Results 1 to 24 of 24
    Established Member Two Rings a4b7-sline's Avatar
    Oct 01 2018
    B8 S5 6MT, B7 A4 2.0T 6MT, Lowered '97 Chevy S10, Lifted '87 Chevy K10
    Scotland, Connecticut
    BWT 2.0TFSI Coolant
    I did some digging around and couldn’t find much.
    I bought my A4 from a private owner. The previous owner had taken the car to shops for service/repairs, so I’m assuming a garage did this. Long story short, my car has green coolant when I see most people have red coolant in their A4.
    My question is if I will run into any problems running on green coolant? About 2 months ago my water pump did seize which destroyed my motor but I don’t think it was related.
    Thank you
    Monsoon Gray B8 S5 6MT, Coilovers and Rotiforms
    Veteran Member Three Rings bwdysart's Avatar
    Sep 05 2017
    B7_A4
    Richmond VA
    I would probably flush it out and use the right stuff. G13 coolant is around $10/L found in pure 1.5L. Probably 2 but 3 just to be safe bottles of g13 is 4.5L for $45, then a bunch of distilled water from your grocery store should be less than $1/gallon. That’s all you’ll need to do a flush. https://m.youtube.com/watch?v=s--5ft5YiHg
    Here’s a video I really like on how to do a generic coolant flush.
    May 20 2010
    The biggest problem with green coolant is that if it meets G12/G13 (the pink stuff), it forms this weird sludge and turns a brownish color. That sludge is nasty and tends to block things up, such as the heater core. My C5 had this issue when I bought it. Most disgusting coolant I've ever seen.
    I recommend getting it completely flushed out (heater core too) and replaced with G12 or G13.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Oct 01 2018
    I had flushed it and replaced all the coolant when I rebuilt the engine last month, but I just started to notice others using the red. No sludge found, but listening to others I should probably do a flush and replace w the red
    Oct 01 2018
    Quote Originally Posted by bwdysart View Post
    That’s what I thought, but wasn’t sure if it was fine to run green and didn’t wanna waste money and time, but I’ll definitely do it. Thank you for the video/input
    Account Terminated Two Rings
    Oct 14 2018
    melville, NY
    tell me you didnt use g13 when you did the engine swap? it says it right on the cap! KID
    Quote Originally Posted by a4b7-sline View Post
    Oct 14 2018
    melville, NY
    idiotic. almost as stupid as me driving with low oil pressure when i knew i was suppose to pull over and tow to the nearest dealership...
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by joepickems View Post
    Nah Driving with no oil pressure is way more retarded than driving with the wrong coolant.
    If it's all green it's gonna work fine, the problem comes when mixing them. It says G12 on the coolant tank not G13.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Oct 01 2018
    Quote Originally Posted by Jay-Bee View Post
    Yeah it’s all scratched off where it says G12. I could only make out the G, so I just put G13 in since that’s what it had to begin with when I got it.
    Oct 14 2018
    melville, NY
    green coolant is not G13 so why would it be fine? i would not risk anything but G13 and isnt G12 discountinued from audi? i think i rememebr dealership saying they only carry G13 now.
    (driving with low oil pressure not a good idea. take it from me)
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    I have run prestone any make any model for years..my car has been green for at least 5 years and absolutely zero problems. Color doesn't matter... what it actually is and what the chemicals are compatible with is what's important
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
    Jun 27 2011
    I’d only use G12 or G13 compatible coolant. Pentofrost E is the non-Audi brand that’s easiest to find.
    There’s zero reason to not use the proper coolant. Zero.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Oct 28 2018
    San Dimas, CA
    New to the forum...
    Just picked a up an 07 A4 Avant. Right out of the gate I had to replace the thermostat which was stuck open (low temp during morning freeway runs was the indicator). Not too bad of a job but I'm glad I tackled it as soon as I noticed it because the system was filled with only water! I used Zerex G40 50/50 after doing a full drain so I'm happy now. G40 meets current specs but you're supposed to do a flush and fill if you're going from old G12 to the newer stuff to get the proper protection. With all the hoses and plastic manifold parts that are exposed to coolant you want to make sure you use the proper coolant. Stuff with high silicates (old school green) can abrade plastic parts and seals as I understand it.
    Oct 14 2018
    melville, NY
    low temp, do you mean your gauge was showing low when it should have been in the middle during drive on highway? i was wondering if my theromostat is stuck open because i have HOT air coming thru the vents into my cabin. its like i have the heat turned on in the car but i dont i have it switched off. only way to stop the heat from coming into the cabin is to turn on the AC. wondering how to fix this. b7wannabe said recirculation door is stuck open but not sure if that is related to my the HOT air coming thru the vents. car also makes loud buzz sound during startup and random "burps"when shut off
    Quote Originally Posted by ksw_92 View Post
    New to the forum...
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    agreed.
    luckily my gf has a semi hookup at a local dealer/shop (she doesnt press it as hard as she should[when her relatives own it]) ended up getting a flush/g13 fill for free but imagine my annoyance when she needs to refill green stuff and pays equal $$ for "premixed" coolant from a store.
    "no this is better, its pre mixed!"... they mix it with water.. "but its pre mixed!!" with water..... you paid the same price for half as much. "but now i dont need to add water..."
    Jun 27 2011
    Hahaha. The struggle is real.
    -CP
    2017 Q7 3.0t
    Oct 28 2018
    San Dimas, CA
    Yes, my temp gauge never got to the middle of the range until I'd been sitting in stop-n-go traffic for a bit. With the t-stat replaced it now warms up in a few minutes and stays glued to the middle marker regardless of what's going on, drive-wise.
    I suspect your problem is in your HVAC unit. I don't know much about the internals of the Audi heater box to help, but from owning Saab 9-5s and their dual-zone system I assume that you have some issues with the temp-blend servos and/or flaps. I thought the Audi HVAC systems were pretty robust? The 9-5's weren't, at least in the early years.
    Jun 27 2011
    Yea the thermostats in the b7s are a weak point. I’ve had to replace them in both my b7s before 65k miles. They definitely should last longer than that.
    -CP
    2017 Q7 3.0t
    Established Member Two Rings rbjeepthing's Avatar
    Oct 03 2018
    08 A4 Avant, 95 YJ, 01 Duramax, 18 JK
    Innisfil, Ontario, Canada
    I need to change my oil filter housing and i'm having a difficult time finding the G12 coolant in orange/pink.
    I can easily get:
    Fuchs Coolant
    ACL Part #: 1573B | Ref Part #: G013A8J1G
    VW G13 COOLANT
    NEW SPEC FOR AUDI-VW (TL 774J)
    Violet in color - 5L JUG
    ALSO AVAILABLE IN 1L/1573A,205L/1573D
    THIS IS THE NEW PREMIUM VW COOLANT
    CAN BE MIXED WITH G11/12/12+/12++
    Can I actually mix this or do I have to do a complete flush and fill?
    May 15 2016
    Lock Haven, PA
    Quote Originally Posted by rbjeepthing View Post
    I can easily get:
    Fuchs Coolant
    VW G13 COOLANT
    you answered yourself
    Oct 03 2018
    Quote Originally Posted by tloft4 View Post
    Expected someone to say that, just always second guess myself and sometimes others...lol
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Guys, just so you know, G12 is DISCONTINUED by audi and Superceeded by G13. This is the part number we all now need to run even though your reservoir says G12.
    G013A8J1G
    I also talked to several techs at the Audi dealership and mentioned my car has G12 in it and needs to be topped off. I asked if i need to do a full flush of the G12 before putting in G13 and he said NO. Go ahead and top off with G13. Its fine to mix and thats exactly what i did.
    Jun 27 2011
    Apparently g13 has less toxic shit in it or something. Either way, yea it’s the new coolant hotness. Might as well get that as it’s fully compatible with cars that specified g12.
    -CP
    2017 Q7 3.0t
    Oct 01 2018
    So I was rereading these and realized I wrote g13, I did not mean g13 lol. I meant green coolant but typed g13 for some reason or another. My bad
