The B8.5 version of the 3.0T coolant pump has the additional N489 "coolant valve for cylinder head" solenoid. This is pointed out in the workshop manual, Exploded view - coolant pump and thermostat. According to the manual, it's located right below the bank 1 vacuum pump at the front of the head, pretty much just to the left of the coolant pump.
The Audi SSP on the EA837 3.0T (PR-TC6) is for the original version in the B8.0. But the Audi SSP on the EA837 evo 3.0T (PR-TM8, the CRE) does cover this modification, referring to the coolant pump as "switchable coolant pump". The evo (CRE) calls it a N492 and locates it in the back row of vacuum solenoids, but the coolant pump management seems to be the same.
But that is a presumption. Though they look the same and are the same base part number, the TC6 switchable coolant pump is a different revision letter chain than the TM8 switchable coolant pump. Regardless of the location or the electrical schematic designation, the electrically controlled vacuum solenoid is the same part number in both cases, 037 906 283 C. Failure exhibit is pointed out on page 31 of the SSP 624. I don't know if the
The wiring diagram for the B8.5 3.0T seems to also confuse Cylinder Head Coolant Valve -N489- with Engine Temperature Control Actuator -N493-, I presume it's calling both objects the same. Is the wiring to the solenoid, whatever you want to call it, red/white on 1 and yellow/green on 2?
To RPM's question, the quick glance assessment is that the presence of vacuum at the pump displaces the diaphragm covering the impeller, so no coolant flows. The solenoid passes vacuum when energized. The ECM uses PWM signal to energize the solenoid at whatever duty cycle to pass a net level of vacuum to the coolant pump, depending on how much vacuum, if any, it wants to transmit. Lack of vacuum at the coolant pump means the spring force pulling the diagram from the impeller "wins", and max coolant rate flows into the cylinder head.
I'm assuming the solenoid is closed (no vacuum transmission) on no electricity; this would be simple enough to test with a vacuum pump and an output test for the solenoid in 01-engine.
