Page 1 of 4 123 ... LastLast
Results 1 to 40 of 151
    Veteran Member Three Rings mike0819's Avatar
    Oct 29 2016
    nz
    Right oil for 3.0 tfsi?
    Hi some people recommend 5w 40, on castrol edge web recommendations 5w 30 ll, so what is the best ratio for this engine? And how many litre I need? Please help
    Jul 21 2004
    South Florida
    Quote Originally Posted by mike0819 View Post
    The oil needs to meet vw502 spec. For castrol its the 0w40 euro. For m1 its also 0w40. Id get the m1. You can get it in 5qt jugs from walmart for 25 bucks or less
    2018 Audi S5
    Gone-
    Oct 29 2016
    nz
    Hi I. M in New Zealand, I don't think we got 0w 40 in store, will the 5w 30 castrol edge still works fine?
    Jul 21 2004
    South Florida
    Ahhh. You get different products there. It should be the 5w40. The bottle should say vw502 on back
    2018 Audi S5
    Gone-
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Anything with VW502. I prefer the Mobil 1 0w-40 FS (formerly called European Formula), but if the bottle says VW502, it is good to go.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Lots of guys swear by the Mob 1 products, but also those that swear at them. I think they are decent, but many other oils out there just as good. If you are doing a 5k oil change,it probably doesn't matter. I would use the higher viscosity oil if you have had any oil consumption issues, as long as it id not to cold outside. Not sure of weather in NZ .Summer soon!
    Jun 30 2018
    Port Moody BC PNW
    Just buy oil that meets the spec, read the bottle
    Sent from my PH-1 using Tapatalk
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by Dr GP View Post
    Funny, I always thought of M1 as the "discount" go to for synthetic oil, but after buying our Macan, I was surprised by Porsche's standing recommendation to use it across their model lines.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Quote Originally Posted by sacandagaD View Post
    They are decent enough for regular drivers as long as you don't beat your car on a track.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Jul 21 2004
    South Florida
    Quote Originally Posted by wangshuo1989 View Post
    The 911 guys use the m1 5w50 for serious track duty as recommended and approved by Porsche. I run the factory fill m1 0w40 in mine.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Three Rings Allan691's Avatar
    Jul 23 2018
    Vicenza, Italy
    VW 505 okay? Is it 502 or greater? Or only 502?
    2009 Euro-spec Black Optics S4 Avant APR Stage 2 APR SC pulley + JHM187 with APR Open Air Intake • CR-15 + AK + Eurocode USS + Diff + Trans inserts • P3
    Dec 14 2017
    Windsor, ON
    Liqui Moly
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Mar 28 2016
    Quote Originally Posted by Allan691 View Post
    505 is diesel oil.
    Jul 02 2013
    Quote Originally Posted by B8S42011 View Post
    Liqui Moly
    +1, I'm a big Liquid Moly fan in my Audi.
    Established Member Two Rings Dimich's Avatar
    Jan 01 2013
    2013 audi S4 Prestige
    Portland, OR
    I personally use Liqui Moly or Motul Specific in 5w-40. some have had "consumption" issue with M1
    Senior Member Three Rings EAFLO88's Avatar
    Dec 08 2016
    Texas
    Liquid Moly works exceptionally well for me as well. I’ve learned to stay away from M1 due to rapid oil level decreasing.
    Mar 28 2016
    Add me to the list of happy Liqui Moly users. That stuff is awesome.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Well its how much money they want to pay Porsche to put their logo on the cap is all that is.
    I don't think M1 is discount oil. i don't know if anyone has ever looked at how the different variations of oil is produced and where it is made and quantity will affect pricing. I swear by M1. I have used it in every Audi and VW i have owned except for my TDI. I have had 0 issues with it what so ever. I burn 0 oil in my 14 S4. But i think thats because i broke it in correctly.
    I tried to try Liqu Moly and it was backorder like a B from ECS and they couldn't fill the order for weeks. So i said hell with them canceled the order and went back to M1.
    I change mine at 5K or once a year which ever comes first. Usually its once a year. But maybe if i was going to the track i would look for something thicker. But if it meets the 502 guidelines its as good as the next one.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    M1 0w-40 no issues.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Only oil I'll use in this car.
    Sent from my SM-G965U using Tapatalk
    2021 Audi S4, P34 Intake
    Mar 28 2016
    According to a Liqui Moly rep, the Leichtlauf High Tech replaced that and is what he recommended.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Synthoil is not approved for VW 502 spec, only recommended.
    In the past I've used Motul Specific 5W-40. Car ran great, never burned a drop.
    I recently switched to Liqui Moly Leichtlauf High Tech 5W-40. I switched because I wanted to order oil from FCP Euro. FCP offers a lifetime replacement guarantee on all products that they sell. This means you basically only have to buy oil once. When it's time for another oil change, order up a new kit and change the oil. Dump the old oil into the new empty bottles and send it back to them for a full refund. Send back your old used crush washers and oil filters too. It's all covered, as long as you originally purchased it from them.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Mar 28 2016
    Quote Originally Posted by Acejam View Post
    Yes it is.
    EDIT: I take it back, you're right. No idea how I missed that. Glad I switched to the Leichtlauf.
    Dec 22 2009
    MA
    Quote Originally Posted by hilmar2k View Post
    Yes it is.
    Approved != recommended
    Mar 28 2016
    Yeah, I know that. I just can't believe missed that it was only recommended. I've only run the Leichtlauf in the S4, but I used the Synthoil in my A6.
    Senior Member Three Rings KAMP's Avatar
    Sep 18 2018
    2004 Nissan Murano SE AWD
    I think mobile 1 is a good oil and I see a lot of people are using it. I see someone saying to buy the 5qt but what are most of you pouring in... about 7qts total? I guess Walmart is a good place to get it but what about the filter.. do they also carry them?
    Dec 14 2015
    Orange County, CA
    My car like Motul 8100 X-Cess 5W40. Low wear numbers as confirmed by Blackstone.
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Oct 29 2015
    Los Angeles, CA
    Mobil1 0-40 is all you need. oil/filter change every 5k. Had a GTI with 200k, only used that oil, ran great but can't say the same for rest of the car
    Jul 02 2013
    Run this by me again???
    Jul 21 2004
    South Florida
    FCP has a completely inclusive policy that all parts they sell are warrantied for life. In general i'd guess they have done well with this policy.
    That said there are the .1% of folks who will do things like send back spark plugs that still look almost new that have 30K miles on them because they want a new set. FCP has posted pictures of the plugs and they did send out replacements.
    Or sending back used oil for new oil although if I were FCP i'd force the customer to send a used oil analysis with it stating the oil is really completely used up. I suspect most UOAs would show the oil still has 50% of so life left in it.
    So yes, you can technically apparently get away with draining out your old oil and ship it back for new oil.
    Mike
    2018 Audi S5
    Gone-
    Feb 14 2017
    Gulfport, MS
    Read the back label, guys. VW502 should be there.
    Within brands, even full synthetics have different additives. Not all Mobil 1 synthetic is the same.
    For Mobile 1, you want the one labled "FS." This is a rebranding of what they formerly called "European Car Formula", which may still be on some vendors' shelves. Look for FS or European Car Formula. Identical and VW502 approved.
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    What kind of a dbag would send back used oil. Is 70 bucks really that important that your willing to be "that guy" that takes advantage of a solid policy.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Jul 02 2013
    Quote Originally Posted by bhvrdr View Post
    Mike
    I'm just floored that the return policy would apply to normal maintenance consumables, wow.
    Mar 28 2016
    Quote Originally Posted by tar View Post
    I haven't done it, but that is their policy. It literally covers everything, assuming it can be sent back. So something that gets fully used (think gas additive, aerosol can, etc) can't be sent back, since it is gone. Seems like a no-brainer for brakes, wiper blades, etc.
    Established Member Two Rings SVG's Avatar
    Jul 05 2016
    68’ Ca Spcl, 96’ CTD, 05’ LJ Rubicon (sold), 06’ Victory JP, 14’ S4, 17’ Rav4 Hybrid
    Ca/MT
    I just ordered 5 cases of M1 0-40w "european car” oil from Costco. 6 quarts for $28 with free shipping.
    And regarding Porsche selecting this oil based on a marketing agreement with M1, please. Do you really think Porsche would assume such a massive warranty liability on their cars for this if the oil wasn’t up to snuff?
    I don’t.
    2014 Estoril Blue S4
    Jul 23 2018
    Vicenza, Italy
    505 is diesel oil.
    Could be.. But nowhwere on the bottle does it state that.. Since I am in Italy where it is full of diesel cars and thus diesel oil, I was overly cautious to check and make sure I did not see “diesel” written anywhere.. It seems (from my quick research) as if it is not a problem regardless as long as it meets API SN, which is does..
    Mar 28 2016
    Not "could be", is.
    https://www.oilspecifications.org/volkswagen.php
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    2nd
    LM 5w40 from FCP and return it.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Jul 23 2018
    Vicenza, Italy
    Okay. Also IS for gasoline..
