."
    What is adding pressure, where is it being added, and what is pressure being added to?
    Deactivated Two Rings
    Jun 13 2018
    Los Angeles, Ca
    http://www.youtube.com/watch?v=UX3_uGRAqZA&t=2m10s
    Registered User Four Rings
    Sep 01 2013
    Sweden
    TheTuner IM is very nice Peace of Engeneering.
    For proper results, it should have been measured static on the bench. I can feel personally, this is something they should have done in the first Place.
    However, i have had oportunity to Tune 2 cars with this Setup. They also had other Power addons from TheTuner.
    All of them very Beautiful Products, perfect fitment.
    This is an RS4 with Loba600 on petrol 98 (Us 93), made 636bhp.
    It is alot for petrol used and turbos.
    https://www.youtube.com/watch?v=7LE9fYEYIlQ
    Maybe the IM has played a big role in it? I dont know, but concidering that used RS IM is 1000 bucks, brand new TheTuner IM is not so bloody expensive.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Mocke do you have any pictures of thetuner piece? I’d like to see what the inside looks like since they only have a few pictures on website.
    Sep 01 2013
    Sweden
    Quote Originally Posted by Silverex View Post
    No i dont, its customers cars.
    I can ask.
    But i might get back to back logs, as one of the mega builds i have been involved in has been tuned on RS IM. He has been talking about switching to TheTuner one.
