Originally Posted by
AudiNike12
Yes, red and yellow still going to the same wire. Maybe that's the problem? Could that also cause the radio losing its settings? Haven't had the time to rewire it yet. Hopefully between Christamas and New Year
If it is losing power when the key is off/out then yes it would lose its settings.
On a car stereo (aftermarket) yellow will be constant hot and red will be switched, so if the yellow (paired with the red) is on some sort of switched source then you will lose power once ignition is off, why it is staying on after the car is off and not coming on when the car is off (if you switch it on I 'don't know)
So you need to wire the yellow aftermarket radio wire to a constant 12v power supply, the stock radio one should work for this. Likely a red with a white stripe wire.
For the red wire from the aftermarket radio you either need to wire it to the one in the blue connector mentioned by rollerton or or the 75x terminals under the dash to be switched with ignition (75x) or switched with ignition but stays on with the key still in you'd use the one from the blue cluster connector.
