Results 1 to 11 of 11
    Sep 28 2006
    Lexington
    Key Fob won't stay programmed (Keyless Entry)
    So, I've had problem with my keyless entry not working lately.
    I will program it and it will work one time and then it stops working. Here is the only code I can find.
    00955 - Key 1
    00955 - Key 1: Adaptation Limit Surpassed
    Possible Symptoms
    Key/Remote Control not operational
    Possible Causes
    Key/Remote Control not matched
    Key/Remote Control operated too often while Out of Range
    Possible Solutions
    See vehicle specific page for synchronisation/adaptation procedures
    Could it be the control module going bad? My buddy at audi said it recognizes it, but not doing anything.
    Thanks
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Sep 28 2006
    Lexington
    I scanned the car and it said programmed, but now it says not programmed. what is going on?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Sep 28 2006
    Lexington
    So, when I was using my scan tool to try and reprogrammed, I erased the remote. How do I fix this?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Feb 15 2016
    Cambridge,Ontario
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Sep 28 2006
    Lexington
    I only have one key, so I don't think this will work.
    The code I posted above it gone, because when I go in with my scan tool, it shows no key programmed.
    My buddy at audi says it could be the control module
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Feb 15 2016
    Cambridge,Ontario
    yeah no key programmed is not good that is for sure ...
    the key operated too often while out of range is interesting
    wonder if a flakey switch in the key could cause this , then the car invalidates it.
    Not to sure about this one.
    1976 Yamaha XS 360
    Sep 28 2006
    Lexington
    It works for everything else, just not keyless entry. I got it working last night, but it only worked once and then I had to do it all over again.
    When I went back in (scanner), I like I erased remote and now it won't let me reprogram.
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Established Member Two Rings Maximoose001's Avatar
    Aug 24 2018
    18' VW Passat R-line, '88 Porsche 911 Carrera (Turbo), '17 Mercedes GLS450, '18 Infiniti QX60
    Lauderdale By The Sea Florida
    My key works fine accept for keyless entry. It doesn’t lock/unlock from the door handle. Any ideas?
    - Max
    - Max
    Sep 28 2006
    Lexington
    I'm still lost on this. maybe control module under the carpet
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Quote Originally Posted by Maximoose001 View Post
    - Max
    I have the same problem as you. I learn to live with that
    Jul 06 2009
    2007 A4 B7 (project car)2013 B8.5 S4 IE stg1 2015 A3 8V
    Atlanta
    You can program your FOB with only one key. You need to remove the lock cylinder from the drivers door, but working key in ignition and use a screw driver to operate door lock. its tricky to do with one person, but it is possible. I reprogrammed 2 FOB's this way, just had to swap the immobilizer out of the old FOB. There is a DIY that I followed to do this, but I can't remember if it was on AZ or YouTube
