Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Revision: -------- Serial number: --------------
Coding: 65A6D649A6656B921B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41CA8EC2D0D4D0429A-8014
1 Fault Found:
161536 - Tire Pressure Warning
C102D 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FR HW: 4H0 907 064 ER
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 0DA86F4E000000000000
VCID: 7EB0353EE9AA6FBAA7-802A
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3215000079239004
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 90
Mileage: 66811 km
Time Indication: 0
Date: 2018.11.21
Time: 19:29:29
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008002
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F2ED87A764056327C-807A
3 Faults Found:
455688 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Date: 2000.00.00
Time: 00:00:00
455690 - Sensor for Ride-Height
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 66027 km
Date: 2018.11.16
Time: 17:23:10
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 66027 km
Date: 2018.11.16
Time: 17:18:37
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0366822884
Coding: 01061E3A003A408583B0080402070E47000000000000000000 0000000000
Shop #: WSC 06342 000 00000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000288835
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST0009C5SI00000
Coding: 101F02
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93508895
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 62972 km
Time Indication: 0
Date: 2018.09.17
Time: 11:38:53
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 135
Mileage: 62972 km
Time Indication: 0
Date: 2018.09.17
Time: 12:05:21
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 HW: 4G1 035 025
Component: MU-H-LNS-US 040 0143
Serial number: A278D0FB014075
Coding: 017551020000000013220002041A00102F0007E5F1700104FE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 5BF65CAA52789A92E0-800E
Data medium:
Subsystem 1 - Part No SW: V03 959 801 GC HW: -----------
Component: NAR 2015 --- 0035
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9FY801HD1
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349OE40005A
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3006
1 Fault Found:
0020 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 132
Mileage: 62957 km
Date: 2018.09.17
Time: 08:27:55
Voltage terminal 30: 12.1 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H09 0008
Revision: 00001001 Serial number: 97811005109602
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X_AU57.rod
VCID: 281C336653AE010ABD-807C
1 Fault Found:
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 142
Mileage: 63109 km
Date: 2018.09.20
Time: 12:42:25
