Results 1 to 15 of 15
Thread: Vinyl wrap
    Sep 22 2013
    2016 mercedes c300, 2016 audi q5 3.0,2016
    owings mills/MD
    Vinyl wrap
    Hello all,
    I have a 2018 sq5 and plan to vinly wrap the window surround and the 2 roof rack bars. A few questions.
    1. Do most use the flat black or the shinny black that matches the current strip color between the front and back windows.
    2. How well does the wrap hold up with time? I only do hand washes or no touch car washes.
    3. Got a quote of $600 from a reputable tint/wrap shop(car wraps are part of their business). Does that sound bout right?
    Thanks for your input
    Established Member Two Rings 15WhiteA3's Avatar
    Feb 12 2015
    Harrisburg
    Vinyl wrap
    I had my A3 wrapped and it lasted about 2 years. The corners near the back side windows peeled up and need redone. I am a Detailer so it got taken good care of and never through an automatic. I would do gloss black though instead of matte. I paid $225 for mine to get wrapped but it was only the window trim not the roof rails.
    B8.5 Q5 3.0T-Glacier White, Black Optics, S-Line Interior Package.
    B8 S4 Stage 3 Phantom Black-SOLD
    8V A3 State 1+ Monsoon Grey-Ex Took
    2004 Titan- Work Truck
    Veteran Member Three Rings cmoore86's Avatar
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Vinyl wrap
    I did that to mine but the lower BO trim on the bumpers is OEM. Your quote matches what I paid. I went with gloss black match up with the other trim. I’ve had mine for about a year so far with no issues at all. But I hand wash and only use air to dry the car. I’m very pleased with how it turned out.
    2018 Audi [] SQ5: Navarra Blue | BBS | AWE | 034 |
    Sold - 2015 Audi RS5: Sepang Blue My Sepang Blue RS5
    Sold - 2015 Audi SQ5: Sepang Blue cmoore86 2015 SQ5
    Veteran Member Four Rings MK2SQ's Avatar
    Aug 11 2018
    That looks nice, Are the mirror also wrapped in carbon fiber? Or it is true carbon ?
    Thanks
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Cmoore86 referred me to his vendor for my B-pillars, and I've been ecstatic. Your quote certainly sounds reasonable - those roof rails are very labor-intensive and with this type of job you definitely get what you pay for.
    Also trust his advice on the B9 treatment. I went with gloss for my pillars simply to match the OEM pieces that attract swirl marks like mad. If I was trying to capture the BO look I would've gone with matte on the roof rails, but again...I'm B8.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Veteran Member Three Rings Thudux's Avatar
    Jun 22 2016
    2012 Jeep Wrangler
    Houston, TX
    Quote Originally Posted by rottley View Post
    Hello all,
    I did my own bro....super easy and way cheaper.
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Quote Originally Posted by SQ5/2018 View Post
    Thanks
    The mirrors are OEM carbon fiber mirror caps. Sourced from Europrice.
    Quote Originally Posted by VroomVroom View Post
    Yea I was torn on matte vs gloss for the roof rails. I think OEM is matte black on the B9 BO trim. I am happy I went gloss though. Especially with my ceramic coating. The paint is so shiny that matte black may have been too much contrast for me.
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    1. whichever you prefer. I think most are gloss black tho.
    2. My wraps held up fine over 2+ years here. In the summer I try to park in a covered garage. I noticed in direct light(heat) all day, it may start peeling up.
    3. that's alot for just window trim and roof rails. Don't forget the grille and lower bumper.
    I paid much less than that and work was completed in my garage in addition to ceramic coating lol.
    Would definitely recommend david @dac custom detailing, he's in the area.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Established Member Two Rings DonnyK's Avatar
    Oct 18 2017
    Any reason this is preferred over just painting them? I spoke to my paint shop guy and he quoted me $600 to paint my roof rails gloss black and the top caps on my mirrors ibis white (didn't ask about window trim), but unless you are just trying it out to see if you like it, i would think a more permanent change would be a better solution.
    2014 Ibis White SQ5 | BBS CI-R's | DWS06 295's | EPL Stage 1 ECU Tune | EPL ZF TCU Tune | APR Intake | 034 Inlet Hose | Vag'd
    Nov 11 2014
    2018 SQ5
    San Jose, CA
    Quote Originally Posted by DonnyK View Post
    For me, the same reason as I why I didnt just get the OEM parts. Because you'd have to take the rails and window trim off. Rails require dropping the headliner, and on the B9 the rear window trim is stuck on the actual window glass with adhesive. So you have to remove the rear glass to get that trim off. I know they could be painted on the car...but I wouldnt risk the overspray and possibly not getting the paint around all the corners.
    Sep 28 2010
    NW NC / DE
    Good input here!
    To add, I had my A5 windows trims wrapped, and they looked perfect still after being on the car for over 4 years.
    I also sourced my carbon caps from @[email protected]
    Sep 22 2013
    owings mills/MD
    Thats for all the advice. I’m going gloss black on the window trim and roof rails.
    Will leave mirrors as is. Quitely indentifies car as an “S” model.
    Feb 20 2018
    L.I./NY
    I deal with vinyl on a regular basis and most of the industry standard vinyls are rated for 5years, such as 3m 1080. Now that doesn't mean it will just start peeling off at 5 years, but at 5 years it will get a lot harder to remove (still removable) but it might come off in pieces. 600 does sound high though. It's a fun project to do yourself if you're up for that and a hell of a lot cheaper provided you already have a heat gun. Avery is also a good brand and I've had it on boats in saltwater that has lasted over 10 years, but 1080 is alot easier to work with. Vvivid is also a good brand to work with. Also I read someone else had problems with their vinyl peeling on the edges, use 3M 94 Primer on them and they wont come off unless you want them too. They come in little crush pens too which make life easy
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Definitely going to tackle this in the spring...or during a warm winter chinook weekend. Always though the chrome clashes with the blue paint.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Jul 21 2008
    any photos of how the wrap looks at the ends of the window trim? a number of videos on installs but they all seem to skip how to tuck or fold the vinyl at the ends.
    2018 SQ5 P+ | Nav | S Sport | Dynamic steering | B&O
