Results 1 to 14 of 14
    Nov 15 2018
    Alexandria, VA
    Best Tire Size for 21" Stock Wheels on 2016 SQ5
    Couple novice questions here so bear with me... picked up a 2016 SQ5 a couple months ago... love it. Came with the stock Summer tires, and I'd like to replace them with All Seasons (I'm in VA, it's fairly moderate here... don't need dedicated Winters).
    So the stock size is 255/40... but they seem pretty low profile compare to what I'm used to, so wondering if I can get tires with a bit more meat on them.
    I've seen people here recommend 265/40's... what about 265/45's? What's the largest that'll fit on the stock rims and install on the vehicle without any modifications?
    Could always go to 20's or 19's but I like the look of these 21's. Appreciate the help!!
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Quote Originally Posted by falconcry View Post
    I'll let an expert on the B8 chassis weigh in. It seems like there are 2-3 common set ups people. The 265/45 option will be too much - as you increase the width, the sidewall increases naturally. So even a 265/40 will have a taller sidewall than your 245/40. If you increase the width by 20mm and then increase the aspect ratio by another 5 - you'd be oversized.
    265/40 would be what I'd tell you to go after. 19s or 20s sounds like a gross idea unless you're building a track car and want lighter weight
    '18 S5 - BBS / EPL
    Nov 15 2018
    Alexandria, VA
    Quote Originally Posted by JD S4 View Post
    yea, thought 265/45 might be too much. thanks man
    Dec 14 2018
    2014 MINI
    Gallatin TN
    265/45 would be oversized but only bu a small percentage. Speedo would be off 1-2mph. Nothing that would adversely effect anything.
    2014 Q5 Premium Plus TDI with extended MMI NAV / B&O Audio
    MODS: H&R Street Performance coilovers , TSW Bathurst 20x10 et25 wheels
    , 295/40/20 Toyo Proxes STIII tires and APR tuned
    Nov 15 2018
    Alexandria, VA
    Gotcha. So 265/45 wouldn't rub or hit anything physically? Any advantage to 45 or just stick with 265/40? Thanks again guys
    Oct 24 2018
    Detroit
    You wouldn't even be able to bolt up a tire as it would interfere with the UCA. 265/40/21 Michelin Premier LTX barely fit without rubbing. From what I've seen Pirelli tires are slightly smaller and will allow more clearance .
    Nov 15 2018
    Alexandria, VA
    Quote Originally Posted by turner56 View Post
    Copy, thanks. Looking at Pirelli Verdes
    May 06 2007
    Michigan
    This thread might help you out for the Verde all seasons: https://www.audizine.com/forum/showt...ighlight=verde
    2013 Daytona Grey RS5
    Prev
    2014 Ice Silver SQ5
    2012 Monsoon Grey S4
    2010 Brilliant Black A5
    2003 Denim Blue A4
    Nov 15 2018
    Alexandria, VA
    Quote Originally Posted by mlux24 View Post
    Sure does, thanks for the link
    Sep 14 2005
    NC
    If you ever want to swap for 20s let me know. I’m in no rush but always would consider. I’m in nc
    Nov 15 2018
    Alexandria, VA
    ok guys, I'm about to pull the trigger on some 265/40 Verdes from tirerack... but now I'm confused. There are 2 listings for Verdes on the site. Pictures and reviews are identical, but there are a few differences in the specs:
    Listing 1:
    - $217
    - 105v
    - 34 lbs
    - country of origin mexico
    - https://www.tirerack.com/tires/tires...um=64VR1SVASXL
    Listing 2:
    - $223
    - 105w
    - 30 lbs
    - country of origin italy
    - https://www.tirerack.com/tires/tires...um=64WR1SVASXL
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Speed rating, weight, country of origin, and probably their age. They can all play a part in their pricing.
    Nov 15 2018
    Alexandria, VA
    Quote Originally Posted by SQive View Post
    yea, but what I don't understand is why are there 2 versions of the same tire? Is one a 2017 model and one a 2018 model or something?
    Apr 26 2014
    DFW
    Probably.
