Results 1 to 23 of 23
    Established Member Two Rings B8S4inKC's Avatar
    Jul 31 2018
    Lawn Mower
    Kansas City
    What kind of gas mileage are you seeing before/ after your tune?
    I was averaging about 23 mpg (mixed driving, mostly highway) before I got the EPL stage 1 tune. After flashing their 93 file (no other significant engine mods) my gas mileage has plummeted to around 17 mpg. I figured my gas mileage would go down a bit, but not that much. My friend that has an APR stage 1 tune averages 25 mpg. Anyone seen similar results?
    Current: 2019 S4
    Gone but not forgotten: 2011 S4 (6 MT)
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Its your right foot, your just enjoying it more.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    19-20 to 9.5MPG
    Mar 05 2014
    2020 SQ5
    PDX
    GIAC STG2. Have always been around 18.5-19.5 MPG.
    Unless I go on long freeway drives and it cruises up.
    2020 SQ5 Quantum
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    I got about the same before and after the tune. Maybe a smidge better mpgs post tune.
    Mar 28 2016
    Don't forget that in many areas of the country we are switching to winter blend gas. You lose 2-3 MPGs there. Maybe just coincidental timing.
    May 06 2015
    Minnesota
    EPL stage 1 here. No change in mileage after I tuned.
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Established Member Two Rings Jimcoily's Avatar
    Apr 06 2017
    4M Q7, Charger 392, OBS GMC
    Bremerton, WA
    I'm too lazy to do math but I had 264 miles when the gas light came on. APR UC
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    Most likely the "right foot" being used more. It's much more fun. When I drive responsibly, my MPG is about the same pre-tune. I'm UC'd now and get get 10-12 MPG if I'm having a really good time.
    +1 for the winter blended gas as well.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Apr 16 2017
    Illinois
    With a heavy foot with my current setup running the 91 octane Stage 1 tune, I saw about 20mpg.
    With that same heavy foot on E20 and running the Stage 2 tune, I am seeing about 17-18mpg.
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
    Mar 28 2016
    Quote Originally Posted by Bartlett View Post
    That makes sense. Less energy in ethanol, so the more of that you run the worse your mileage.
    Jun 04 2018
    Orange County, California
    With APR Stage 1, I was averaging about 24
    APR Stage 2 DP I’m averaging about 26
    I drive mostly hwy
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by hilmar2k View Post
    I swear I lose more like 4-5 mpg with winter gas here in NE.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Three Rings Corradobrit's Avatar
    Oct 27 2007
    TX
    Giac Stg1. Seeing about 10% better fuel economy post tune. Pretty much same driving style, route. 99% time drive on manual (S/M) setting
    2014 S4 Premium Plus, Glacier White Metallic, Black Optics, DSG, sport diff, Nappa, B&O, AWE Touring/Res DP, GIAC ECU Stage 1, ECS CF rear diffuser, CR15
    Oct 30 2012
    Oxford, MS
    Quite a bit worse but I'm having so much fun.
    Sep 20 2018
    Plumsteadville, PA
    Bought car Stage II+ so I don’t know stock at all but I can average anywhere from 12-27mpg on my entirely backroad drive to work 20 miles.
    Entirely dependent on your driving habits and available open roads to smash that gas.
    Had the car for two months and never been on the highway at all so I have nothing to compare there.
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Kinda shitty before. Slightly shittier after.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Established Member Two Rings Atrevido's Avatar
    Mar 19 2018
    Florida
    Typically around 20 MPG, but I recently took a road trip down to Key West where the speed limit is between 45-55 MPH, and this must've been the sweet spot!
    I had no idea I'd ever come close to 32 MPG.
    As others have wisely noted what really matters is how much your right foot comes into play. I try to behave . . . whenever possible . . . which is not often.
    2013 S4 / 6MT / Phantom Black / APR Stage II Single Pulley / Sports Diff / RS4 Grille / Sachs Performance XTend Clutch / ECS Lightweight Flywheel / ECS Transmission Mount Insert
    ECS X-Pipe / K&N / Modded Air Box / CR-15 / Osram CBI 5500K HID / Zimmermann / Akebono / Pirelli P Zero AS Plus 3 / Hard-wired Valentine V1 Gen 2
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I can still get about the same mpg on dual pulley as I did stock. I can get worse if I try lol. It's all in the way you drive.
    If anything, I would think you could get better mpg after a tune, IF you can keep your foot off the pedal. It's just too tempting not to.
    Sent from my SM-G965U using Tapatalk
    2021 Audi S4, P34 Intake
    Mar 12 2014
    Atlanta
    I commute ELP stg 2 and TCU tune. 300 miles per tank every week. Works out around 21 or 22 MPG based on my fuzzy math.
    Estoril Blue 2013 S4 / EPL Stage II / EPL TCU Tune / ECS Kohlelaser Luft-Technik Intake / ECS Wheel Spacer Flush Kit / CR-15 Upper Strut Tower Brace / Pioneer Subwoofer Upgrade
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    in the SF bay Area, none of my cars ever got great gas mileage. combination of my driving style, plus the hilly terrain, traffic, & our low density fuel. My stage 1 EPL car with 3 to 4 gallons E85 averages about 17 to 18, gets mid 20's on a full highway trip. got the same with my B5 and B6 A4 with a ton less power. don't think the tune affected it much, except for now I run the E85 mixed in, which lowers it a MPG or 2
    only way to get good mileage around here is with a hybrid or normally aspirated lightweight car.
    Jul 31 2018
    Lawn Mower
    Kansas City
    Thanks for all the replies. Guess I’ll have to try and see what I could get on a full tank driving conservative the entire time. Even though it’s real hard to do. I’ve only done about 3 pulls hard pulls on this tank. MMI says I’ve got 80 miles to empty so that math gets about 17 mpg. Just figured it would be better.
    Also was curious if EPL tunes result in worse gas mileage than others but I guess it seems consistent.
    Current: 2019 S4
    Senior Member Three Rings Jk79's Avatar
    Sep 20 2018
    Chicago
    Usually you should see an increase in gas mileage from a tune. These cars run pretty rich from the factory and the tune should lean out the mixture a bit. On a full tank I used to see an estimated 340 miles but after the tune it shows 370. Minimal increase for sure but an increase none the less. I can’t say I’ve been getting that as I do tend to push it a bit. I mean, that’s why the S4 with a tune is fun. There’s always a stretch of road worthy of a quick pull to keep the commute fun : )
    2018 RS5
    2014 S4 - EPL Stage 2+ (SOLD)
