Results 1 to 40 of 59
    Sep 25 2018
    Frisco, TX
    Radar detector mount location ideas
    Hello all,
    Our city has a lot of LE presence, so planning to hard wire a radar detector, most probably will be a Uniden R3. The blendmount is a good solution, but almost third of the price of the detector itself and also the mirror is already low, so will mount real low. Also mounting it on the windshield above the mirror will hinder the sunglass holder opening. When I was shopping, came across a S4 listing and stated it has steath/hidden radar detector mounted. So would like to see all your suggestions for other alternatives.
    Thanks in advance.
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Well mine is right here. Mostly due to laziness. The wiring run was so short. Placement isn't bad IMO either
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    Keep in mind my Uniden R3 is hardwired but here is my setup. Yes this placement will slightly reduce rear radar dection but I can live with it. That clear thing in between the mirror and detector is to keep it from bouncing as I have a rear facing dash camera attach below the detector. From the outside this is not very noticeable, but I do have a all black interior.
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
    Sep 25 2018
    Frisco, TX
    Quote Originally Posted by Morritse View Post
    Lol, I too have it in a similar location in my other car, same reason, lazy. Thanks.
    Sent from my SM-G955U using Audizine mobile app
    Sep 25 2018
    Frisco, TX
    Quote Originally Posted by mys4.org View Post
    Awesome, thanks for the photos. Is that a blend mount? And the reason for the dashcam facing rear?
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    2012 S4 (sold)
    Senior Member Three Rings rvcahawaii808's Avatar
    Mar 18 2017
    Portland, OR
    Here's mine. Uniden r3 with fuse tapsIMG_20171102_232951.jpegIMG_20171102_233010.jpeg
    Sent from my Pixel 2 XL using Audizine mobile app
    Sep 25 2018
    Frisco, TX
    Thanks for the link.
    Sep 25 2018
    Frisco, TX
    Quote Originally Posted by rvcahawaii808 View Post
    I like this idea using just the suction mount near the rearview, gives you an option to relocate unlike blend mount. Thanks for sharing.
    Jan 14 2018
    Audi
    Do you guys leave your radar mounted when the car is parked? I don't since don't want to entice shady ppl to break in.
    Established Member Two Rings Atrevido's Avatar
    Mar 19 2018
    Florida
    I mounted mine high on the windshield and just to the left of the mirror. It's hard to see from the outside. No problem getting to the sunglass holder, and I always remove the V1 when leaving the car.
    No reason to leave it baking in the hot Florida sun.
    Below is my post for a custom built Valentine V1 mount, but you can use the same basic idea for making your own custom R3 mount.
    https://www.rdforum.org/index.php?threads/78354/
    2013 S4 / 6MT / Phantom Black / APR Stage II Single Pulley / Sports Diff / RS4 Grille / Sachs Performance XTend Clutch / ECS Lightweight Flywheel / ECS Transmission Mount Insert
    ECS X-Pipe / K&N / Modded Air Box / CR-15 / Osram CBI 5500K HID / Zimmermann / Akebono / Pirelli P Zero AS Plus 3 / Hard-wired Valentine V1 Gen 2
    Sep 25 2018
    Frisco, TX
    Quote Originally Posted by Atrevido View Post
    I am thinking about the same location, but using this https://www.ebay.com/itm/1x-Permanen...72.m2749.l2649
    Thanks for confirming the access to the sunglass holder, the above solution is permanent unlike the suction cups. In Texas, I have found it hard to keep the suction cups lose their grip and do not want the radar dropped. Your solution looks creative as well. Appreciate it.
    - - - Updated - - -
    Quote Originally Posted by gmurom View Post
    Currently, I leave it on the dash with a removable pad and leave it in the cubby.
    Mar 19 2018
    Florida
    sailakfan,
    I also got tired of the suction cups losing their grip and having the radar detector suddenly drop. No fun when you're on the highway!
    I considered an Ebay solution like the one you mentioned, and it certainly could meet all your needs. Just remember the radar detector must be as level as possible for maximum range.
    Will you be able to bend the mount if necessary? Just food for thought.
    Good luck, and let us know how it turns out!
    Aug 27 2014
    Sandy Springs, GA
    Exactly how I have mine
    2012 S4 (sold)
    Established Member Two Rings Dewar's Avatar
    Feb 17 2018
    Michigan
    Use the V1 visor mount and concealed display. Had to put some cloth between visor and roof to get it parallel.1543194614435.jpeg1543194644628.jpeg
    Sent from my Pixel 2 using Audizine mobile app
    Jul 20 2011
    C8 Z06 Soon.
    Raleigh, NC
    I went more custom / stealth. Went with the Beltronics STIR Plus.
    Cannot see anything anywhere. Installed a cutoff switch to turn off if I get pulled. Requires a professional install though.
    Harry P
    IE 80mm Throttle Body kit, IE TB and Crackle Tune, Jokerz Perfromance full S/C Port, APR 57mm SC Pulley, JHM 187mm OD Pulley, APR CPSv1 and Pierburg CWA 100-3, AWE Touring, GESi downstream cats, JHM Short Shifter, Southbound Stage 3 Clutch (600 tq), ECS Stage II Big Brake Kit, USP Metal Slave and SS Clutch Lines, Vorsteiner VFF-103 w/ H&R 5mm spacers.
    Jul 20 2011
    C8 Z06 Soon.
    Raleigh, NC
    Quote Originally Posted by hgparrish View Post
    I’ll take pics tomorrow but everything installed in the ashtray so door can close to hide it if pulled over. Rdd unit installed in engine bay. Installed Laser Interceptor jammer with 4xsensors as well.
    Harry P
    Dec 18 2007
    PNW | Monroe, WA
    Quote Originally Posted by sailakfan View Post
    No, stock mount that came with the R3
    Sep 25 2018
    Frisco, TX
    sailakfan,
    Hello, sorry for the late response, have been travelling today. I will let you all know how it turns out if I decide to go that way.
    Sep 25 2018
    Frisco, TX
    Quote Originally Posted by Dewar View Post
    Like the stealth visor mount, thanks for the pics.
    Sep 25 2018
    Frisco, TX
    Nice, thought about it, but could be way out of my budget. Thanks for the post and awaiting your pics.
    - - - Updated - - -
    Thanks.
    Mar 18 2017
    Portland, OR
    fwiw i dont use this suction cup mount anymore. i use the regular 2 suction cup one it came with. it has never fallen. this one fell off twice so i stopped using it.
    Sep 25 2018
    Frisco, TX
    Thanks, will try the suction cups for a while and see how it holds up.
    Established Member Two Rings rcz22's Avatar
    Aug 19 2015
    2014 Cherokee Overland, 2011 Ducati 848 EVO
    New Jersey
    I have my R3 mounted with suction cups (that it came with) right to the left of the rear view mirror (but out of the way of the sunglass holder) and I piggy backed off a fuse off the driver side fuse panel. For all those who mounted it down below or at the bottom of the windshield, doesn't that block radar coming in from the rear? I thought we had to have clear line of sight or as close to it as possible.
    2014 S4 / Moonlight Blue Metallic / Prestige / Navigation / B&O / JL10W6 custom enclosure + Alpine Amp / Black Optics / Sports Differential / DSG | 19" Peelers / Ziza LED Interior / 35% Tint / VLED VX3 Fogs / CR-15 /
    AWE Touring Exhaust / ECS Luft-Technik Carbon Intake
    Feb 17 2018
    Michigan
    V1 manual says to mount high.
    Apr 25 2016
    Bronx/New York
    I don't have much experience with radar detectors, what is the best radar out in the market currently? My current budget is around $500.
    Mar 28 2016
    Quote Originally Posted by armandogee View Post
    Uniden R3, Escort Max 360, radenso Pro M, among others.
    EDIT: If I had $500 to spend on a detector, it would be the radenso Pro M. They (radenso) are the best at limiting false alerts, and the Pro M is tiny in comparison. I am about to pull the trigger on the radenso XP after much research (I don't really want to spend as much as the Pro M costs).
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Great resource here to get you started.
    The V1 was the benchmark for a long time, but it's development has stayed static for some time, so other brands have begun to surpass it. I have run a V1 mounted on the passenger sun visor and hard wired, for several years now, and am still happy with the performance.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Aug 27 2014
    Sandy Springs, GA
    R3 seems to beat pretty much everything in tests, it’s saved my ass a few times.
    2012 S4 (sold)
    Jul 02 2013
    Quote Originally Posted by 4RCFED View Post
    The R3 is definitely hot shit in the detector world right now. If it had Arrows like the V1, I'd be all over it. At least for now, the V1 with custom sweeps set-up and the V1 Driver app, is still good enough for me.
    Dec 18 2007
    PNW | Monroe, WA
    For the heck of it I ran a Uniden R3 up front and a Uniden R1 in the rear on a summer road trip. And this was in a suv so they weren't causing each other to false. I was detecting stuff miles away before it would even show on Waze. I had to take down the rear one as it was simply overkill.
    Best spot for info on all the top rated radar detectors are on https://www.vortexradar.com/
    Mar 28 2016
    Their top 3 is the exact list I posted, in the same order.
    Sep 25 2018
    Frisco, TX
    Quote Originally Posted by hilmar2k View Post
    Nice, I too had these three in my final list when I narrowed it down to the R3.
    Mar 18 2017
    Portland, OR
    Quote Originally Posted by sacandagaD View Post
    yeah. sometimes i wish the r3 had arrows. but its pretty rare that i actually need them. once in a blue moon ill get a ka hit and i cant find it. but i just chalk it up to him sitting somewhere with i/o.
    Active Member Two Rings autologic's Avatar
    Dec 03 2017
    06 Powerstroke F250 4x4 | 2016 Q5
    Sonoma County
    I went with mirror mount for best signal pickup and power source. I have an Escort 9500ix and found better price mount on Amazon for $32.29 and power cable for $18.99. They have brackets for most popular detectors. Fit was fine and mount looks clean. Way cheaper than Blendmount.
    Radar Mount Mirror Mount Bracket for Escort Radar Detectors - Escort 9500ix, 8500x50, Solo S3, Redline (3001001)
    Radar Mount Mirror Wire Power Cord for Escort Radar Detectors With Inline Fuse RJ11 (3005201)
    Mar 15 2017
    Iowa
    I have a V1 that mount under the middle headrest in the back using an enclosure I made. Then I'm using a VEI gauge pod upfront as the concealed display (still need to tuck the wires away better)
    Sep 25 2018
    Frisco, TX
    Quote Originally Posted by 7786 View Post
    That is really creative and never thought about the middle rear head rest, thanks for sharing.
    Veteran Member Four Rings if6ws9's Avatar
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    Quote Originally Posted by autologic View Post
    Which model do you drive?
    2014 A5, Gloss Boat Blue, Black Optics, Sport package, MMI+, B&O, AWE Touring, AWE DP, USP HFC, CTS CAI, APR Stage 2, ST Coilovers, Alu Kruez, 034 TX insert, ECS diff bushing, Apikol blue diff mount, VAG's, Escort Redline, ZR4 shifters, 20% tint, Sprint Booster, ECS dipstick, FB steering wheel, piston diverter valve, ECS rear lower control arm brace, 10mm & 12mm spacers, BFI shift knob, CR 15, powder coated calipers, extended paddles, Vossen CV3-R's, Eurocode F&R sways, RS grille
    Senior Member Three Rings Robdukes's Avatar
    Dec 11 2014
    01 Audi A4 2.8 Quattro
    Mount Cobb, PA
    Went Uniden R3 with blendmount and mirrortap. The R3 has multiple colors for the LCD and the orange matches the MMI nicely. I was pulled over once with it on under a case of mistaken identity (cops were looking for a guy in a "blue sports car") and the cop and his partner said nothing about the detector. Looks more OEM i think mounted on the mirror and matching color of lighting.
    Sent from my SM-N960U using Tapatalk
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Yes. For many years now. Valentine. I don’t live in a bad area though.
