Results 1 to 17 of 17
    Junior Member Two Rings
    Nov 13 2018
    Riverside , ca
    P00b7 engine coolant flow low
    This p00b7 code came up on my A3 8v 1.8 the other day so I cleared the code and thought maybe it was a random code. Came home from work parked it and the car sat for about an hr. Went out to go the the store and got the same code right after start up and the temp gauge was almost to the high mark. Grabbed my vagcom and the coolant temp was at 72c so it wasn’t over heating ? Shut down the car and restarted immediately, code went away by itself and the temp gauge was at normal. Any thoughts? Possible bad thermostat or bad sensor ? I’m no a mechanic but if it was the water pump then wouldn’t the car be overheating right after the second start up ? Car has been on idle now for 15min with vagcom plugged in with no sign of overheating. Coolant level in the tank is just below the M mark.
    Nov 13 2018
    Riverside , ca
    Update: car is still on idle and temp is staying between 107 - 108 c and the temp gauge is at half
    Sep 14 2006
    Take it to Walter's Audi if it's under warranty. Ask them to do a pressure test. Chances are, they'll just top it off, but at least it will be documented that you had an issue now, so if it happens again in the future, you'll have a better chance of getting the issue fixed under warranty. The water pump is a common issue on these cars.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Nov 13 2018
    Riverside , ca
    Thanks. Unfortunately warranty expired. Got 60k on the clock. Think I’ll top off the coolant wait and see if it comes back and if that doesn’t work change out the coolant sensor and do a coolant flush while I’m at it and if that doesn’t work then I’ll drop the big money on a new pump
    Sep 28 2017
    It's the thermostat/water pump. They are one unit. I had mine replaced in my A3 and I just had it replaced in my S3. You will never see any fluid leaking. Mine is parked in my garage at home and at work. Seems to be a known issue. Audi mechanic said the factory ones had a pin hole leak. They are plastic and the new ones are metal. Problem solved. I have no idea how much to replace as both of mine were done under warranty. The part is Thermostat Unit - Audi (06L-121-111-J). It costs $146.32. I hope that helps.
    Nov 13 2018
    Riverside , ca
    Thanks aem. Just ordered a new thermostat and coolant from fcpeuro. I fell like I’m pretty mechanically inclined to do a diy on this. Anybody know where the thermostat is located on the 1.8 gen3 ?
    Mar 20 2019
    saudi Arabia jeddah
    Question audi A4 2014 Problem P00B7
    Hello everyone can anyone help me in my problem please I have audi a4 2.0T 2014 2 fans working to fast and overhating when i put the obd in it showing P00B7 i think that was the water pump so i changed it but the problem not solve the 2 fans working fast sometimes it showing EPC and engine oil pressure too low What should i do its not under warranty
    Oct 05 2022
    I have a 2016 A6 Quattro 2.0 received a CIL, scanned and retrieved code P00B7. Dealer diagnostic found a leak from the thermostat and will not cover it under the extended warranty on the water pump. Having the water pump and thermostat replaced now from a reputable specialized Audi mechanic.
    Established Member Two Rings RedStallionA3's Avatar
    Jul 17 2021
    Orange County
    I just got priced $2000 to fix my p2681 and p00B7 fault codes which is the thermostat etc that's alot of money for just a thermostat. Mechanic tried to say the thermostat water pump housing cost $700 but ecs tuning has it going for $285 so I'm lost on why the mechanic wanted to charge so much. Oh and the mechanic will only get the parts through his people he won't install any parts that I come across wether cheaper or more expensive
    Sent from my SM-G998U using Audizine Forum mobile app
    Dec 25 2004
    Earth
    Quote Originally Posted by RedStallionA3 View Post
    The thermostat and water pump require the intake manifold to come off....
    I would go to a different shop...get a better quote cause that shop is going to rip you off...IMO
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jul 17 2021
    Orange County
    Quote Originally Posted by MikTip View Post
    I think ima just have my buddy who worked at VW as a mechanic and other dealerships aswell help me and tackle the thermo and water pump myself. I did make an appointment for audi to look at it but that's not til Oct 25 but that's worst comes to worst
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    From your other post, sounds like you're in LF and your "Audi" appointment is way out there, I think I know which dealer you're referring to. I would not use that dealer if I were you - I just had my 50k AudiCare serviced there, which is essentially just an oil change and "some" inspections and they had my car for over a week and it took me over 3 weeks to get an appointment! They were very unresponsive when you try to call them - 90% of my calls went to voicemail without a returned call...very frustrating experience. I would recommend venturing further north to SouthCoast Audi, which is much better, IMHO.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Jul 17 2021
    Orange County
    Quote Originally Posted by XMetal View Post
    Which one are u talking about. Which mechanic ?
    Nov 02 2017
    CA
    I was assuming your appointment at Audi Mission Viejo?
    Sent from my Nokia 8.3 5G using Audizine Forum mobile app
    Nov 27 2020
    Florida
    A3 stallion - please tell us how the engine fire was resolved. I've been waiting months for a resolution on that story!
    Jul 17 2021
    Orange County
    No I sent have that appointment until the 25th if I dont fix the issue by then I guess that's my last resort
    Jul 17 2021
    Orange County
    Quote Originally Posted by noseyp View Post
    It could of been the turbo getting really hot idk that's in the past
