Results 1 to 7 of 7
    Jun 21 2018
    Alabama
    Oil cooler hoses?
    I'm in the middle of my engine pull/timing service, meaning that I've got the engine out and I'm undressing the engine to get to the timing covers. At this point I'm starting to order parts that I know I will want to use in putting it back together. All of the hoses down low connecting to the engine and radiator were really oily, and I feel it's best to replace them.
    The ones on the driver's side are power steering hoses, right? There seem to be a lot of them, and I haven't sorted out all the part numbers yet, but at least I can find diagrams.
    On the passenger side (right seat side, this is a USA left hand drive car) the two nasty lower hoses seem to be send and return from the oil cooler. The one with the two hex nut connection was tough to get off, and I ended up twisting it a lot to get the nut off of the thread. The problem is, I can't find this hose in any of the oil cooler or radiator diagrams I've found.
    What would be really great is a diagram labeling the various hoses, but my immediate need is to identify that particular hose, the one with the two hex nut connection at the radiator. Anybody?
    Jun 21 2018
    Alabama
    Maybe a pic would help. Thousand words and all that.
    Nov 12 2015
    Oregon
    B6/7 s4?
    The b6/7 S4 has an oil cooler mounted to the block with only coolant hoses coming off of it.
    That leaves power steering cooler hoses on the drivers side and automatic cooler lines on the passenger side. Are these what you are referring to?
    Sent from my SM-N920V using Tapatalk
    My build log
    Jun 21 2018
    Alabama
    Quote Originally Posted by VinnysS4 View Post
    B6/7 s4?
    Oops! Long day.
    B7 S4, Tiptronic. The pic is of the passenger side pair of lines connected to the oil cooler, I think. Next to the alternator.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Quote Originally Posted by NALS4 View Post
    Oops! Long day.
    The lines in your pic would be your transmission cooler lines and they connect to the front clip assembly, not the oil cooler.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Nov 03 2011
    All Over!
    A cheaper option would be to remove the original corroded lines, and get them made in stainless braided.
    They’ll last longer, and will still be cheaper than buying the RS4-specific lines from Audi.
    1986 Type 85 Audi 90 quattro
    Jun 21 2018
    Alabama
    Thanks for the clarification on just what those lines are, and for the suggestion on the braided lines. This forum rocks!
    As it turns out, one of my friends who has been helping with my first time pulling an engine is a former aircraft tech. He says he'll help me put hoses together with end fittings. This could work!
