Results 1 to 39 of 39
    Oct 04 2017
    SFLA
    Diy Oil change tips and observations...
    So after doing my first oil change and not knowing what tools i exactly needed, and the DIY’s didn’t say what oil filter tool was needed, i will cover all that now. First if you owned an mk5 and/or an mk6 gti or golf R you might have these already as i did.
    For oil filter removal you’ll need THIS 74mm and 14 fluke socket:
    And for removing the oil from the oil filter before removing the oil filter housing and causing a mess you’ll need THIS:
    Other optional stuff you might want that i already owned are jack pads and jack stand covers as well. Here are the optional stuff i had already that made things better:
    There are a total of 7 t25 screws three on each side and one in the front of belly pan, 3 t45 bolts (overkill) on rear side of belly pan. The t45 torx bolts had blue loctite so expect a little more ratcheting, they really wanted to hold down this pan lol. This car took 7.5 quarts of oil!!! so get 8 quarts! Oil filter has to click into position inside oil filter housing, if not it will be annoying to line up with filter housing base.
    Any questions or things you can add feel free to reply or message me. Hope this helps those weekend warriors/backyard mechs
    Jul 07 2018
    22 Tesla M3P
    Pleasant Hill, CA
    This is my first Audi (these both are...) what does a typical oil change at the dealer cost?
    2024 RS3 - Glacier White - PPF, Tint, ECS Intake
    *SOLD* 18 RS3 - Florett Silver - PPF, tint, Uni Stg 1+ e85/TCU stg 2, APR Intake, throttle inlet & 4in turbo Inlet, CTS Intercooler, Midpipes, fuel-it sensor, sparkplugs, ece dogbone, Uni WG Line upgrade, Eurocode Rear Swaybar w/034 endlinks, 034 Street Motor/Trans mounts, subframe locking collar kit, Neuspeed rse10s, Rotors
    2022 Tesla Model 3 Performance - PPF, Tint, cosmetic mods
    2025 Mazda CX-70 PHEV
    Oct 04 2017
    SFLA
    Quote Originally Posted by JBones81 View Post
    double the cost of doing it yourself or more. IIRC was like $250 last i saw.
    Oct 14 2006
    Mass
    I just had it done at a dealer in MA and it cost me $140.
    Mar 09 2018
    2018 RS3
    I have the same oil filter drain tool and I have this oil filter wrench:
    https://www.amazon.com/ABN-Filter-So...+oil+filter+vw
    Probably identical to the MotiveX wremch. You can drain the filter without the tool but there is a nearby coolant hose that you don't want to get oil on.
    Surprisingly none of my funnels would fit in the oil fill hole so I bought one of those long neck funnels and chopped it down until I got a good fit.
    This is the first car I have to remove the under-tray which is annoying but it's pretty easy job.
    Florett RS3+DS1+034TCU
    Oct 04 2017
    SFLA
    Quote Originally Posted by robopp View Post
    that's not too bad, it cost me $80 for 8 quarts of oil and filter plus crush washer. liquid moly 4200 top tec, better than dealer oil.
    i try to stay away from dealer period specially for oil changes after what happened with my MK6 GTI and getting the free oil changes from them, they like to over tighten the pan bolt and it started to develop a leak and the only way for it not to leak was by over tighten it.
    Oct 07 2008
    Earth
    Thanks for sharing. Just ordered bunch of tools.
    Oct 02 2017
    Thanks for sharing this with the community. I have already done 2 oil changes (1k, 5k) and I got myself a reusable magnetic drain plug.
    May 03 2018
    11th gen Honda Accord Hybrid EX-L
    Jax, FL
    Yeah, just put an order in for the $25 filter drain hose. Thanks OP.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    ive changed mine 5 times now, not to hard
    my s4 i could change from the top of the car in 10 minutes, i really miss that!
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Oct 04 2017
    SFLA
    Quote Originally Posted by saxon View Post
    Yeah my MK6 was the same way sure miss that and no belly pan.
    Oct 04 2017
    SFLA
    FYI just found two new oil filters that i had on my MK5 and they are the same part#!! so if any of you have left over filters from MK5 gti or FSI engine then your in luck!!
    Established Member Two Rings 1QWIKWHP's Avatar
    Nov 18 2006
    WESTCHESTER,N.Y.
    Quote Originally Posted by speeddemon69 View Post
    Yes.. apparently MK2 TTRS and 8V RS3 same filter
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    Did mine today on my dads lift. It was really easy. Look about 1 hour from first driving up on lift to backing off lift. I went slow during. Bought my oil and filter from europarts. Couldn’t be more pleased.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    May 03 2018
    Jax, FL
    Did anyones 1st oil change factory drain plug not include a washer?
    T45 for drain plug, and 3 back belly pan bolts.
    Anyone figure out why the back three are huge and have blue (compared to other 7) lock tight?
    Apr 05 2006
    992 c4s
    Blue Springs
    Mine had washer. My pan and back 3 bolts are t45.
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    Veteran Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    Super helpful thanks
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
    Oct 04 2017
    SFLA
    Quote Originally Posted by shivaswrath View Post
    May 03 2018
    Jax, FL
    Quote Originally Posted by Bezlar View Post
    I meant T45, my typo, will correct. I did not inspect, but why are those 3 torx at the end of belly so big and necessary?
    Guess, cuz bolted to sub, why not use a bigger bolt on aluminum.
    Mine only needed 7 qts.
    Apr 05 2006
    992 c4s
    Blue Springs
    Quote Originally Posted by comingabriel View Post
    I put the full 7.5 in and it was at the max on the dip stick.
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    May 03 2018
    Jax, FL
    That is weird, 7 brought me to max.
    I let the pan gavity drain forever, also drained the heck out of the oil filter housing.
    Had a God aweful startup sound after 7 qts added for a couple of seconds, like slight grinding gears.
    Apr 05 2006
    992 c4s
    Blue Springs
    What oil. Mine started smooth as butta. I used liquid moly top tech 4200 they where liter bottles. So I’m pretty close to 8 quarts.
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    May 03 2018
    Jax, FL
    Used Motul 8100 X-clean+
    Had the car in N, so I could move the car back or fwd, to get centered on the lift, maybe starting in N was the reason? Coulda moved the shifter a tad without realizing somehow? No idea.
    Nov 01 2017
    Waco/TX/USA
    I'm about to perform my first oil change. How do you reset the oil service timer after changing the oil?
    Apr 05 2006
    992 c4s
    Blue Springs
    Quote Originally Posted by wittmer25 View Post
    It’s in the mmi screen under car
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    Nov 01 2017
    Waco/TX/USA
    Really, I looked and couldn't find it. I will look again.
    Can someone post a picture of the MMI screen on their 2017 RS3 where you reset the oil service timer?
    Nevermind, I found it. There is a side menu in vehicle settings.
    May 03 2018
    Jax, FL
    Go to audi drive select screen, hit the round dial to the left, it should bring you to the area where you will see service and checks, select, service intervals, reset oil change interval, yes. Done
    Established Member Two Rings Optimus812's Avatar
    Aug 20 2012
    Cencal
    I assume we should have a cover for this area ??
    2018 Catalunya RS3 - Uni Stg II/TCU, Uni Injectors, IE Carbon Intake, IE Inlet, Iroz FMIC, Milltek DP, Fuel-it E85 Sensor, ASR Exhaust Controller
    Oct 16 2012
    pa
    Quote Originally Posted by Optimus812 View Post
    nope, thats just how it is
    Aug 20 2012
    Cencal
    Thanks glad I asked!
    Jan 03 2019
    Bringing this thread from the dead since it’s so good.
    Can anybody please share which drain plug and washers they used ?
    Thanks
    Oct 02 2017
    Gold Plug Magnetic Drain Plug AP-08 1 $18.99
    14mm Gold Plug Aluminum Drain Plug Crush Washer - 5-Pack 1 $3.99
    https://goldplug.com/shop/ap08/
    been running this for 10k miles with 3 oil changes (1k, 5k, 10k). I just replace the crush washer
    May 03 2018
    Jax, FL
    Ever find anything on the magnet?
    Oct 02 2017
    there's always small dusting, it's when you get fingernail shavings when you have to worry. I've built motors and run magnetic plugs. Just learn not to freak out when you see little things because every motor has small bits of metal that make their way down. I have seen canister filters with magnetic rings on them for those that want to trap that debris there.
    Jan 15 2017
    Carlsbad, CA
    Can anyone tell me the torque specs for the filter housing and drain bolt when reapplying them?
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I paid $170 for my oil change at the 5k interval. I was told by the service advisor that my oil would be changed removing the bottom oil plug and not using the suction device. Paying for the oil change you get a decent carwash and also a free inspection sheet at no cost.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Dec 05 2010
    Los Angeles, CA
    I thought first oil change was free at Audi dealership?
    2019 Nardo with all OEM options
    Aug 29 2017
    Tucson, AZ
    Quote Originally Posted by BzzzBom View Post
    ^^Yes, correct it is free at 10K. I opted for one which I paid on my own at 5K. I got my free one at 10K.
    at 3100ft elevation
    May 16 2019
    worcester Ma
    Quote Originally Posted by S3DUDE View Post
    Decent carwash at the dealer?? You should see my dealer's carwash. Looks like the gates of hell.
