-2005 Audi A4 B7
-Front wheel drive (HHE CVT Transmission)
-2.0L Turbo
-Engine started and appeared to run fine when we bought the car
-Transmission made noises when shifted into any gear and would not move
We pulled the front end off of the car and removed the engine and transmission together. This allowed us to clean the engine up replace gaskets as needed. We swapped out the transmission and put everything back together. It may be important to note the battery was out of the car for roughly two months while we performed this work. When we went to start it for the first time after replacing the transmission it will start then immediately die. This has continued to be my problem since. Some observations we made while attempting to diagnose:
-The dashboard center readout panel states “Press clutch to start” but it’s an automatic.
-When connecting OBD scanner, we use OBDeleven, it states there is no connection
Any thoughts or recommendations would be greatly appreciated. This has become quite a challenge and was hoping to avoid a trip to the dealership if possible. Thanks in advance
