Results 1 to 9 of 9
Thread: ACC retrofit
    Established Member Two Rings Daemotrix's Avatar
    Jun 14 2018
    Prague
    ACC retrofit
    Hi,
    Is possible to retrofit ACC or distance regulation with radars only? I have cruise control, but I haven't camera on windscreen. Is possible to retrofit it without that camera? Thank you.
    Senior Member Three Rings Dawid's Avatar
    Mar 09 2012
    Denmark
    Short answer: No.
    Camera in windshield is a part of the ACC system on 4G.
    Jun 14 2018
    Prague
    Okay, I hoped at least for distance regulation or automatic brake if sensor detects something. Thank you.
    Established Member Two Rings vrod's Avatar
    Oct 02 2018
    Germany
    How hard is this if you DO have the front camera? Pulling the trigger on an S6 soon but it doesn’t have ACC.
    Aug 24 2014
    Denver
    2 words for you. Cost Prohibitive...
    There are radars in the front grilles if you don't have those, they run $2500ea and that's the tip of the iceberg, control units etc etc.
    Apr 03 2018
    I personally hate the ACC and auto breaking feature. I’ve almost gotten into more accidents because of them than anything else. Doing 75 in the highway and all of a sudden it just mashes the breaks with no warning and no one in front of me. Turned both features off.
    May 20 2010
    Quote Originally Posted by Helios Black View Post
    Sounds like your system is not calibrated correctly. I've had mine brake for me, but it's usually because some jerk cuts me off, or I forgot to shorten the distance. It shouldn't just brake like that--if you're under warranty still, I'd take it in and see if they can replicate it. Or if you have dashcam footage, show them that.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Established Member Two Rings winreboot's Avatar
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    I'm sure it's not for everyone. I collected all my parts and just missing windshield. You will need below parts to get ACC to work:
    -ACC radars left/right with brackets and new grills
    -ABS pump with ACC support
    -Instrument cluster with ACC support
    -New cruise control lever and stock with ACC support
    -ACC module
    -Camera in Windshield
    -Windshield that has mount for camera, if ur doing HUD at the same time make sure you get windshield with HUD film on
    -Wiring harness for Camera to module
    -Wiring harness from module to ACC radars
    -Coding, component protection removal from module
    -Last is calibration at Audi dealer
    Again this is not for everyone, but it's duable and has been done already.
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by Daemotrix View Post
    Hi,
    Yes you can retrofit the ACC to the C7, KUFATEC sells a kit, it's about 4800. EURO = 5428.00 today ;-) And a shit load of labor. I retrofitted the "advance key" and the kit was 800.00 and the labor at my Audi dealer made my nose bleed!
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
