Originally Posted by
mattlqx
Any and all vacuum lines, particularly if they're the hard plastic kind are super brittle. I ended up replacing the PCV hose (which is a big tee contraption) and ended up breaking a vacuum line that runs into the driver side fender. Not clear on where that even goes, but I was able to couple it back together.
Goes to the "Vacuum Reservoir" or technically the reservoir that holds NOTHING! Not even air.
Two reliability issues to consider on older 2.7T engines are:
1. The stock turbos. If they are starting to go, they will go. If not, good maintenance should keep them going as long as the engine itself.
2. The Cam Chain Tensioners. The pads will wear out, so check for wear on the next timing job or leaky valve cover gasket replacement.
Pretty good other than that so long as you do the timing/waterpump and other normal preventative maintenance and hoses/wiring stuff as mattlqx listed.
You should also consider the transmission issues that will happen. the 1-2 syncros tend to crap out on the manual, and the torque converter seal tends to go out on the auto. I am convinced that if someone were to have actually changed out the tiptronic transmission fluid every 50k miles, that wouldn't be and issue, but that would be an incredibly rare thing since Audi lists the trans fluid as lifetime in the manuals.
Another something to consider when looking at an older 2.7t cars is... don't worry about any of that if you plan to bump up your power level with bigger turbos. Just rebuild everything when you do the turbo install and you have a brand new car that will last at least another 100k at the higher power levels so long as you don't do something silly.
