Results 1 to 40 of 68
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Torque Converter RPM surge Poll
    Seems to me like all the B7 A4’s I Drive and or own experience some degree of rpm fluctuation due to the TC. I have been wrenching on these cars for years, but just now realizing how common this problem is. I own a small dealership specializing with Audi, Vw, BMW so I see a lot of these cars and they all do it!!
    I’ve been browsing the web and believe this is a major issue affecting cars with as low as 30k. There was a TSB issued, but never became a recall.
    It seems somewhat benign, but certainly annoying and unacceptable.
    I’d love to hear from those who drive tiptronic. Do you have this issue, how long has it been occurring, and has it gotten worse?
    Mar 07 2018
    Ottawa/Canada
    I wasn't sure what caused this, but it happens to me. I have about 78k miles on mine. It usually happens for a little while somewhere between a cold engine and fully warmed up and is most pronounced at about ~30 mph. It stops once the car is fully warmed up so I don't think much of it.
    Jun 23 2008
    https://www.audizine.com/forum/showt...4#post13364424
    Posted about it last year, take a read. What else is new, every platform of Audi's has a major issue, still getting us back from the War. :)
    Mar 24 2013
    Oakdale, CT
    I had a b7 tip car a while back for a short period and it surged a little when in gear until it warmed up. Wasn’t sure concerning because the car had 174k and otherwise, everything worked really well.
    -Adam
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by 419kla View Post
    Those are the same symptoms I have read about and experience with most of the ones I see. I’ve got 3 right now and they all do it. Mileage 100, 111, 135.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by DownhillA4 View Post
    I will take a read. I’ve been browsing many threads the last couple days but did not come across yours.
    It really is a love hate with these Audi’s. 1.8t with the oil sludge.. 2.0t with cam follower, balance shaft, timing tensioner (issues I though were major enough), and now TC is on my radar. B8 2.0 timing chain tensioner, oil consumption, and rear main seal.. sometimes I wonder why I choose to buy, fix, and sell these cars lol.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Even with that mileage it’s not acceptable, i wonder for how long it was like that. I’ve got 2 right now around 100k doing it. And one with 135k that fluctuates over 2-300rpm. Far worse than the others and it doesn’t get much better when warm, like really Audi should have acknowledged this.
    Sep 27 2008
    Phoenix
    I'm at 115k miles and haven't noticed any TC issues.
    Aug 04 2015
    Kansas City
    My 2007 A4 has 76,000 miles and I get some RPM fluctuation when there are cool temps outside. After the car warms up the fluctuation goes away. It doesn’t bother me.
    Jan 16 2016
    indiana
    Quote Originally Posted by a4lownslow View Post
    I have for as long as i remember but i really started studying it last winter. It only does this in the cold weather and we are just now getting our cold mornings in Indiana. After my car starts to warm up, it goes away. I have yet to perform a carbon clean so no idea if its related. Currently at 127k miles.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by audiman91 View Post
    That seems to be the general consensus. Symptoms there when cold, and go away when warm. Carbon buildup does not seem to be related to this, although I’d take that over TC.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by wootwoot View Post
    Lucky you!
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by KJack View Post
    Personally it doesn’t bother me either. I don’t feel as though it’s a reliability concern, more so a drivability annoyance, but that can be a tricky one to explain when selling these cars as a dealer. The enthusiast/ honest person in me likes to break down all the detail, and be as transparent as possible when selling vehicles. Good and bad.
    Established Member Two Rings bigheadb7's Avatar
    Jun 02 2017
    New Jersey
    I experience this on cold starts ! I thought it was piston rings because car was swallowing oil but after a compression test and some other stuff, I found out that my valve cover was cracked and Pcv was faulty. Oil consumption was Fixed to 1 quart every 2500 miles like it was before but RPM was still funny. What is the solution to this problem ???
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by bigheadb7 View Post
    The solution is a new torque converter. But it’s going to have the same issue eventually. I came across a post where the symptoms returned after 30k on a NEW one. Sounds like there may be an upgraded seal that will rectify it for good, but I haven’t looked that far into it. These cars are getting old enough where it really isn’t worth the cost for a new TC, even if you’re doing the work yourself.. unless it’s really bad. I have one right now that jumps 300+ rpm and will still do it after driving for hours. Only happens at light throttle 30-40mph. Thinking about trying a fluid and filter change but that may be a waste of 300$. Some say it helps, others not so much.
    Jun 17 2013
    jersey city nj
    Ive got 245,000 miles on the original transmission . Ive been this since i purchased it with 161,000. Its been the same rpm fluctuation
    Sep 27 2008
    Phoenix
    Many of those with issues mention cold weather. How cold exactly? I ask because I have not seen issues but my car is never in the cold, I live in Phoenix.
    Jun 27 2011
    My old old 2006 Tiptronic did that. I believe we bought it with 75k miles or something and it did that since we bought it (its so subtle I didn't notice it for a while though). It would bounce 1-200 rpms under low load, most notably when cold, but it tended to do it when warm too. Rather than dick around with that car that I wasn't a huge fan of anyway (it shifted pretty rough as well and I really dislike Automatics) we traded it for my current 6MT b7. I was going to do trans filter and fluid but at the time, ~2011, the fluids were Audi brand only and were like $80/L and the filter was like $250. The cheapest I could price the job was like $650 or something ridiculous so I decided on a hard pass and kept driving it until we traded it in.
    The lurchiness from a stop, and the dragging while stopped was super frustrating and something I chalked up to the torque converter basically being partially engaged or "dragging" while at idle. In P and N it idled so smooth, but put it into R or D and it vibrated like hell. I wasn't a fan.
    By comparison, the 8-Speed ZF Tiptronic in my wife's current Q5 is so so so much better. I just changed the trans fluid and filter at 65k miles due to some shifting issues and its freaking perfect now. The b7 should have a transmission that shifts like that.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    That TC really is something.. it’s like clockwork on everyone I drive.
    Before I got my dealers license (about a year ago) I would fix and flip a few Audi’s a year for a few years, and by personal choice I would always buy manual Audi’s because that’s what I liked driving. Now that I do it for a business I’ll buy either auto or manual, and that’s how this entered my radar. I’ve Easily driven 15+ b7 models that I can recall doing this, and it Makes me want to stick with manual trans lol.
    Such a bother when selling, regardless if the symptoms stay the same for 100k, it’s still there and most will acknowledge it. Same goes for the vibration at idle when in gear.. everyone asks “is that normal?” My response is yup, they all do it
    My significant other drives a 2010 Q5, transmission smooth as silk @ 110k.
    Aug 04 2015
    Kansas City
    I start to notice it when morning temps are in the 40s.
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    I bought my 2008 A4 2 years ago with 68k on it, surge was pretty bad at that time. Early on in my ownership I had the fluid flushed with the comparable REDLINE (ECS sells a kit that includes the REDLINE as an alternative to the Audi fluid) since then it is a lot less noticeable though I do still notice it, and shifts are smoother as well.
    I live in south Florida where cold starts are usually in the 75*-100* mark but during winter the temps drop into the 40's and 50's its a little worse that time a year.
    I'm at 110k now and its still there but much less noticeable then when I bought it.
    Veteran Member Three Rings griga's Avatar
    Jun 30 2017
    Central Jersey
    i also have surging, some days worse than others depending on weather. 144k miles, still have yet to do a fluid and filter change. didn’t know the cost of fluid has gone down?
    Silver 2008 A4 2.0T | Thermal R&D Exhaust | Cupra R Lip | 034 Mounts | Peelers w/ Spacers | Custom Intake | Paint Matched Reflectors | B5 Perches |
    IG: https://www.instagram.com/rigadesigns/
    Sep 27 2008
    Phoenix
    Are you experiencing issues in D or S mode?
    Jun 30 2017
    Central Jersey
    personally, i only have the issue in D and very very slightly in TIP mode. In TIP it’s mainly slipping not really surging. I haven’t experienced it in S but i prefer not to drive in it
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    No "surging" issues with the tip trans in our 08 Avant before and after the fluid and filter was changed at around 75k and the car has about 92k now. Car is completely stock.
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
    Oct 26 2018
    2014 Lincoln MKZ 400 HP
    Akron, Ohio
    Do these cars have a lock up style converter?
    If they do then it might just be the converter de coupling due to high load demand and not enough RPM to keep it locked up.
    My 2005 with 235000 miles does not do this warm or cold, but it does not down shift into 1st gear unless you come to a complete stop.
    But it will take off in second gear pretty well.
    First gear seems a little useless, it shifts into second gear only moving a couple of feet.
    Veteran Member Three Rings K1196A's Avatar
    Feb 16 2007
    B9 S4, 2018 Q5, 2012 Tacoma TRD Sport
    DOVER, PA
    180k+
    same as most describe... occurs when cold and stops once warm. probably around 120k when it started. doesn't seem to be getting worse, but I'd be happy to not have it.
    Jun 17 2013
    jersey city nj
    @ it as 1 of the characteristics of these cars
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Definitely happens to me as well. Close family member and his b7 has had problems all over the place. Torque converter RPMS surge though, usually around 30-45MPH when it's cooler outside
    Sent from my ZTE B2017G using Audizine mobile app
    Established Member Two Rings Dwightlud's Avatar
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    I have a 2006 Avant that I bought with 72,000 on it. At that time is had a surge of about 30-40 RPMs. Surging stops once it has been driven for a time. Three years and 30,000 miles later, nothing has changed. I also have a 2008 sedan with 70,000 and no sign of fluctuation.
    Jun 23 2008
    Transmission Fluid Flush + Filter change should decrease the issue significantly. I had it on mine and it got rid of it 99%.
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Good to know. I’m planning to give it a try in the next week or so. I will report back with my results.
    Established Member Two Rings Planespotting's Avatar
    Oct 25 2013
    '19 Tacoma DCSB, '05 Ducati Multistrada 1000S DS
    MI
    Yup. Second owner and it has done it since I bought the car in 2013 at 114k miles. I now have 176k. It seems like its getting worse. I may have a flush/fill done before long.
    2008 Ibis White A4 2.0T (fake) S-Line | Tiptronic (I know...) | Quattro | APR Stage 2
    Jan 22 2018
    Detroit, MI
    I have a 2007 A4 with 107k miles surging about 200rpm between 30-45mph when cold while in D. Third gear seems to slip while shifting into fourth and surges about 400rpm. This is not present with >25% throttle or after the engine temps come up and the car has done a few minutes above 50mph. This issue also isn't present in Sport or Manual modes regardless of temps.
    2007 Audi A4 Quattro 2.0T Tiptronic JHM Stage 2+ 93 octane
    Luft-Technik FMIC, JHM HPFP, test pipe, downpipe to Y, and B6 S4 catback exhaust
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    2007 2.0 TIP. Bought the car with 63k and a slight rpm bounce when cold weather hits that disappears when it warms up. Now it is close to 130k and the issue has remained relatively the same. I have a buddy with a 2.0 TIP and his seemed a little worse, he ended up replacing the TC and it solved the issue.
    They're not scared of you. They're scared of what you represent to 'em.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by griga View Post
    You can find the zf oem fluid for like $22/l. Can get cheaper comparable stuff for like $16. Was just on a site(can't rem which) and everything was under $200. Thats for 6 liters, not for a full flush. Just a drain and fill.
    Sent from my VS995 using Audizine mobile app
    Jan 21 2018
    frackville, pa US
    That sitr is rmeuropean.com
    Jun 27 2011
    FCPEuro has ZF Lifeguard for cheap too
    -CP
    2017 Q7 3.0t
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    UPDATE: ZF lifeguard fluid and filter change from FCP, cost around 250$. No change in symptoms. Kit came with 8 quarts, only took 5.
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    What you need to do is drive for ~1k miles and then change it again. Just a drain and refill if you already changed the filter. This way you are assured that the majority of the fluid is fresh. As for the surging, you probably have a vacuum leak somewhere. I've changed the fluid twice in my S4(140k) and it still does it when it's cold and then goes away when it warms up.
