Results 1 to 13 of 13
    Jul 29 2015
    Anaheim, California
    RS5 rear brake pads
    Sorry to ask but newcomer to Audi world.
    Can I replace the rear brake pads on my 2014 RS5 without a VAG tester?
    Will the electronic handbrake work after the replacement even if the dash light stays on?
    Thank you
    2014 RS5 Sepang Blue
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    If the rear pads are completely worn then you may need a plug in device to fully retract the calipers and adjust for the new pads.
    Jul 29 2015
    Anaheim, California
    D
    Quote Originally Posted by JamesRS5 View Post
    Thank you James. Do you mean to say I would not be able to push the rear caliper pistons all the way back with a C clamp like I did on the front brakes and other cars, without a connected VAG ?
    Feb 27 2014
    Dubai
    No, the electric rears have a motor driven caliper, as the brake pads wear the motor automatically adjusts to position the pads correctly. With VCDS you select the rear caliper to the service position where it will fully open the piston, when you deselect service it will auto adjust to the new pads thickness, you can also calibrate the caliper for the new pads.
    You cannot move the rear piston with a G Clamp, you may cause damage doing this.
    Jul 29 2015
    Anaheim, California
    Thanks again. I learned something. Now I have to decide whether to buy a VAG or ask the dealer to do the brakes. I would rather buy the tester if I can find a reasonably priced one. I am sure it will come handy in the future. (I guess my regular OBD2 tester would not work on an Audi. I have used it successfully on my NSX and GTR).
    Thanks again James!
    Junior Member Two Rings
    Aug 17 2018
    FL
    You could use obdeleven. Cost ~$60
    Jul 29 2015
    Anaheim, California
    RS5 rear brake pads
    Quote Originally Posted by ips_cou View Post
    Thank you. Just did some research. Looks like it only works with Android devices; my house has nothing but iPhones and iPads ! Looks like I would have to buy a phone or tablet just to use OBDeleven LOL
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Honestly, the VCDS is worth it in the long run. It pretty much does everything. Not always the most intuitive (thanks Windows!) but it is powerful.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Jul 29 2015
    Anaheim, California
    Quote Originally Posted by Ape Factory View Post
    Thanks. I am not planning any mods on the car and it is a CPO until 2021 with Audi care. Onviously the VCDS would be overkill for me...but having said that, it would be nice to have a cheaper alternative VAG to do simple things like rear brake changes, code identifications, resetting warnings.....etc.
    Feb 27 2014
    Dubai
    It’s always worth asking on here if someone local to you has access to VCDS, I have one with unlimited VIN and loan it out to guys in this area, it works on any of the VW/Audi group cars. If you’re planning to stay with the VAG brand for a number of years, they are worth the investment.
    Jun 24 2017
    San Antonio, TX
    Quote Originally Posted by Alexandros View Post
    This is true, especially if you don't have a Windows-based computer (or Bootcamp installed on a Mac). If you do have a PC, then $200 is probably close to what you'd spend on a used Android phone, Bluetooth dongle and the program. You can get a three license VCDS for $199 new. But I do agree, it'd be overkill for your needs.
    Aug 17 2018
    FL
    You could buy a galaxy S3(really overkill, but should be snappy) for ~$60 off ebay.. so all in ~1 hour the dealer labor rate and your set. Think of it as a investment into yourself. You can also reduce the number of times you have to walk into the stealership, bend over, and say '..right here'. Also, less worry about damage to your car. 9 out 10 times I get a new scratch...other than my wallet Plus you've already gone through all this effort.
    Jul 29 2015
    Anaheim, California
    Thank you. I was resigned to byuing a VCDS when a good of friend of mine who owns a race shop told me his pro shop tester works on VAG cars. I will use his this time to change my rear brakes but I think I will still purchase the 3-vehicle VCDS in the near future.
