Results 1 to 19 of 19
    Active Member One Ring -C-'s Avatar
    Jun 18 2018
    Wheaton / IL
    Mk3 TT steering wheel retrofitted to my Mk2 TT finally !
    Well it took a while to get all the parts but it’s all
    Done and
    Works great!!!
    Found some great guys along the way and had amazing prices for the parts. And want to thank them.
    Modernizes up the interior nicely and now waiting on the WiFi chip so that the start button can be used instead of the key!!!! Hopefully it will be ready soon!!!
    The wheel works great with the aftermarket stereo with the voice button working SIRI and apple car play makes it so worth it! Love love love it!!!
    Next up is adding the keyless push button and keyless entry! More to come!
    Senior Member Three Rings goodhews's Avatar
    Sep 20 2008
    ridgeville in
    DETAILS?!?!?!?
    Direct fit? What buttons actually work? I thought mk3 used a single stage and mk2 used a dual stage?
    Been contemplating doing this for a long time. Great job!
    Jun 18 2018
    Wheaton / IL
    Quote Originally Posted by goodhews View Post
    DETAILS?!?!?!?
    Hey sure thing, was away on a business trip and didn’t get around to doing a writeup. I’ll post some info later tonight.
    Veteran Member Three Rings jcs4's Avatar
    Jan 06 2005
    98 m3, 92 3000gt
    Chicago
    would that wheel work on a Audi c7? Awesome mod
    2014 S6
    2018 Alfa Giulia QV
    2004 S4
    07 911 Turbo
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Huge improvement. I need to add this to my list :)
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Jun 18 2018
    Wheaton / IL
    Copy
    Jun 18 2018
    Wheaton / IL
    Quote Originally Posted by -C- View Post
    Mk3 TT wheel retrofit info
    After talking with my lawyer and his thoughts regarding this mod I’m going to just relay the information that you guys can use to acquire the parts. Luca is located in Italy and has a business where his experience can assist you in wiring up your vehicle.
    It’s fairly simple and not that big of an undertaking.
    (DISCLAIMER)
    Due to the nature of This mod and your safety it should be done at your own risk and I cannot be held responsible in any unintended outcome were to transpire.
    If you want the wheel please contact Karol @
    [email protected].
    Best deal on the steering wheels I could find, hundreds less than on eBay and a great selection of wheels, the less optioned wheels are much cheaper as well.
    Say christian sent you and Karol will hook you up !
    For the dongle to tap into the signal conversion so that the new wheel button signals can work with the car please contact Luca @
    [email protected].
    He has developed a small dongle that converts the high line to low line signal so that the older Audi’s tech can read the new signals from the new wheel.
    Other than that the wheel was pretty much an easy swap.
    If you own a soldering iron this will be a walk in the park.
    You also need a 2,2 ohm 1/4watt resistor for the airbag.
    Since every car can be different Luca has instructions and knowledge to help you re-pin your connector.
    It’s very simple. You will need your original yellow airbag connector and swap it to the new airbag. So you will need a pin tool to unlock the connectors.
    Below are some pics, I had to make the resistor wire for the airbag and a horn wire but that was it.
    (DISCLAIMER)
    As with anything regarding airbags you do it at your own risk and is not recommended, you know what your doing if you choose to continue. I cannot guarantee airbags will function correctly Incase of a car wreck so please understand this is at your own risk. And cannot be held accountable. I am aware of the risks that I am taking and you should two before doing this mod.
    Attachment 95703Attachment 95704Attachment 95705Attachment 95706
    Veteran Member Three Rings pretarion's Avatar
    Jan 02 2007
    Plano, Texas
    Paddle shifters on a manual car? Uh... No!
    2012 Audi TTRS Carbon Package
    Jun 18 2018
    Wheaton / IL
    Quote Originally Posted by pretarion View Post
    Mines a DSG ! :p.
    However you can remove them ;).
    And this isn’t for everybody.
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    wow! Very cool especially once you get the stop start button working
    Currently
    2015 Audi Q5 3.0TDI S-Line, Malone stage 2 with Deletes
    Previous:
    -2013 Audi S4 3.0T S-Tronic Teknik
    -2010 Audi S5 4.2L 6MT
    -2008 Audi TT 3.2L S-Tronic
    -2007 Audi A4 3.2L S-Line 6MT
    Jun 18 2018
    Wheaton / IL
    Yea I have the i key coming from DGD
    https://www.digitalguarddawg.com/key...tomotive/ikey/
    I’m pairing it with the WiFi switch Luca is making for the start button so it will truly be a keyless system with a functional start button on the wheel. :). Very excited !!!
    Jul 24 2018
    Cincitucky
    That's really neat. Not that I don't like the wheel on my MKII... but.. niiiice.
    Jun 18 2018
    Wheaton / IL
    Jan 09 2020
    Greece
    Hi there bro...except the steering wheel and the airbag did you get anything else to make the retrofit?
    Στάλθηκε από το SM-N975F μου χρησιμοποιώντας Tapatalk
    Veteran Member Three Rings Jayblack9397's Avatar
    Dec 04 2019
    00’ Laser S4 rs6r, 00’ Nogaro S4 Tial 605’s
    Houston
    What stereo are you running? Stock one is awful
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Mines a DSG ! :p.
    So you can remove the paddles...are you also able to remove the Drive Select or Start/Stop buttons?
    Also curious, any idea if iKey works with a manual trans?
    Nov 15 2020
    Mone, IL
    Any update on this??
    Veteran Member Three Rings Del Mar's Avatar
    Mar 26 2020
    Too many cars to list.
    YYZ
    Bump
    Sent from my Pixel 2 XL using Audizine Forum mobile app
    Jan 17 2021
    Italia
    hi, i own a tts 8j my11, i ordered a pair of r8 Style wireless buttons (not original) but identical to the originals;
    1) what do you recommend to make the red button work with the key?
    2) what do you recommend to be able to connect the black button to my sport button?
