tested the fuel pump and it runs no problem when supplied 12v ( reading was at 350ish psi after priming with power probe), checked the plug and get no reading. checked the fuse is good, but not getting 12v with ignition on or while cranking. checked all the relays under the cowl, under kick panel ,and in trunk compartment ( I cant find where the fuel pump relay is suppose to be)and they are operating as should and have 0.000 resistance (good). I cant find any wiring diagrams at all for these cars for the fuel system.
Am I missing something?
P.S. I have an idea why the engine appeared to be seized (coolant leak), because even after i got it to crank over many times without a hiccup, as soon after priming the fuel system with the power probe and getting rail pressure it sputtered and locked up again, so i removed a coolant line and pressurized the cooling system with air to evacuate any remaining coolant in the system and attempted to start it and again without an issue it cranks but still no fuel pump or pressure. - I was wrong
SOLVED: It ended up being the fuel pump control module. The reason I believe it to have been locking up was due to the pressure build up in the HPFP (high pressure fuel pump). With the HPFP being run off the cam it would hydrolock the HPFP piston and stop the engine due to the timing chain running the cam. There was no coolant leaks into the engine, the PVC had no coolant leaks and the supercharger held pressure.
