Results 1 to 40 of 49
    Active Member Two Rings Exi's Avatar
    Oct 23 2018
    Norway
    A7 brakes - what fits when upgrading?
    Hi guys!
    Wondering about upgrading my stock 3.0tdi brakes to S/RS brakes.
    Have no clue on what would be bolt-on from other Audi models or what would fit with fairly simple mods?
    Any ideas out there?
    Established Member Two Rings BurgerGawd's Avatar
    Nov 08 2016
    Rollerblades
    Philly / South Jersey
    Subbd, there’s probably some porsche options too
    Established Member Two Rings EuroDub's Avatar
    Dec 06 2008
    Laconia NH
    S8 brakes are direct swap.
    May 11 2014
    Walnut Creek
    Quote Originally Posted by EuroDub View Post
    I’ve been following that S8 brake thread. Can’t tell if it really fits.
    Mar 11 2007
    Colorado Springs
    These are plug n' play... both front and rear (S6/S7/RS7/S8 too IIRC)
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Oct 23 2018
    Norway
    Quote Originally Posted by A6sport View Post
    These are plug n' play... both front and rear (S6/S7/RS7)
    Have you done it?
    Mar 11 2007
    Colorado Springs
    You are looking at pics of my car.
    2012 A8L 4.2
    Oct 23 2018
    Norway
    Ok.
    A7? Model?
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by Exi View Post
    Ok.
    A7? Model?
    yes, A7 2012, but it's special, very special...that's why it's "plus" ;-)
    2012 A8L 4.2
    Dec 06 2008
    Laconia NH
    Not the best pic but S8 brakes painted black on A7.
    Oct 23 2018
    Norway
    What model A7?
    Bolt-on..?
    Dec 06 2008
    Laconia NH
    What model A7?
    Bolt-on..?
    2012 3.0T Prestige and yes same as above, direct bolt-on.
    Oct 23 2018
    Norway
    No new hoses(?) or anything?
    From D3 or D4 S8?
    Junior Member One Ring
    Dec 16 2012
    United Kingdom
    I've not long fitted the S7 brembo 6 pots to my 3.0 tdi A7. Straight fit as mentioned above, plug and play!
    45342207_308862323047352_2675470759450640384_n.jpg45427258_370083463729946_7292745015661428736_n.jpg44139921_247327985951457_7479480925152083968_n.jpg
    Oct 23 2018
    Norway
    Quote Originally Posted by Jord_C View Post
    Looks great!
    Oct 23 2018
    Norway
    Offtopic, what front-lip is that?
    Established Member Two Rings egli05's Avatar
    Apr 15 2010
    Pennsylvania
    Would Also like to know front lip ^
    On the Road: C7 A7 APR Stage 2+
    In the Driveway: Laser Red Giac X Stage 2 B5 S4
    Dec 16 2012
    United Kingdom
    Quote Originally Posted by egli05 View Post
    Its the Maxton Design front lip for the facelift, it took abit of patience but i managed to get it to fit!
    Active Member One Ring e85-addict's Avatar
    Feb 12 2017
    California
    Does anyone know if it is possible to fit C7 S6 front caliper brackets on a C7.5 A6 TDI for a bigger rotor (from 345 mm -> 400 mm)? Or BBK is the only option?
    Mar 11 2007
    Colorado Springs
    Nope. You need the calipers.
    2012 A8L 4.2
    Feb 12 2017
    California
    Thank you!
    One more question, wil the stock calipers hold 356 mm rotor?
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by e85-addict View Post
    Thank you!
    I don't quite understand? You have 356mm front rotors as stock correct? However IIRC the TDI has 345mm?
    2012 A8L 4.2
    Veteran Member Three Rings AdrianLee's Avatar
    Jul 19 2011
    2016 A7 3.0T & 2016 Q5 3.0T (Wife's Daily)
    SW Michigan
    SQ5 calipers and 380mm rotors fit. RS5 calipers and 365mm rotors also fit. Most things fit except the newest B9 chassis stuff
    I currently have SQ5 front brakes on my C7.5 A7
    C7.5 A7, APR Stage 2, APR Heat Exchanger, Fluidamper, AWE Exhaust, Eurocode Swaybars, RS7 Airbox, Trans Tune
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by AdrianLee View Post
    You know. I've wondered if the B9 stuff doesn't fit because it's no longer Brembo?
    2012 A8L 4.2
    Dec 08 2020
    Portland, OR
    Any consensus on best bang for the buck upgrade? Ie. lowest ebay price for parts with best performance gain.
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by markdjr View Post
    In IMHO, find a set of S6/S7 calipers, rebuild and refinish, mate them with Girodisc rotors. Not only the best bang for your buck, stopping power is greatly increased.
    My brakes, front 400mm and rear 336mm are one of my favorite mods. I don't have Girodisc rotors on my C7 as I had a set of new fr/rr OE discs to get through.
    For rotors, I've seriously considered RB 2 piece discs for the front and rear. RB is one of the few aftermarket brands that have put the development costs into both 2-piece 400mm fronts and 356 rears.
    2012 A8L 4.2
    Nov 18 2014
    2001A6,2013A7 C5 allroad
    Hartford
    Anyone running the fcp setup?
    Zimmerman sport rotors and akebono euro ceramic pads?
    Very minor ,cheap upgrade
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    Quote Originally Posted by nick1980 View Post
    Curious to see if this provides any upgrade.
    2013 Audi A6 3.0T Prestige
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    Mar 11 2007
    Colorado Springs
    Zimmerman Rotors and Akebono pads will not be better than stock rotors and pads. Audi OE pads and rotors are very good for what they are. The one thing AB pads will provide is less dusting.
    I always laugh to myself when someone says their new pads and rotors are way better than OE. The new setup stops so well because they're new and not worn! Not better. On top of that the trade-off for pads that are ceramics are cold bite is lessened.
    Stock brakes are the best bet except for the dusting properties. You can buy any rotor pad combination and you will not realize decreased stopping distances nor resistance to fade.
    More pistons, bigger rotors, and performance, dirty, dusty pads are best for improved stopping power.
    2012 A8L 4.2
    Junior Member One Ring Eric_BiTDI's Avatar
    Aug 04 2020
    Rugby, UK
    I have just fitted the S7 calipers to my 2012 A7 bi-turbo. Direct fit and an easy swap.
    Painted in Deception Purple with added glow in the dark!
    Sep 27 2008
    Phoenix
    All of this talk has me considering an S6/S7 caliper upgrade. What did the full upgrade cost you?
    Nov 03 2019
    San Francisco
    I did my S brake upgrade, front and rear, for ~$2700 all in and installed. It’s the two piece front rotors and the Brembo front shims that make it more expensive than expected.
    The stopping power is amazing though and by far my fav upgrade.
    Jul 16 2018
    Connecticut
    Quote Originally Posted by wootwoot View Post
    Currently pricing out a kit. It looks like it is going to come out to ~2,000 for used calipers and brackets, new (FCP) pads, rotors, shims, and sensor
    Aug 04 2020
    Rugby, UK
    in the UK...
    calipers (new) - 500
    shims (from Audi) - 140
    pads (EBC Red stuff)- 140
    clips (from Audi)- 140
    paint - 80
    discs (zimmerman)- 420
    caliper bolts (from Audi)- 16
    fitting - 120
    total - 1556
    This is not $ and England prices, so cups of tea per queen (aka £)
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by prestige.phantom View Post
    If you can get this for 2k, I'd jump on it! I paid 2k for calipers only back in 2016.
    2012 A8L 4.2
    Jul 16 2018
    Connecticut
    Calipers, brakets, and lines are on their way! Gonna use up the remaining pad life on the stock brakes then order the pads and rotors from FCP and install my S8 set!
    Sep 27 2008
    Phoenix
    After looking around more last night the A8 brakes seem like the best value upgrade on this platform. ~$350 for used calipers and carriers for the front through eBay.
    https://www.audizine.com/forum/showt...rade-for-A6-A7
    Junior Member Two Rings
    Jun 01 2020
    Tokyo, Japan
    Hi, was hoping to get some help with how to choose upgrade kit.
    Currently i have a A6 C7 2012 with stock 356mm fronts/330mm rear calipers.
    1) In case of finding S6/S7/S8? calipers(as per below part no.), I can see in online ETKA caliper carrier but no part no. next to it(only comment:not for this model)
    Do you happen to know or how to how to find out the right part no. of caliper carrier that will fit S6/S7/S8? calipers as well as the stock S-line A6 C7 wheel bearing housing(4G0407254B)?
    S6/S7 4G8615107(Left), 4G8615108(Right)
    S8? 4H6615107(Left), 4H6615108(Right)
    2) Currently summer tyres are on 19inch wheels and winter on 18inch wheels.
    I suspect 18inch wheels wont fit over the calipers, is my assumption correct? 19inch wheels may be the minimum?
    3) Since the 18inch wheels are beneficial in winter time, is there any recommendations on brake upgrade should I choose to keep the 18inch wheel?
    Established Member Two Rings benlaud87's Avatar
    Jan 23 2023
    '03 Corvette, '06 mini Cooper S, 16' A7 TDI '22 Tahoe HC
    Raleigh, NC
    S7 front calipers cost me $700 on eBay
    the original black finish looks like its seen better days so I'll paint them myself $60 for a G2 black paint kit on amazon
    new front and rear rotors from 034 motorsports roughly $2000
    EBC brake pads front and rear $300 on amazon, but I used points
    Shims from ECS Tuning $100
    steel brake lines from ECS Tuning $100
    Total was $3260
    I'm sure this can be done for cheaper or more expensive. Like others have said, the cost of the front 400mm rotors add up quick.
    This is the cost of swapping rear brake pads and rotors at the same time as upgrading the front. If you're just doing the front then subtract roughly $1000
    Jan 31 2009
    2016 RS7-P
    Quote Originally Posted by Mikedd View Post
    The Brembo carriers are hard to get if they have been separated from the calipers, I don't think Audi sells them but some places like killerbrakes sometimes list them. Short story, don't buy calipers without the carriers if at all possible.
    https://www.killerbrakes.com/product...m-brake-discs/
