Results 1 to 33 of 33
    Oct 31 2018
    san diego
    Best Way To Black Out Window Trim?
    What is the common ways to black out your window trim.
    I know that vinyl is one way but I have heard that only really works for about a year or two? Is there a more long term way? Remove trim, powerder coat?
    Senior Member Three Rings j23a45m's Avatar
    Feb 07 2018
    19’ Qx60, 16' s1000rr, 15’ S4, 12' X5, 10' A3
    Lacaster, Pa
    Sem trim black
    Look that up!
    [B]'15 S4 - Sepang Blue|DSG|Sport Differential|MMI|B&O Side Assist|ECS Trans Mount|ECS F/R Diff Mount|MercRacing Hx/ Divorce kit|AWE Touring Exhaust 102mm|Apr Open Carbon Fiber Intake|Iabed 82mm throttle body |35% Tint|3000k Fog LED's|OBD Eleven Mods|Macan 4-piston brembo calipers|Unitronic Stage3 Ecu/ stage 2 Tcu|Custom clear lense and painted Headlights|Ecs carbon lip and rear diffuser|Airlift 3P/H| 10.25 Rsnav|034 Track/Street density/ Sway bar| [/CB]
    Jan 03 2018
    Torrance, SoCal
    Plasti-dip? Probably the worst looking and least durable, but it's an option!
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    I had mine removed and color matched to the body when I had to have my rear bumper painted.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Veteran Member Three Rings hellovaras's Avatar
    Oct 28 2018
    PNW
    Quote Originally Posted by rustyrizzo View Post
    I am doing this to my Camry this week using DYC emblem kit. Will send you pics. Should work fine.
    2013 Monsoon Grey B8.5 S4 6MT | ECS CF Wing | ECS CF Front Lip | Canyon Run-15 Strut Brace | ECS Front Strut Tower Bar | Injen CAI | ECS Center X-Pipe | 034 Motorsports Rear Sway Bar | ECS Tuning Lower Control Arm Brace | Ziza Interior Light Kit | Luft-Technik Intake Air Scoop | ECS CF Antenna Cover | ECS CF Rear Diffuser | IE Stage 1 |Do Tinted Windows Count?
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    I had a detail shop wrap mine.
    Sent from my iPad using Tapatalk Pro
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Senior Member Three Rings TristanT14's Avatar
    Sep 24 2017
    Totaled B8.5 Moonlight Blue S4
    Long Island
    Had mine wrapped in Satin black.
    2014 Moonlight Blue Audi S4 Totaled
    Integrated Engineering DP Crackle
    2011 E93 Snapper Rock Blue Metallic BMW M3
    Instagram @DREAM3Y.M3
    Senior Member Two Rings PR.138's Avatar
    Jun 22 2018
    ‘08 Honda S2000
    DC/MD/VA/WV
    What have you all been quoted price-wise for wrapping the trim? I’m planning on having it done this winter, but not sure what to expect for pricing.
    2020 Audi S3 - Ara Blue
    2008 Honda S2000 - Laguna Blue Pearl
    [sold] 2014 Audi S5 - Misano Red | EPL Stage 2 DP - 3.25 ratio | MercRacing HX | H&R RSS+ | CR-15 | DPE FT-5S 20x10
    [sold] 2016 Audi SQ5 - Mythos Black
    Instagram: @pr.138
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    $250-$400 anything beyond that you're getting robbed
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
    Sep 24 2017
    Long Island
    Quote Originally Posted by PR.138 View Post
    Mine was 275 so yeah that 250-400 price range is good. Contact a couple different shops about it. I went with the cheapest since its only small and black.
    Jun 22 2018
    ‘08 Honda S2000
    DC/MD/VA/WV
    Perfect, thanks guys. That sounds reasonable. Hopefully the place near my house quotes me somewhere in that range so I don’t have to look around too much.
    Instagram: @pr.138
    Senior Member Three Rings EAFLO88's Avatar
    Dec 08 2016
    Texas
    People paying hundreds for something any novice can do, is beyond me..
    I did mine 2 years ago with the following items off Amazon and it has held up very well. I use a power washer on my car when I detail it every other week, hasn’t peeled off yet.
    For anyone wanting to save hundreds, here’s some quality vinyl film & precision knife.
    3M 1080 G12 GLOSS BLACK 5ft x 1ft (5 Sq/ft) Car Wrap Vinyl Film https://www.amazon.com/dp/B007EEU58W..._Y5cdCbTR7FNCQ
    VViViD Stainless Steel Precision Cutting Knife with Lockable and Replaceable 30 Degree Acute Angle Blade Specially Designed for Automotive Vinyl Wrap Material https://www.amazon.com/dp/B014GC2YLA..._29cdCb5RMMABK
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    I disagree that Plastidip will look like shit. If you take your time (I spent roughly 2.5 hours total) it can look very good. I realize the picture isn't an up-close but it is an option that can come out nicely if you have a little patience. Wrapping certainly can produce a nice result as well but for someone who doesn't mind taking a little time to try something themselves, it's a viable option.
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Senior Member Two Rings jcpowell's Avatar
    Oct 18 2017
    Somewhere, GA
    Vinyl is probably your cheapest and best quality route if you DIY. Mine took me about three hours but most of that was getting the hang of it, if I had to do it again it would go much faster. I did gloss black (on black car) with Vivvid brand vinyl off amazon and a little tool kit. Still looks flawless after a year.
    2018 Brilliant Black S6 Prestige | APR Stage 3+TCU & downpipes | SRM RS7 Turbos | H&R Sway Bars | RS Grille | Sport & Black Optics Package, Alcantara Headliner
    Active Member Two Rings Edmeister's Avatar
    Mar 28 2014
    Pflugerville, TX
    Vinal tape.
    Sent from my Pixel using Audizine mobile app
    Established Member Two Rings eurotuner123's Avatar
    May 15 2017
    1999 Audi A4 2.8 Sport (RIP) | 2010 Audi S4 Prestige Stage 1.5 (RIP) | 2014 A4 Allroad Stage 2
    Chicago,IL
    Quote Originally Posted by jcpowell View Post
    +1 on this. I also used this stuff and wrapped the trim. Looks OEM to me and I love it....however, I stupdily removed the metal from the rubber part of the trim and now I can't get it back on lol. I only did this on the lower door pieces thinning it would be easier to wrap.
    Anyone else make this mistake and if so what is the best way to reconnect it with the rubber trim pieces? Should I remove the rubber as well to snap the metal back on?
    Sent from my LG-H931 using Audizine mobile app
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    I had mine done in vinyl last year for $150 and I got what I paid for. I highly recommend finding a reputable shop and even checking out their other work first.
    If you attempt to DIY, I have found that 3M is much better than the Vivid stuff. YMMV
    Dip has come a long, long way. I wouldn’t rule it out if you have a solid shop locally.
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Oct 18 2017
    Somewhere, GA
    I really don’t see a reason why you’d pay anyone to do it unless you just don’t have any free time, guy quoted me $700 lol..told him to kick rocks.
    Aug 23 2011
    NH
    I personally find vinyl work to be a gigantic pain in my balls. To each their own
    Oct 10 2018
    FL
    for you guys that did the vinyl yourself, did you use the std 3m vinyl or the 3m air release stuff?
    Dec 08 2016
    Texas
    Quote Originally Posted by mpk1996 View Post
    Link I posted is for air release channels. Definitely recommend this option for minimizing any bubbles.
    Apr 02 2014
    where are you planning on getting it done? i still need to do mine as well. thanks.
    Oct 31 2018
    san diego
    Quote Originally Posted by bmoreS4 View Post
    How much did you pay and how long has it lasted?
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I just got a quote to chrome-delete wrap my Monsoon Grey Q5. Door Blades, Trunk Blade, Roof Rack, and Door Handles in Monsoon Grey. Window Trim, Fog Rings, and Grill in Black. They want $1135. I'm going to give it a shot by myself. I quit recently quit drinking and think this could be a satisfying project for me.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Apr 27 2011
    MD
    I had all the window trim and fog surround trim done, also installed new rear OEM rings.
    $250
    Had it for a year with no issues and he matched the stock black trim really well.
    IG: @s4dad
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    AutoDip Spray. Much higher quality than Platidip and it shows in the final finish. It can be had in a larger variety of finishes and colors too.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    Shadowtrim vinyl. $25 and 45 mins of your time. Its easy do it yourself.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by raudiace4 View Post
    Do you have any close-up photos of this? I would be willing to give it a shot if the finished product looks convincing.
    SOLD 2015 Daytona Gray S4
    Nov 06 2013
    Quote Originally Posted by SteveYem View Post
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Apr 04 2012
    MSP
    Or you can just buy an A4 if you're going for that look
    Senior Member Three Rings rvcahawaii808's Avatar
    Mar 18 2017
    Portland, OR
    how do you guys wrap the trim on the small window in the rear? that corner absolutely fucked my vinyl strip when i was trying to do it. mine came out great except for that curve.
    Nov 06 2013
    Yeah the rear curve on the trim is a bitch to wrap, took me couple tries but this was the 3rd S4 I’ve done it to so I had some practice
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Feb 12 2018
    Terrebonne
    I blacked out my window tims DIY, very easy to do if you're careful and patient but pretty hard to get it ''perfect''. Watched alot of ''ckwraps'' on youtube. Before you start you need to know you'll have to use a blade on the car to cut vinyl, there's risk there to cut paint, other trims such as rubber seal which you dont want to cut open you'll get all kind of water leaks inside (rubber is pretty tough and thick). The other important thing to know is prep, you'll have to tuck the vinyl inside or behind the trim with a squeegee so you need to clean the shit out of everything in and out with such light brush. I had remaining water in the bottom rubber and behind some trim so it didnt stick perfect in some area. Bumper accent were pretty easy to me with a heat gun. Stretching and bending the material can be a nightmare if you dont know much. Overall im glad i did it myself i might do it all over eventually. The blade part was the hardest for my OCD level when it comes to damaging my car.
    tips and material ;
    I used vivid chrome delete pre-cut gloss black 40 FT (20 isnt enough)
    Cheap heat gun and delicate exacto.
    Perfectly clean and DRY use a blower if you have one
    Rubbing alcohol as last step before applying.
    the vinyl itself can get scratched and swirled.
    brillant black 2015 ; 034 stage 1 | AWE touring 102mm black tips | Modded airbox | KW V1 | 034 rear sway | CF trunk spoiler | ECS rear diffuser | stance SF01 19x9.5 et38
