2000 Audi A4 1.8T Quattro 5MT
No auto scans yet.
I've been having issues trying to program the key fob. It is an eBay 3 button key fob. The car only came with the valet key. The key fob did work initially and was able to successfully program it to the car, this was around March shortly after purchasing the car. Been having issues ever since the trunk area where the module sits got flooded due to a disconnected sunroof drain hose (car is parked outside). I did my best to dry it out and clean the corrosion off the board and the connector housings. I don't know how long it was underwater for. Fast forward to last night and I installed a CLM from the junkyard. The part number of the new module is the same as the old one (8L0 862 257 N). I also grabbed the pigtails and connectors from the car in the junkyard, but have not replaced them yet.
With the new CLM installed, I changed the soft coding to what it was on the old CLM (also changed the WSC if it matters). I've been trying to program the fob to the new CLM and been unable to do it using the following procedure:
When I do the initial part of the procedure the car gives no confirmation of any button presses and the door does not unlock with the fob. I have also tried to clear the CLM memory using Adaptation Channel 00. It says that it's saved successfully, but when I go to measuring blocks, group 003 it shows memory positions at 1111 (memory full, 4 fobs programmed).
I’ve checked the fob battery, it’s good (3.2v).
Also tried the output tests via VCDS and they’re all successful...
The new CLM didn't have any fault codes stored during all this either.
I don’t think the key fob is bad or anything because it was working fine before the CLM got flooded. I think my issue is with the full key fob memory positions.
With the weather getting colder here in Upstate NY, I have been having issues with the battery going flat while sitting outside. But during the above work, I had the battery hooked up to a charger with the car parked in the garage. I will be replacing the battery once it comes in at the dealer.
