Hello people,
So I'm planning to convert my NA 1.8 to turbo'd engine and I could use some help/insight from some experience people or anyone really :P. I have posted this over at nefmoto too, as that is what I'm going to use to flash the ECU (8D0 906 018 Q / 0 261 206 318 ECU with 99. august timestamp) with, and they given me some help, but I figured why not post it here too :P.
So currently as I am unemployed, everything is on hold until money gets sorted but I have got the ebay turbo so far, it has 8 psi internal WG ( good enough for now)
So my plan is to get 1.8t Intercooler possibly , depending on how expensive they are, if they are expensive , could get an universal one, IAT/MAP on intake side ( apparently this is what people recommended me, even tho I am not 100% on how to wire it up to the MAF wiring/ECU ( IAT is in the MAF in NA cars)), oil/drain is straightforward, exhaust turbo manifold from ebay obv, bigger injectors, possibly fuel pump too ( not to crazy tho for now) , and possibly an used AEB intake manifold right? as the NA one is not suited for it, and that should be enough to get this cheap custom turbo'd engine running :P People also said that getting a wideband lambda would be really good/ way easier to tune , but the current ecu is narrowband soo..
So yeah any insight , help is welcome :) Thank you if you read it all :)
