Results 1 to 16 of 16
    Veteran Member Four Rings BlkS5's Avatar
    Nov 20 2009
    2017 Tesla S Loaded
    La Quinta, CA
    Waterpump Replacement Cost?
    Audi just called, they are doing the piston/ring replacement on a 2011 2.0t A4. They said the water pump is showing signs of leaking which I had no problems before. Anyway while its apart they are saying I should replace it. $1,000 wtf? They said its normally $1,400. Are they jacking me?
    2007 A6 , Blk/Blk/Sport - Traded for S5
    2009 S5 6M , Phantom Black/Tuscan Brn/Loaded - Totaled
    2009 S5 6Tip , Phantom Black/Blk/Loaded SOLD - 30* tint/KW ADS Coil Overs, Überlegenes Stabilisatoren System/RS5 instrument trim/ClearBra/BB Sport Exhaust/AWE S-filter/Hoen zenon/Blk Ops Grill & Valence/LoJacked/trunk panel net/led's & 42 Catch Can
    2011 A4 2.0 TQ Premium Plus/Brillant Black/Blk/30* tint/back up cam
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by BlkS5 View Post
    gee I dunno .. you be the judge :)
    https://www.genuineaudiparts.com/par...&siteid=214407
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Nov 20 2009
    2017 Tesla S Loaded
    La Quinta, CA
    Yep, without any lube.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    I would tell your SA that if the tech doing the engine job can't swap a pump with the engine out in 30 min, then you want a trained tech, not the car wash guy they seem to have assigned.
    2011 A4 Avant
    Apr 30 2014
    Phoenix, AZ
    They are most definitely trying to power fist you, the engine is out and disassembled all the stuff they will charge you for ( labor wise ) has already been removed ( intake mani, etc) . It’s a pure scam, chances are if the dealership is shady enough to try thisthey eont even replace it since you won’t be able to see if it’s new or not after they reinstall the engine. Just my 2 cents
    -DaGerman
    Aug 17 2015
    California
    They're likely just trying to make a profit on the piston job. Your waterpump may very well be due for replacement depending on your mileage, but like said above it should be pretty easy for a technician to do that while the engine is out. You should pay for parts and maybe 30 minutes of labor. The pump itself can run you $200 or more from the dealer (can be found for cheaper online).
    Think of it this way: the piston work will be reimbursed fully by Audi. If they sell you on a $1000 waterpump, nearly all of that money goes directly to the service department's bottom line.
    Ask them if they can do it for parts + 30 min because that's all it's worth.
    Junior Member Two Rings Cirikon23's Avatar
    Jun 30 2018
    Hartford
    They’re jacking you my guy, I have the exact same car and everything. When they did my piston job they said the same thing but they said i will only have to pay for the part. So I only payed like $412 and that’s with tax
    Jun 30 2018
    Hartford
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    At this point I dont think there is any benefit to having the dealer replace the water pump. When the engine repair is done take it to a reputable Audi specialist and have them look for “signs of leaking.” If it is leaking go ahead from there.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Aug 19 2016
    Newport Beach/CA/USA
    rip job. at the absolute max i would pay is $500 and even then there is still a little screwing going on.
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    $1400?! I would have laughed at the guy.
    Call another dealer not associated with the one you are at and ask them the price to change a water pump on a 2011 a4. I'd even do it on speakerphone with the service manager, then ask him why they are charging so much more when 95% of the labor is already done. After that I'd call AoA and tell them what's going on.
    Dealerships ripping unsuspecting people off like this is complete BS and it needs to be dealt with.
    Even the guys saying they paid $450-$500 to replace the water pump in the same situation got screwed just not nearly as bad. Should be $75 in labor plus the part cost. Roughly $300 plus tax.
    2011 A4 Avant Prestige S-Line
    Sep 03 2014
    2014 Audi Q7 Premium Plus, 2014 Audi A4 2.0T Quattro S-Line
    Ellicott City, MD
    I love getting quotes from dealership service departments because they're always good for a laugh. When I tell them I can do it for a fraction of what they charge they always say that they use genuine OEM parts. That's when I look them in the eye and inform them that it was a genuine OEM part that failed. Of course, I wouldn't use anything other than OEM parts, but they don't have much to say after that.
    Jan 03 2013
    Baltimore
    I believe I paid 800 total for my water pump at a local shop. They did the job with the engine still in the car and intake manifold attached.
    Sent from my Pixel using Tapatalk
    Nov 20 2009
    2017 Tesla S Loaded
    La Quinta, CA
    Thanks for all the feed back.
    Nov 20 2009
    2017 Tesla S Loaded
    La Quinta, CA
    Quote Originally Posted by captain_video View Post
    LOL, best line of the day. "It was an OEM part that failed" can't wait to use that!
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Wow, when my stage 2 was done they went ahead and just replaced mine free.
