Results 1 to 7 of 7
    Dec 06 2018
    Detroit, MI
    Going up one sidewall size to 245/50-R18 Winter Tires on 2017 A6
    Good evening,
    With winter upon us in Michigan I decided to purchase a set of winter tires. I was planning to get 235/50-R18s vs. the standard 245/45-R18s to get a little bit more sidewall to protect against potholes. However, I mistakenly bought 245/50-R18s which came today. Looking at tire comparison tools it increases the diameter by 0.9", or 3.3% vs. stock (245/45). Are these tires too big, or should i be fine with utilizing them? It was my mistake, but I don't want compound the problem by trying to save some money by keeping them and causing more issues.
    Thanks!!
    Established Member Two Rings Slickn's Avatar
    Apr 08 2012
    Massachusetts
    I run 255/45/18 for my winter tires. I ran the tire size comparison between my size and yours... It's a .6" difference in height... So .3" more in each direction. There should be no problem fitting .3" of extra tire in there.
    Good luck,
    Nick
    Sent from my XT1635-02 using Tapatalk
    2014 Audi A6 3.0t Prestige - 20" sport. EPL stage 2. Eurocode sway bars.
    2001.5 Audi A6 2.7t - K04/997 hybrids tuned by EPL.
    Dec 06 2018
    Detroit, MI
    Thanks for replying. From the photo it looks like the clearance won't be an issue. The local tire shop which i was going to for getting them mounted advised against installing them because it was more than 3% larger than stock (that was their cutoff).
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    You will have some speedometer error that is all.
    Dec 02 2021
    Colorado
    Did you ever end up trying this size? I'm about to buy winter tires and am trying to decide between 255/45r18 and 245/50r18. Much better selection available locally in the latter size.
    Established Member Two Rings 5000S's Avatar
    Aug 26 2020
    Both will work easily, but with winter tires, a narrower tire, "45" will be better on ice or snow, the 255 is a bit taller also, both good things.
    Established Member Two Rings pstuu's Avatar
    Jun 18 2019
    Jersey
    Quote Originally Posted by Slickn View Post
    Good luck,
    Nick
    +1 for 255/45/18 in the winterIMG_2946.JPG
