Results 1 to 28 of 28
    Active Member One Ring xionis's Avatar
    Apr 29 2014
    Ohio
    RS5 mmi/map update
    I can't seem to find a specific answer to how to update the mmi software and/or the maps. I purchased a t-mobile Sim card since its only $10/mo (2gb of 4g data,unlimited 3g) but I'm not sure if this will update both or just give me some Google online search features and a wifi Hotspot.
    I tried to sign up for audi my connect but it requires me to put in my Vin as well as Sim card number... So I'm not sure if the update is there or elsewhere. Or if there is another location to download these or if I have to upgrade the mmi unit itself in order to perform a software update. My car is a 2013 Audi RS5 (and I'm in love with it)
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    With a SIM card installed you will be able to activate the google earth feature for a satellite view but as far as I know, the actual navigation map has to be purchased.
    I just had mine updated at its last service, it was approximately $250 for the update and the software is uploaded and then activated from a code which in my case was sent from Germany.
    Established Member Two Rings xxxaudixxx's Avatar
    Mar 21 2013
    Nova
    Quote Originally Posted by JamesRS5 View Post
    Was the update worth the $250?
    2014 Sepang Blue RS5 - Xpel, Gtechniq, Maxton, 1SEC Carbon, Capristo, AWE, Armaspeed, BBS CH-R, Morimoto RGB DRLs, Demon Eyes, CF Reflectors
    2012 Ibis White A4 Stg II - AWE exhaust, APR tune, 034Motorsport HFC, RS grill, BFI shift knob
    Follow me on Instagram @restless.rs5 @restless.decals
    Apr 29 2014
    Ohio
    Quote Originally Posted by xxxaudixxx View Post
    That's what i'm wondering too....does the update offer additional settings or any improvements? But a constant map update would be great because of all this random construction and detours around town
    Feb 27 2014
    Dubai
    That all depends on the city you live in I guess, Dubai is like the staircases from Harry Potter, constantly changing, building new bridges, roads and housing developments, etc.
    They also added 3D buildings to the navigation map so you do get a nice 3D view of the area you’re driving through. There no additional features and no other functionality for me but I cannot use Audi Connect in the Middle East so not sure what that would add.
    Speak to your local Audi, the update comes in a plastic wallet, inside it is a list of everything that’s added so you should get a good idea.
    *Edit
    I very much doubt they would add construction road closures to the map unless you have traffic activated in your Nav, I use Waze for traffic info.
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    You can get gray market updates through eBay for about 1/5th the cost. I upgraded my MMI that way but did not update the NAV as I never use it.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Apr 29 2014
    Ohio
    I got my sim chip and installed it yesterday, which was great because there was alot of accidents on the highway lastnight and it alerted me of lane closures ahead as well as gave me a google earth view of the city. So i'm 99% sure it updates the maps that way too because it also showed road construction areas on the highway. I plan to make a 2 hour road trip saturday so I will see how well it does with only the sim. audiconnect website still won't allow me to sign in though, it keeps saying invalid sim when i type the number in and I heard from somewhere I can download the MMI update from there.
    Feb 27 2014
    Dubai
    You’re getting traffic updates, not map updates.
    Established Member Two Rings doc280's Avatar
    Feb 09 2016
    NC
    Traffic on the Audi is performed through Siriusxm, at least here in the States.
    Apr 29 2014
    Ohio
    Yep you're right...took a couple of days to realize that. Guess i'll have to visit the dealer to get the update
    May 15 2018
    RS5 mmi/map update
    I’m actually thinking about getting something like this:
    https://rover.ebay.com/rover/0/0/0?m...2F153232495160
    ~140 and looks like it should include everything to update maps and fw.
    Apr 29 2014
    Ohio
    Quote Originally Posted by leew102 View Post
    That looks very promising! However the bottom right of my screen says 2G, will this work on mine?
    May 15 2018
    Uhh I think you’ll have to go into your MMI info screen and determine what mmi system you have and find the right eBay posting for your mmi version. The seller sells multiple versions for each mmi version.
    Jun 24 2017
    San Antonio, TX
    That’s what I did. Sent the seller my MMi version and he sent the right software update package.
    May 15 2018
    Quote Originally Posted by Ape Factory View Post
    Works pretty flawless I assume? Does anyone happen to know what the map update cadence from Audi? I know in my dads older Mercedes, they did them on like 2-3 year cycles.
    Veteran Member Three Rings Delasangre4231's Avatar
    Nov 22 2012
    Portland, Oregon
    I had the latest update and maps installed and it made almost no difference except adding some roads that weren't there on the old 2013 maps.
    I say its NOT worth the money. I hate the stock MMI and nav. I just installed a phone mount so now I just use Waze or Google maps on my phone. I recommend RSNav or a phone mount.
    -2016 VW GTI Autobahn Performance pack DSG
    Michelin Pilot Super Sports, APR Carbon Fiber Intake, APR Stage 1 ECU tune
    -2003 VW Golf 2.0 5-speed SOLD
    -2013 Audi RS5 Phantom Black Pearl SOLD
    Michelin Pilot Sport 4S, ECS Brake lines with Motul RBF600, ECS X-Pipe, Leyo Motorsports paddle extensions
    -2003 Audi A4 Avant, 6MT, 3.0 V6 SOLD
    B6 S4 front brakes, JHM stainless brake lines, Straight Pipe - http://youtu.be/7zsiB7rT1fo
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by doc280 View Post
    This. I learned the hard way. Updated mmi and maps and got AT&T and still no traffic. Only to find out I had to use shitty Serious XM. Not worth it.
    Feb 09 2016
    NC
    Quote Originally Posted by Delasangre4231 View Post
    I agree 100%. I am holding out for some brain child to workout how to add Android Auto or Apple Car Play to MMI.
    Jun 24 2017
    San Antonio, TX
    I'm here to help you spend your money. You mean like this right? https://rsnav.com
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    RS5 mmi/map update
    Is that everything you need? I just upgraded to MMi 3g+, still working on bugs actually, and it’s overall so much better.
    Then I get a 2019 Altima rental with 14 miles on it and Apple car play. Seamless and completely awesome. Now I want Rsnav.
    I also hit a deer in that car, had 50 miles on it I think. Lol
    Jun 24 2017
    San Antonio, TX
    They have an entire new unit with larger screen. They have an older version which is just mirroring. I’d contact them directly. Guy that owns RSNav is an Audizine member and is pretty responsive.
    Jan 20 2017
    RS7
    New Hampshire
    Why does it have to be that easy!
    Jun 24 2017
    San Antonio, TX
    I think this is the one they have for the B8.5 but check with them. Scroll down and you can see they make an Apple iOS version too.
    https://rsnav.com/products/android-n...symphony-radio
    Feb 09 2016
    NC
    I will have to check with them and save a few nickels, but I really like the RSA-8 system. Also I do not understand the accessories list, if my current system has these features, is the new system not going use the existing equipment?
    https://rsnav.com/products/audi-8-8-...stem-for-a4-b8
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Keep in mind that there's a thread going on that's indicating that the Google Earth map overlay will stop working at the end of 2020 due to a major software change by Google. Any 2018 and older Audi will no longer have the Google Earth map overlay, but would still have Google search and other features. That's only 2 more years of use.
    USP CLUB MEMBER #34
    Nov 22 2012
    Portland, Oregon
    Quote Originally Posted by CyberPMG View Post
    I don't use it anyways but good to know.
    Feb 27 2014
    Dubai
    Would that not just be fixed by a software update from Audi?
    Feb 23 2004
    Stow, OH
    The software change from Google is targeting newer graphics hardware and cannot be fixed by any firmware update. The graphics cards used in 2018 and older Audis will no longer be compatible to Google's software.
    Here's the whole thread on this matter... Clicky click
    USP CLUB MEMBER #34
