I was able to take advantage of the 10% off sale and purchased the harness for $270 and the adapter for $180. This is all that is needed. I already had a 74mm Bosch throttle body sitting around from my 997. This TB is on a ton of Porsches and can be found in great shape on ebay too for around $50.
Thank you also to Issam Abed for taking the initiative to create this harness given us a plug and play solution for upgrading TB sizes.
CONDITIONS:
All testing was performed the same day. The 74mm throttle body runs were in slightly cooler temperatures giving an unfair advantage to the throttle body test results, however the difference was approximately 5 degrees F and I attempted to control for this as well as possible by keeping starting intake temperatures as close as possible. All testing was performed on the same tank of gasoline. All air filters were brand new.
Stock run DA: +553 feet - 4:53pm
Modified Runs DA: +439 feet - 6:53pm
Ultimately its about as well controlled of a test session as you can get without having a climate controlled test cell.
The following was the vehicle setup for all runs:
2013 Audi S5, DSG with Unitronic Stage 3 file that allows up to 26 degrees timing and requests 2450mbar boost. 200mm KI pulley was installed with stock SC pulley. Divorced Revo charge cooler installed. Exhaust is stock.
TEST VARIABLES:
I tested the following setups:
1. Stock Throttle body with Modified Stock Airbox consisting of a ported airbox with AFE inverted cone oiled filter (brand new) with OEM accordion intake tube.
2. 74mm Throttle body with Modified Stock Airbox consisting of a ported airbox with AFE inverted cone oiled filter (brand new) with custom silicone intake tube reinforced in the center with a 6” long aluminum tube.
3.74mm Throttle body with APR Open Intake with custom silicone intake tube reinforced in the center with a 6” long aluminum tube.
Throttle body Part Number: 99760511501 for 74mm throttle body
RESULTS:
Here is the log of the BASELINE run with the Modified Stock Airbox and Stock Throttle Body…
https://drive.google.com/open?id=1Zw...sD_qPvjLlmMqZH
Here is the log of the 74mm Throttle Body run with the Modified Stock Airbox….
https://drive.google.com/open?id=1dp...zASi8TKivAZGBc
Here is the log of the 74mm Throttle Body with the APR Open Intake…
https://drive.google.com/open?id=1Xa...eTmuDAXfawBnN0
VIRTUAL DYNO - COURTESY OF K186 THANK YOU
DISCUSSION:
The throttle body itself probably gained around 5-10hp. The use of an open air intake compared to a ported stock airbox with smooth intake tube and high flow air filter was also an improvement compared to the throttle body upgrade and modified stock box. Probably worth 10-12hp when combined with the 74mm throttle body. Keep in mind these gains are on a relatively tame 3.17 pulley ratio and a stock supercharger (not ported). It is possible these gains could be even more improved with higher pulley ratios and ported blowers.
Driveability has been the same as stock thus far. No issues noted. No perceivable difference noted.
PHOTOS:
